This is an exceptional water-resistant digital servo with impressive torque. It boasts a torque capacity of 35kg and a controllable angle of 180 degrees. It exhibits superior linear motion and features an internal configuration of steel gears, with the gear axis thickened to an optimized 2.0 center distance. The dual ball bearing design ensures smooth operation, while the aluminum casing enhances heat dissipation capability, thereby extending its lifespan.
Additionally, this servo is equipped with electronic and temperature protections, ensuring a safer user experience. In the event of a servo lock-up, it automatically triggers a protective torque output when the torque exceeds the overload capacity for a continuous period of 8 seconds. Moreover, should the servo's temperature surpass 70 degrees, it ceases torque output, only to resume once the temperature drops below 70 degrees.
To enhance its water resistance, the servo's joints are fortified with waterproof gaskets, and the circuit board is coated with a waterproof varnish. Both the motor and the potentiometer are sealed with a specialized adhesive. These measures contribute to the servo's exceptional waterproof capabilities. Moreover, this servo is accompanied by a selection of different-shaped servo horns, enabling its application in a wider range of environments.
Interface Definition Diagram
Dimensional Diagram
Electrical characteristics
Control characteristics
Mechanical specifications
Other parameters
