FireBeetle 2 ESP32-C6 IoT Development Board for Smart Home Control System
$5.90
SKU: DFR1075
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
A versatile IoT controller board featuring a RISC-V processor, supporting Wi-Fi 6, Bluetooth 5, Zigbee, and Matter for smart home projects with low power usage.
The FireBeetle 2 ESP32-C6 is a versatile low-power IoT controller board designed for smart home automation, control and monitoring system. It features a 160MHz RISC-V 32-bit processor, providing excellent energy efficiency and flexibility for Internet of Things (IoT) projects. The board supports multiple communication protocols, including Wi-Fi 6, Bluetooth 5, Zigbee 3.0, Thread 1.3, and Matter, enabling versatile wireless connectivity.
Comprehensive Configuration and Programming with Detailed Tutorials
The FireBeetle 2 ESP32-C6 can be configured and programmed using Arduino IDE or MicroPython. Detailed tutorials are provided, making the setup process smoother.
These tutorials cover basic setup, including Arduino IDE configuration, MicroPython flashing and execution, Battery voltage monitoring, PWM output, Interrupt management, UART device communication, Servo motor control, SD card file operations.
Advanced tutorials are also available for project development, including How to connect and drive displays, Transfer data with mobile phones via Bluetooth, Control LEDs with Wi-Fi, fetch network time and weather information, Use ESP32-NOW for communication between devices without Wi-Fi, Implement Smart Config for one-click networking and auto-connection.
These resources ensure users can navigate the setup process effectively, facilitating a seamless experience when starting IoT projects.
Versatile Wireless Connectivity with Matter, Wi-Fi 6, Thread, BLE, and Zigbee
The FireBeetle 2 ESP32-C6 supports multiple communication protocols, making it highly versatile for smart home setups. By supporting Matter, Wi-Fi 6, and Thread, it can create Matter Wi-Fi terminal devices and Matter Thread terminal devices. Matter is an open, interoperable, and secure smart home standard used by many brands, such as HomePod mini and Apple TV 4K. This allows different smart home devices to work together seamlessly within the Matter ecosystem. Detailed tutorials are provided for connecting the ESP32-C6 to the Matter Network.
Additionally, the FireBeetle 2 ESP32-C6 supports BLE (Bluetooth Low Energy) and Zigbee communication protocols. Zigbee and Thread are low-power wireless protocols designed for IoT and smart home devices. Many smart bulbs, dimmer switches, smart plugs, and smart speakers use Zigbee and Thread for communication. When combined with other MCUs, the FireBeetle 2 ESP32-C6 can function as a Thread border router or Zigbee bridge, enhancing its connectivity and integration capabilities.
FireBeetle 2 ESP32-C6 supports BLE, Zigbee, Wi-Fi 6 and Thread
Figure: FireBeetle 2 ESP32-C6 supports BLE, Zigbee, Wi-Fi 6, and Thread
Ultra-Low Power Consumption, Deep Sleep at 16uA
TWT (Target Wake Time) is a power-saving mechanism in Wi-Fi 6 that allows devices to negotiate wake-up times with Wi-Fi access points (APs). The device only activates Wi-Fi when data transmission is needed, remaining off at other times to conserve battery power. The FireBeetle 2 ESP32-C6 offers ultra-low power consumption, with deep sleep mode consuming just 16uA. This mechanism is comparable to a phone only activates Wi-Fi when data transmission is needed, remaining off at other times to conserve battery power. IoT devices often need to run on battery power for extended periods and have low data transmission requirements. TWT extends battery life and reduces network interference, making it highly beneficial for IoT devices.
FireBeetle 2 ESP32-C6 supports Wi-Fi 6's Target Wake Time (TWT) technology
Figure: Wi-Fi 6's Target Wake Time (TWT) technology
Versatile Power Supply Options - Type-C, 5V DC, Solar Charging
The FireBeetle 2 ESP32-C6 offers versatile power supply options, including Type-C, 5V DC, and solar charging, complemented by integrated lithium battery management. This flexibility is ideal for projects in locations like balconies, windows, or rooftops where traditional power sources are impractical.By integrating solar panels and lithium batteries with the ESP32-C6, it ensures a reliable power supply. The FireBeetle 2 ESP32-C6 uses the same solar power management chip as the 5V@1A solar power module, optimizing current output from the input source. A detailed wiring diagram for the FireBeetle 2 ESP32-C6 and Solar Panel is provided for easy setup.
Battery level detection enables monitoring of device battery information, essential for prolonged operation. IoT devices often operate in varied environments, including extreme temperatures that affect battery performance. High temperatures accelerate chemical reactions within batteries, while cold temperatures increase internal resistance. Robust battery management ensures consistent device reliability under such conditions. Additionally, for battery voltage measurement and continuous operation, refer to the provided codefor effective management.
Figure: FireBeetle 2 ESP32-C6 supports solar charging and battery level monitoring
High-Speed Data Transmission (Wi-Fi 6 - Up to 9.6 Gbps | Bluetooth 5.0 - 2 Mbps)
Wi-Fi 6 offers theoretical data transmission speeds of up to 9.6 Gbps, enhancing network-wide data transfer efficiency. Transferring large files, like a 1GB file, can be completed within seconds, optimizing performance for demanding IoT applications.
Bluetooth 5.0 provides a maximum transmission rate of 2 Mbps, enabling swift audio, video, and data transfers. This allows quick volume adjustments or song changes on wireless devices and faster command execution and data synchronization for smart home operations.
Compatible with All DFRobot Gravity and Fermion Series Sensors
DFRobot's Gravity and Fermion series sensors are compatible with the FireBeetle 2 ESP32-C6, offering a comprehensive selection for various projects.
The onboard GDI interface allows for easy connection to screens, ensuring efficient data visualization. Detailed screen lists and configuration tutorials are provided to facilitate seamless integration of ESP32-C6 functionalities into any setup.
Seamless Connectivity
  • Multi-Protocol Support: Wi-Fi 6 (up to 9.6 Gbps theoretical speed), Bluetooth 5 (2 Mbps max), Zigbee, Thread, and BLE.
  • Ultra-Low Power Efficiency: 36µA deep-sleep current (battery-powered).
  • Visual Development & Monitoring
  • Onboard GDI Interface: Direct plug-and-play compatibility with displays for real-time data visualization.
  • Solar Charging: Integrated support for 5V solar panels (max 0.5A charging current).
  • Battery Health Tracking: Built-in battery-level detection for proactive power management.
  • High-Performance Hardware
  • RISC-V Core Processor: 160 MHz single-core with 512KB SRAM, 4MB Flash, and 16KB RTC SRAM.
  • Expanded I/O: 19 digital I/O ports, 6-channel PWM, SPI, UART, I2C, I2S, and IR transceiver support.
  • Precision Sensing: 12-bit SAR ADC (7 channels) with DMA control.
  • Indoor Air Quality Monitoring
  • Indoor Ambient Light
  • Balcony Plant Soil Monitoring
  • Outdoor Weather Station
  • FireBeetle 2 ESP32-C6 Applications: IoT Devices and Smart Homes
    Basic Parameters
  • Operating Voltage: 3.3V
  • Type-C Input Voltage: 5V DC
  • VCC Input Voltage: 5V DC or 5V Solar Panel
  • Max Charging Current: 0.5A
  • Sleep Current (Deep Sleep Mode, Battery-Powered): 36µA
  • Operating Temperature: -10~60℃
  • Dimension: 25.4x60mm/1x2.36”
  • Hardware Information
  • Processor: RISC-V single-core processor
  • Main Frequency: 160 MHz
  • SRAM: 512KB
  • ROM: 320KB
  • Flash: 4MB
  • RTC SRAM: 16KB
  • USB: USB 2.0 CDC
  • WIFI
  • WIFI Protocol: IEEE 802.11b/g/n
  • IEEE 802.11ax (20 MHz-only non-AP mode)
  • Bandwidth: Support 20 MHz and 40 MHz at 2.4 GHz band
  • WIFI Mode: Station, SoftAP, SoftAP+Station combined mode
  • WIFI Frequency: 2.4GHz
  • Frame Aggregation: TX/RX A-MPDU, TX/RX A-MSDU
  • Bluetooth
  • Bluetooth Protocol: Bluetooth 5, Bluetooth mesh
  • Bluetooth Frequency: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
  • IEEE 802.15.4
  • Compatible with IEEE 802.15.4-2015 protocol
  • Frequency band: 2.4GHz
  • Data rate: 250Kbps
  • Supports Thread 1.3 and Zigbee 3.0
  • Ports
  • Digital I/O x19
  • LED PWM 6 Channel
  • SPI x1
  • UART x3 (LP UART x1)
  • I2C x2 (LP I2C x1)
  • I2S x1
  • IR Transceiver: transmit channel x2, receive channel x2
  • 1 × 12-bit SAR ADC, 7 Channel
  • DMA Controller: transmit channel x3, receive channel x3
  • FireBeetle 2 Board ESP32 C6 Microcontroller x1
  • 20pin-2.54mm Pin Header x2
    Non-Contact Temperature Sensors, How Do They Work?
    Projects Non-Contact Temperature Sensors, How Do They Work?
    Mellow_Labs
    Sep 30, 2025
    FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Blog FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Jul 15, 2025
    FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Blog FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
    Jun 08, 2025
    FireBeetle 2 ESP32-C6: The Ultimate Controller for Your Smart Home Projects
    Blog FireBeetle 2 ESP32-C6: The Ultimate Controller for Your Smart Home Projects
    Jul 02, 2024
    Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
    Sep 25, 2023
    ESP32 DIY Smart Menu for Coffee Cafe
    Projects ESP32 DIY Smart Menu for Coffee Cafe
    Yakroo108
    Aug 22, 2024
    Jan.Holtzhausen Feb 23, 2026
    Nearly done with the code for a cat flap monitor to keep that $%^&*( ginger tom cat from terrorizing my precious moggies. https://github.com/janholtzhausen/esp32p4-catflapmonitor
    David. Feb 09, 2026
    I'm testing this with several student projects.
    nick.cole Jan 05, 2026
    greatest board ever made
