_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
_150x100.jpg.webp)
LattePanda Sigma is a hackable x86 Windows / Linux single board server with mighty power. It features an Intel Core i5-1340P processor with Intel Iris Xe Graphics, and up to 32GB Dual-Channel LPDDR5 memory. This powerful single board computer can be used as a home server, streaming server, game server, IoT, AI Inference, edge computing, and more.
Ultimate Performance
LattePanda Sigma is equipped with the 13th Intel Core i5-1340P processor, which features 12 cores and 16 threads with the turbo frequency up to 4.6GHz, offering ultimate performance and multitasking capabilities.
This single board computer features Intel Iris Xe Graphics with 80 execution units (EUs) capable of reaching dynamic frequency up to 1.4GHz, delivering superior graphics performance and rendering quality.
Lightning-Fast Memory
LattePanda Sigma boasts up to 32GB of dual-channel LPDDR5-6000 memory, with an impressive bandwidth speed of up to 102.4GB/s - doubling the speed of the previous generation.
Rapid Chill with Silent Whisper
Thanks to its robust cooling capabilities, the LattePanda Sigma's processor consistently maintains a high-performance 44W TDP (Thermal Design Power), delivering stable and sustained performance without degradation.
Complementing this, the cooling fan's silent operation at just 35 decibels in idle mode provides a tranquil environment.
Perfect Balance Between Performance and Energy
The Intel Core i5-1340P processor delivers high energy efficiency with impressive performance. For example: It achieves comparable performance to the Intel Core i9-9900K but with half the power consumption.
This efficient energy consumption does not sacrifice computing power, offering an exemplary balance ideal for diverse applications.
Compact Size, Mighty Power
This mini PC is just slightly larger than a traditional mouse, with dimensions of 102mm*146mm. Its compact size allows for easy portability or convenient integration in the devices with limited spaces.
Quad 4K Displays
LattePanda Sigma allows for seamless multitasking with its ability to simultaneously connect up to four 4K screens. This feature enables users to effortlessly handle multiple tasks.
Rich Interfaces
LattePanda Sigma boasts an array of interfaces, including USB, HDMI, RS232, GPIO, Ethernet, eDP, and more, accommodating a wide variety of applications.
Moreover, it offers four M.2 slots and dual Thunderbolt 4 ports, enabling high-speed connections and extensive expansion possibilities for M.2 SSDs, 4G/5G modules, Wi-Fi modules, HD displays, eGPU, Type-C docks, and beyond.
Diverse OS Support
LattePanda Sigma single board server supports a variety of operating systems: Windows 10, Windows 11, Ubuntu, ensuring that there is always one that suits your needs.
Professional and Instant Technical Support
To meet the needs of industry users, LattePanda team provides fast and efficient technical support services. Whether it's installation and configuration, troubleshooting, or system integration, the dedicated technical team at LattePanda is always here to ensure the stability and smoothness of your project. Kindly reach out to [email protected].
Customized Solutions
LattePanda series single board computer supports special customization, including hardware and interface modifications, customized boot screens, BIOS feature adjustments, customized operating systems, and so on. If you have any specific requirements, please feel free to contact [email protected]. The LattePanda team is dedicated to providing prompt and professional support to cater to your customization needs.
Rigorous Certifications
LattePanda Sigma single board server has obtained multiple international certifications, such as CE, FCC, KC, UKCA and RoHS, ensuring device safety and reliability. These certifications not only enhance the market competitiveness of the products but also simplify the certification process for the whole system.
Processor
Download
Oct 20, 2025
I’ve been using the LattePanda Sigma for over a year as part of an embedded computing setup with some pretty demanding requirements. The hardware itself is remarkably capable — essentially a full desktop platform in compact form, with excellent CPU performance, dual Thunderbolt 4 ports, generous RAM options, and stable power delivery. It runs modern operating systems smoothly and has handled demanding workloads without issue. Early in ownership, my first unit developed a fault and had to be returned. The RMA process was handled professionally, and the replacement has since run continuously and reliably for almost a year. One limitation I’ve encountered is that, while the Thunderbolt ports function perfectly for display and storage, tunneled USB devices (like those built into Thunderbolt monitors) aren’t detected under Ubuntu on this hardware. This may be a firmware or compatibility limitation rather than a defect, but it’s worth noting for anyone depending on full Thunderbolt peripheral passthrough. Overall, the Sigma offers an exceptional balance of performance, I/O flexibility, and power efficiency for advanced embedded or technical applications. A few firmware refinements and more comprehensive Thunderbolt support would make it a solid 5-star product for me.
Jan 08, 2026
I believe this is a good board. I do have 2 issue with it, the blue USB plastic fell out when using them and the fan has already failed. I purchased this 08/01/2024 and would expect the cooling solution to last longer then that. But I have it sitting on another fan that seems to keep it cool for now. Will be looking for another cooling solution as there does not seem t obe one currently from DFRobot.
Dec 28, 2025
Arrived quickly. Device was easy to setup and works perfectly. The BIOS is unlocked and has a lot of settings to tinker with like CPU turbo timings and CPU power limits, which is nice to see. Runs Debian 13 without any issues.
