Fermion: MEMS Nitrogen Dioxide NO2 Gas Detection Sensor (Breakout, 0.1-10ppm)
$7.50
SKU: SEN0574
  • $7.20 3+ items
  • $7.10 5+ items
  • $6.90 10+ items
Compact NO2 sensor using MEMS tech, offers low power consumption, fast response, measures NO2 qualitatively, suitable for air quality and automotive emissions.
Fermion: MEMS Nitrogen Dioxide NO2 Gas Detection Sensor employs state-of-the-art micro-electromechanical system (MEMS) technology, endowing the sensor with compact dimensions (13x13x2.5mm), low power consumption (<20mA), minimal heat generation, short preheating time, and swift response recovery. The sensor can qualitatively measure the concentration of nitrogen dioxide gas, and is suitable for nitrogen dioxide detector, automobile exhaust detection, and other application scenarios.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Wiring Diagram of Fermion: MEMS NO2 Sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS NO2 Sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Air quality monitoring: measures the level of NO2 and other pollutants in the ambient air.
  • Automotive emission control: monitors the NO2 emission from vehicles and adjusts the fuel injection and combustion parameters to reduce the emission.
  • Industrial safety: detects the leakage or exposure of NO2 and other toxic gases in industrial processes or workplaces.
  • Gas detected: NO2
  • Detection range: 0.1-10ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 5ppm NO2) ≤ 0.5
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS Nitrogen Dioxide NO2 Gas Detection Sensor × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
    Smart Solar Plant(Environment monitoring)
    Projects Smart Solar Plant(Environment monitoring)
    RAJESHKT
    May 17, 2024
    Alan .Arias Diosdado Oct 29, 2025
    Tal como se describe en la página. Excelente producto
