Last Call! We pause shipping on Feb 14th. Order NOW to get your gear shipped before the holiday!
Gravity: GP8512: 1-Channel 15bit I2C to 0-2.5V/VCC DAC Module
$9.90
SKU: DFR1035
1-channel DAC module with 15-bit resolution, I2C communication, and 0.01% precision. Suitable for microcontrollers like ESP32, Raspberry Pi, and STM32.
Purchase this product and earn 70 reward points, which are tied to VIP membership program. Learn More >
This is a 1-channel analog voltage output DAC module with I2C communication, 15-bit resolution, and 0.01% precision. It is well-suited for control projects operating within the 3.3V range, such as ESP32, Raspberry Pi, STM32, and other microcontrollers that require analog signal output.
The high precision and resolution of this module make it suitable for control scenarios that require higher signal accuracy, such as fine speed control or angle control.
DAC series modules are a range of products that can be controlled through I2C or PWM signals to generate voltage or current output signals. This series of DAC products not only offers a variety of output signal ranges, but also provides three selectable resolutions: 8-bit, 12-bit, and 15-bit. It allows for the choice of either single-channel or dual-channel configurations, and multiple modules can be cascaded to form a multi-channel output.
Functional Diagram of Gravity: GP8512: 1-Channel 15bit I2C to 0-2.5V/VCC DAC Module
Wiring Diagram of Gravity: GP8512: 1-Channel 15bit I2C to 0-2.5V/VCC DAC Module
Wiring Diagram of Gravity: GP8512: 1-Channel 15bit I2C to 0-2.5V/VCC DAC Module and Arduino UNO
We provide various models of DAC modules. If you need a different model, please check the selection guide:
Selection Guide of DAC Modules
  • Support 3.3V-5V power supply.
  • Output voltage error is less than 0.01%.
  • Output voltage linearity error is 0.01%.
  • Two channels of voltage output, either 0-2.5V or 0-VCC, enabling connection and control of standard analog voltage devices.
  • Gravity interface, I2C communication, Arduino control, suitable for program automation control.
  • The high precision and resolution of this module make it suitable for control scenarios that require higher signal accuracy.
  • Orchestrates automatic control of motor rotational speed
  • Facilitates the automatic modulation of volume
  • Governs temperature through automatic control mechanisms
  • Commands the automatic control of indoor and outdoor illumination
  • Functions as an apparatus for laboratory testing equipment
  • Operating voltage: 3.3V to 5V
  • Communication Method: I2C
  • Chip Type: GP8512
  • Resolution: 15-bit
  • Output Voltage: 0-2.5V or 0-VCC
  • Number of channels: 1 channel
  • Value Range: 0 - 32767 corresponding to 0-2.5V or 0-VCC
  • Output voltage: 0.01%
  • Output voltage linearity error: 0.01%
  • GP8512: 1-Channel 15bit I2C to 0-2.5V/VCC DAC Module ×1
  • Gravity-4P I2C/UART Sensor Cable × 1
    Blog Selection Guide of DAC Modules
    Oct 25, 2023
