3D ToF Depth Sensor Camera with 1.14 Inch LCD Screen (0.15~1.5m, supports ROS1 and ROS2)
$29.90
SKU: SEN0581
A 3D TOF depth camera measures distances up to 1.5m, supports ROS systems, and features a real-time preview LCD screen. Ideal for IoT applications.
The 3D TOF depth camera is composed of the BL702 and Juyou 100x100 TOF, and is a 3D sensor that can measure distances up to 1.5m. Its built-in 1.14-inch LCD screen allows for real-time preview of depth maps with color maps. The module is plug-and-play with UART and Type-C interfaces. It supports ROS systems (ROS1 and ROS2), enabling fast acquisition of depth data and depth maps.
3D TOF Sensor Camera is an all-in-one, low-cost, flexible and easy-to-use 3D ToF (Time of-Flight) solution for IoT applications.It integrates the following algorithms: Specific applications, such as ranging, multi-area human body positioning and sensing, posture monitoring, posture control, keystone correction, etc. These features are widely used in loT applications like white goods, Laser TV, smart projectors, smart illumination, smart parking, and smart home facilites.
Interfaces of the 3D TOF depth camera
Built-in LCD screen for real-time depth map preview
Selection Guide
Depth Sensing Camera Selection Guide
Figure
SKU
SEN0581
SEN0583
SEN0579
SEN0673
Depth Resolution
100×100 @ 20fps
320×240
640×480 / 320×240
640×480 / 320×240
Sensing Range
0.15 – 1.5m
0.2 – 2m (indoor)
0.1 – 5m (90% reflectivity)
0.1 – 5m
RGB Support
No
Yes
No
Yes
RGB Resolution
N/A
800×600
N/A
1920×1080 / 640×480
Measurement Accuracy
≤1% / cm
≤1% / cm
±1.5cm @ 0.5m ±1% @ 0.5–5m
±2.5cm @ 0.5m ±1% @ 0.5–5m
FOV (Depth)
H70° × V60°
H55° × V72°
H60° × V45°
H97° × V95.5°
FOV (RGB)
N/A
H78° × V98°
N/A
H91.5° × V59°
Power Consumption
Low (5V supply)
Medium (with active cooling)
Avg. 1.2W (5V / 0.5A)
Avg. 3W (5V / 0.6A)
Data Interface
UART / USB 2.0
UART / USB 2.0
USB 2.0 Type-C
USB 2.0 Type-C
Compatibility
Windows / Linux / ROS
Linux (RNDIS)
Win10 / Linux / ROS
Win10 / Ubuntu / ROS
Special Features
Built-in LCD for real-time preview
RGB-3D fusion Python SDK
Dual-frequency / single-frequency modes Industrial-grade reliability
AI recognition Wide dynamic range
Laser Safety
N/A
N/A
Class 1
Class 1
Add to Cart
  • Combination of iTOF sensors
  • Depth range: 0.15–1.5 meters
  • Power supply and data transfer via USB 2.0
  • Low power consumption
  • SLAM and robotic navigation
  • Surveillance & security inspection
  • People counting & tailgate detection
  • VR/AR & gesture recognition
  • Autopilot and AGV obstacle avoidance
  • 3D modelling
  • Dimensions measurement
  • Liveness Detection & facial recognition
  • CPU: 32-bit RISC CPU with FPU,Up to 144 MHz
  • Memory: 132KB RAM and 192KB ROM
  • Camera Supply Voltage: 5V/0.5A
  • TOF Measurement range: 0.15–1.5 m
  • Camera Size: 23.25*40.70*10.50 mm
  • External interface:
               UART (1.25mm)
               USB2.0 (Type-C)
  • Display: 1.14-inch LCD
  • ROS: Support ROS1/ROS2
  • FOV: TOF70°(H) x 60°(V)
  • Operating Temperature: -20~+50℃
  • Weight: About 10g
  • 3D TOF Sensor Camera × 1
  • Review
    Mingkwunrak.Wonchana Feb 04, 2025
    This product works great, it can be used with ROS2 or ROS1, it has a driver so you don't have to write it yourself, it can be applied to your projects in many ways.
