STL-27L 360° DTOF LIDAR Sensor (UART, 25m)
$160.00
SKU: SEN0589
A compact, high-precision 360° DTOF LIDAR with 0.03-25m range, ROS compatibility, anti-glare, and FDA Class 1 safety, ideal for robots and drones.
Purchase this product and earn 1600 reward points, which are tied to VIP membership program. Learn More >
STL27L 360° DTOF LIDAR
Features of STL27L 360° DTOF LIDAR
Ranging range: 0.03- 25m, can perceive farther environmental information
STL27L 360° DTOF LIDAR Ranging range
Excellent performance and high precision allow it to accurately perceive the contours of the environment
Angular resolution: 0.16 7°, Within the effective measurement distance range of 2 meters, the average error is within 15mm
The provided SDK works well with both ROS1 and ROS2 systems.
STL27L 360° DTOF LIDAR SDK works with both ROS1 and ROS2 systems
Anti-glare: effectively resists ambient light interference.
STL27L 360° DTOF LIDAR Anti-glare
Extremely small size Easy to integrate and stylish.
STL27L 360° DTOF LIDAR Extremely small size
Coaxial brushless motor, stable performance,lifespan up to 10,000 hours
STL27L 360° DTOF LIDAR Coaxial brushless motor
Laser Conforms to FDA Class 1 human eye safety level
STL27L 360° DTOF LIDAR FDA Classl human eye safety level
  • Home Service Robot
  • Commercial Service Robot
  • Special Robot
  • Drone
  • Industrial Robot
  • STL27L 360° DTOF LIDAR Applications Home Service Robot, Commercial Service Robot, Special robot, Drone and Industrial Robot
  • Measuring range: 0.03~25m
  • Measurement accuracy:
         ±15mm at 0.03m-2m, standard deviation of 5mm;
         ±20mm at 2m-8m, standard deviation of 15mm;
         ±30mm at >8m, standard deviation of 25mm
  • Scanning angle: 360°
  • Scanning frequency: 10Hz
  • Measurement frequency: 21600 Hz
  • Angular resolution: 0.167° @10Hz
  • Operating voltage: 4.5~5.5V
  • Power consumption: <300mA @5V
  • Communication method: UART
  • Anti-ambient light: 60klux
  • Operating temperature: -10°C~ 50°C
  • Storage temperature: -30°C~ 70°C
  • Weight: 45g
  • STL27L 360° LIDAR (25m) x 1
  • 4-pin DuPont cable x1
  • Review
    Matteo.Venuti Jan 01, 2024
    This is a great lidar module for robotics projects! Though it is worth noting that if you want to use this you may want to purchase a USB to serial converter as well.
    Out Of Stock
