Gravity: GP8101S 1-Channel PWM to 0-5V/10V DAC Module
$8.90
SKU: DFR1036
  • $8.60 3+ items
  • $8.50 5+ items
  • $8.20 10+ items
1-channel DAC module with PWM communication, 8-bit resolution, outputs 0-10V/0-5V for automation control via Arduino, featuring 0.2% accuracy.
This is a 1-channel DAC module with PWM communication, a resolution of 8-bit, and an accuracy of 0.2%, capable of generating analog voltage outputs of 0-10V or 0-5V. The 0-10V or 0-5V voltage output is a standard driving method. It can be widely used in automation control scenarios such as lighting adjustment, frequency converters, valve regulation, and pump control,etc. This product can drive a variety of 0-10V or 0-5V controlled devices available in the market through Arduino programming.
PWM signal drive allows the module to be controlled by MCU digital ports, providing a simple and convenient usage.
DAC series modules are a range of products that can be controlled through I2C or PWM signals to generate voltage or current output signals. This series of DAC products not only offers a variety of output signal ranges, but also provides three selectable resolutions: 8-bit, 12-bit, and 15-bit. It allows for the choice of either single-channel or dual-channel configurations, and multiple modules can be cascaded to form a multi-channel output.
Functional Diagram of GP8101S: 1-Channel PWM to 0-5V/10V DAC Module
Functional Diagram of Gravity: GP8101S 1-Channel PWM to 0-5V/10V DAC Module
Wiring Diagram of GP8101S: 1-Channel PWM to 0-5V/10V DAC Module
Wiring Diagram of Gravity: GP8101S 1-Channel PWM to 0-5V/10V DAC Module and Arduino UNO
We provide various models of DAC modules. If you need a different model, please check the selection guide:
Click here to get Selection Guide of DAC Modules
Selection Guide
DFRobot Gravity DAC Module Selection Guide
Figure
SKU
DFR0552
DFR0971
DFR0972
DFR1071
DFR1036
DFR1037
DFR1073
DFR1035
DFR1230
DFR1034
DFR1229
Add to Cart
Description
I2C 12-Bit DAC
2-Ch 0-10V DAC
4-20mA Current DAC
1-Ch 15-Bit (0-10V)
1-Ch PWM (0-10V)
2-Ch PWM (0-2.5V)
2-Ch 15-Bit (0-10V)
1-Ch 15-Bit (0-2.5V)
Hi-Res ±10V / 4-20mA
2-Ch 12-Bit (0-2.5V)
Hi-Res 0-10V / 4-20mA
Comm.
I2C
I2C
I2C
I2C
PWM
PWM
I2C
I2C
I2C/PWM
I2C
I2C/PWM
Res.
12-bit
12-bit
12-bit
15-bit
8-bit
8-bit
15-bit
15-bit
16-bit
12-bit
16-bit
Channels
1
2
1
1
1
2
2
1
1
2
1
Output Range
0~VCC
0-10V / 0-5V
4-20mA (0-25mA)
0-10V / 0-5V
0-10V / 0-5V
0-2.5V / 0-VCC
0-10V / 0-5V
0-2.5V / 0-VCC
±10V, 0-10V, 4-20mA
0-2.5V / 0-VCC
0-10V, 0-10V, 4-20mA
Chip
MCP4725
GP8403
GP8302
GP8211S
GP8101S
GP8501
GP8413
GP8512
GP8630N
GP8503
GP8600
Key Features
Classic model, with EEPROM, cost-effective
Dual-channel industrial voltage, cascade up to 16 devices
Industrial current loop, requires 18-24V power
High precision (0.01%), single channel
PWM driven, easy to use, industrial voltage
PWM driven, dual channel, low voltage control
High precision, dual channel, industrial voltage
High precision, single channel, low voltage control
Flagship, supports bipolar (negative voltage) output
Medium precision, dual channel, low voltage control
16-bit ultra-high precision, multi-function all-in-one
  • Support 3.3V-5V power supply.
  • Output voltage error is less than 0.2%.
  • Output voltage linearity error is 0.1%.
  • Two channels of voltage output, either 0-5V or 0-10V, enabling connection and control of standard analog voltage devices.
  • Gravity interface, PWM communication, Arduino control, suitable for program automation control.
  • PWM signals can be utilized to drive the module, enabling it to be controlled simply by the digital port of the MCU.
  • Automatic light adjustment
  • Variable frequency drive (VFD)
  • Automatic valve regulation
  • Automatic water pump control
  • Operating voltage: 3.3V to 5V
  • Communication Method: PWM
  • Chip Type: GP8101S
  • Resolution: 8-bit
  • Output Voltage: 0-5V or 0-10V
  • Number of channels: 1 channel
  • Value Range: 0 - 255 corresponding to 0-5V or 0-10V
  • Output voltage: 0.2%
  • Output voltage linearity error: 0.1%
  • GP8101S: 1-Channel PWM to 0-5V/10V DAC Module ×1
  • Gravity-3Pin Analog Sensor Cable ×1
    Certifications
    Blog Selection Guide of DAC Modules
    Oct 25, 2023
    Jens.Gilbers Feb 27, 2026
    I use this in my grow setup to controll my Sanlight EVO. Its very easy to install!
