Mini Laser Distance Range Sensor (4m, I2C, IP67)
$12.90
SKU: SEN0590
Compact laser distance sensor with up to 4m range, fast response time, IP67 waterproof, I2C output. Ideal for smart systems, security, and robotics applications.
This laser distance ranging sensor has a compact size, comparable to the size of a fingernail, and a measurement range of up to 4m. It is specifically designed to address the issues commonly found in distance sensors on the market, such as large size, slow response time, and poor installation adaptability.
It boasts a range of advantages including small size, minimal blind zone (Measurement accuracy: ≤25cm@±1cm, >25cm@±S*4%cm), fast response time (19-38ms), high installation adaptability, dust and water resistance (IP67), long lifespan, and high reliability.
The sensor outputs data through an I2C interface, which allows users to easily integrate it with Arduino IO expansion boards.
It finds widespread applications in various fields, including smart furniture with motion sensing capabilities, home security systems, intelligent detection systems, smart control systems, robot obstacle avoidance, and object proximity and presence detection.
Wiring Diagram of Laser Ranging Sensor and IO Expansion Shield
Figure: Wiring Diagram of Laser Ranging Sensor and Arduino IO Expansion Shield
  • Compact size and small blind zone
  • Lightweight and fast response time
  • Simple to use with I2C output
  • IP67 waterproof rating
  • Smart furniture with motion sensing capabilities
  • Home security systems
  • Intelligent detection systems
  • Smart control systems
  • Robot obstacle avoidance
  • Object proximity and presence detection
  • Measurement range: 2-400cm.
  • Measurement accuracy: ≤25cm@±1cm, >25cm@±S*4%cm (with an actual error of around 5mm).
  • Operating voltage: 3.3-5V.
  • Idle current: 2mA.
  • Operating current: <19mA.
  • Communication method: I2C.
  • Output response time: 19-38ms.
  • Power-on delay time: ≤800ms.
  • Detection angle: 19°.
  • Operating temperature: -15°C ~ 60°C.
  • Operating humidity: 65% ~ 80%RH.
  • Storage temperature: -30°C ~ 80°C.
  • Storage humidity: 65% ~ 90%RH.
  • Laser Ranging Sensor (4m) x1
  • Review
    Steffen.Lorenz Jan 30, 2025
    Perfect device, nothing to complain about. I have it on the Unihiker M10 and the data comes quickly.
    Phoenix.Rahill Oct 18, 2024
    Very responsive and works at much more oblique angles than an equivalent ultrasonic sensor. Exactly what I wanted for my project although it required a few small hacks to get working with a Raspberry pi. It also sadly doesn't have a reprogammable address.
    Only 5 Left
