IP68 Underwater Ultrasonic Obstacle Avoidance Sensor (3m, UART)
$28.00
SKU: SEN0598
  • $27.50 3+ items
  • $27.00 5+ items
  • $26.00 10+ items
Underwater ultrasonic sensor for obstacle avoidance, operates on 5-24V, IP68 waterproof, 2-300cm range, compact with minimal blind spots, suitable for underwater navigation.
Purchase this product and earn 280 reward points, which are tied to VIP membership program. Learn More >
This is an underwater ultrasonic obstacle avoidance sensor specifically designed for underwater applications. It operates on a wide voltage range of 5-24V and features compact size, minimal blind spots, high precision, and high protection. Its underwater measurement range is from 2-300cm.
With an IP68 protection rating, this sensor can replace a camera for obstacle avoidance and meet the requirements of normal underwater navigation speeds. By using this obstacle avoidance sensor, underwater vehicles can achieve true "unmanned driving" without the need for human observation. Even at a depth of 10m, obstacle avoidance can still be easily accomplished.
Waterproof level of IP68
Thanks to its small size and minimal blind spots, this sensor takes up minimal space and can be easily integrated into various projects.
Compact in size, with a small blind zone
Note: The sensor can only be used underwater as it requires the presence of water to provide accurate data.
  • Compact in size, with a small blind zone
  • Lightweight and fast response time
  • Waterproof level of IP68
  • Underwater robot obstacle avoidance and self-control detection
  • Measurement of water depth by underwater robots
  • Applications Measurement of water depth
  • Measurement Range: 2-300cm
  • Measurement Accuracy: ±(0.5+S*0.5%)cm@<2m, ±(1+S*1%)cm@>2m
  • Operating Voltage: 5-24V
  • Standby Current: ≤1mA
  • Operating Current: ≤10mA
  • Output Mode: UART controlled
  • Power-on Startup Time: ≤500ms
  • Output Response Time: 10ms
  • Angle: 5-10°
  • Operating Temperature: -15~50°C
  • Storage Temperature: -25~80°C
  • Storage Humidity: 65%~90% RH (non-condensing)
  • Underwater Ultrasonic Obstacle Avoidance Sensor (3m) x1
    Silas.Hung Mar 06, 2026
    We have measured and calibrated different distances underwater, and it is very stable and has repeatable data. Good product.
    Sebastian.Sebastian Oct 25, 2024
    It's working fine and accurately measures the water depth, thank you
