11.6 Inch 1920x1080 FHD eDP Touch Display for LattePanda IOTA / Mu / Sigma / 3 Delta / 2 Alpha
$129.00
SKU: FIT0955
  • $126.00 3+ items
  • $123.00 5+ items
  • $119.00 10+ items
11.6-inch FHD eDP touch display with 1920x1080 resolution. Features include multi-touch, ultra-thin bezel, wide viewing angle, and compatibility with specific single-board computers.
Purchase this product and earn 1290 reward points, which are tied to VIP membership program. Learn More >
This 11.6-inch FHD eDP touch display features a high-definition resolution of 1920x1080 and an ultra-thin, ultra-narrow bezel design. It is perfect for HMI and Portable Projects. The display has a full-view design and multi-touch functionality that enhance user interaction. It is compatible with LattePanda IOTALattePanda Mu / LattePanda Sigma / LattePanda 3 Delta / LattePanda 2 Alpha / LattePanda 2 Delta single-board computers.
High Definition Display
The touch display offers a high-definition resolution of 1920x1080, providing an ultimate visual experience. Whether watching videos or processing images, users can experience unparalleled clarity and color saturation. eDP screens, with their advantages of high-speed transmission, high-resolution support, and scalability, are widely used in various displays, including portable devices, human-machine interaction interfaces, and industrial control panels. With the continuous development of the industrial sector, eDP screens will continue to play a significant role, bringing higher efficiency and visual effects to the industry.
11.6-inch eDP touch display features
Ultra-thin and ultra-narrow bezel design
This screen boasts an ultra-thin and ultra-narrow bezel design, offering an exceptional visual experience. Its ultra-thin thickness contributes to a lighter screen, while the extremely narrow bezel design provides a broader field of view and a deeply immersive viewing experience.
Wide Viewing Angle and Multi-touch
This screen features a full-view design, ensuring clear images and true colors from any angle. In addition, its multi-touch functionality allows users to perform various operations more intuitively, enhancing the user experience.
Best Compatibility
Unlike other normal HDMI screens, this display uses an eDP interface and has the best compatibility with LattePanda IOTA / LattePanda Mu / LattePanda Sigma / LattePanda 3 Delta / LattePanda 2 Alpha / LattePanda 2 Delta.
How to Install the 11.6-inch FHD eDP touch display and LattePanda
Figure: How to Install the 11.6-inch FHD eDP touch display and LattePanda
Note: Please refer to the instruction sticker at the back of the screen for proper screen connection.
Installation Video
  • High-quality display with vivid and accurate color reproduction
  • Wide viewing angle for enhanced visibility from different perspectives
  • Multi-touch functionality for intuitive interaction
  • Compact design for easy integration into various projects
  • Versatile applications in human-machine interface (HMI) and portable projects
  • Size: 11.6-inch
  • Interface: eDP (DP) + I2C (TP)
  • Resolution: 1920x1080
  • Panel Type: IPS
  • Color Gamut: 68% Typ.@CIE1931
  • View Direction: Full View
  • Pixel Pitch: 0.1335(H) × 0.1335 (V) mm
  • Pixel arrangement: RGB Vertical stripe
  • Display Area: 256.320 (H) × 144.180(V) mm
  • Backlight Type: LED
  • Brightness: 350cd/m2 (Max)
  • OS Support: Windows/Linux
  • Operating Temperature: -10 ~ +60 ℃
  • Storage temperature: -20 ~ +70 ℃
  • Weight: 431g (bare screen)
  • Dimension (W x H x D): 267x159x8.8mm
  • 11.6-inch eDP touch display x1
  • Ribbon Cable pack:
  • 30cm 40P to 30P 0.5mm Coaxial EDP Screen Cable (For LattePanda Mu/ Sigma) x1
  • 34cm Opposite-Side Touch cable (For LattePanda Sigma) x1
  • 34cm Same-Side Touch cable (For LattePanda Mu) x1
  • 22cm eDP FPC cable (For LattePanda IOTA/ 3 Delta/ 2 Alpha) x1
  • 21cm Opposite-Side Touch cable (For LattePanda IOTA/ 3 Delta/ 2 Alpha) x1
    Andrew.Wickens Jan 24, 2026
    Excellent display for compact x86 and handheld projects. The screen is sharp, bright, and very clear at 1080p, and the touch response is accurate and smooth. Works perfectly over eDP with LattePanda boards, with no scaling or compatibility issues. Build quality is good and it’s ideal for custom tablets, handheld PCs, or compact all-in-one systems.
    Elwyn. Aug 30, 2025
    Screen is crisp with very clear imaging. Very happy with this item.
