OpenMV Cam RT1060 Camera for Machine Vision
$130.00
SKU: DFR1082
A compact microcontroller board with a camera, supporting machine vision applications via Python scripts. Features include USB, WiFi, Bluetooth, and various I/O interfaces.
Purchase this product and earn 1300 reward points, which are tied to VIP membership program. Learn More >
OpenMV Cam RT1060 is a compact, low-power microcontroller board with camera, facilitates the seamless implementation of real-world applications using machine vision. Programming of the OpenMV Cam is accomplished through high-level Python scripts, courtesy of the MicroPython Operating System, as opposed to C/C++. This approach simplifies the handling of complex outputs from machine vision algorithms and the manipulation of high-level data structures. Despite this, total control over the OpenMV Cam and its I/O pins remains within reach through Python. Triggering of picture-taking and video recording based on external events is straightforward, as is the execution of machine vision algorithms to manage I/O pin control.
Pinout of OpenMV Cam
The RT1062 ARM Cortex M7 processor running at 600 MHz with 32MBs SDRAM + 1MB of SRAM and 16 MB of program/storage flash. All I/O pins output 3.3V and are 3.3V tolerant. The processor has the following I/O interfaces:
  • A high-speed USB-C (480Mbs) interface to computer. OpenMV Cam will appear as a Virtual COM Port and a USB Flash Drive when plugged in
              1.5A current limited
              With EMI Filtering and TVS protection
  • A μSD Card socket capable of 25MB/s reads/writes which allows your OpenMV Cam to take pictures and easily pull machine vision assets off of the μSD card.
  • A SPI bus that can run up to 60Mb/s allowing you to easily stream image data off the system to either the LCD Shield or another microcontroller
  • An I2C Bus (up to 1Mb/s), CAN Bus (up to 1Mb/s), and an Asynchronous Serial Bus (TX/RX, up to 20Mb/s) for interfacing with other microcontrollers and sensors
  • A 12-bit ADC (3.3V Tolerant)
  • Three I/O pins for servo control
  • One I/O pin for frame sync/triggering (or servo control)
  • An onboard RTC which keeps running when the system is in low-power mode (the system draws less than 30uA in low-power mode)
              One I/O pin for low power wake up
              There is also a pin for device power button ON/OFF support
  • Interrupts on all I/O pins (there are 14 I/O pins on the board)
  • A user controllable/dimmable RGB LED
  • Another RGB LED for Charging, USB Power, VIN Power indication
  • 32 MB of external 16-bit SDRAM clocked at 160 MHz for 320 MB/s of bandwidth
  • 16 MB of program/storage quad SPI flash clocked at 133 MHz in 4-bit SDR mode for 66 MB/s of bandwidth (read speed)
  • A 12-bit X/Y/Z accelerometer (2/4/8g) centered underneath the camera module
  • Onboard WiFi (a/b/g/n - 11/54/65 Mb/s) and Bluetooth (v5.1 - BR/EDR/BLE) module with a chip antenna
              Option to use a U.FL antenna instead
  • Onboard 10/100 Mb/s Ethernet
              Ethernet Jack with PoE support via an external shield
  • Strong Cryptographic Authentication Secure Element support via the SE050C1HQ1
    A removable camera module system allowing the OpenMV Cam RT1062 to interface with different sensors:
  • The OpenMV Cam RT1062 comes with an OV5640 image sensor that is capable of taking 2592x1944 (5MP) images. Most simple algorithms will run about 40 FPS on QVGA (320x240) resolutions and below. If you want to use more specialized lenses with your image sensor you can easily buy and attach them yourself
    A LiPo battery connector compatible with 3.7V LiPo batteries commonly sold online for hobbyist robotic applications with battery charging support via USB
  • 100 mA Fast Charge Current
  • With TVS Protection
    An ARM 10-pin JTAG Header Compatible with SEGGER J-Link Devices for debugging and programming
  • With EMI Filtering and TVS protection
    External 5V VIN with reverse supply protection
  • Robotics
             Robot navigation
             Object tracking
             Collision avoidance, and more.
  • Security Systems
             Motion detection
             Face recognition
  • Industrial Automation
             Quality control
             Sorting
  • Machine vision
  • Processor
             ARM® 32-bit Cortex®-M7 CPU w/ Double Precision FPU
             600 MHz (1284 DMIPS)
             Core Mark Score: 3020 (compare w/ Raspberry Pi 3: 3800)
  • RAM Layout (33MB Total)
             32KB Stack
             480KB .DATA/.BSS/Heap/DMA
             32MB Frame Buffer/Stack
             512KB SDRAM Cache
  • Flash Layout (4MB Total)
             256KB Bootloader
             3.768MB Firmware
             4MB Embedded Flash Drive
  • Supported Image Formats
             Grayscale
             RGB565
             JPEG (and BAYER/YUV422)
  • Maximum Supported Resolutions
             Grayscale: 2952x1944 (5MP) and under
             RGB565: 2952x1944 (5MP) and under
             Grayscale JPEG: 2952x1944 (5MP) and under
             RGB565 JPEG: 2952x1944 (5MP) and under
  • Lens Info
             Focal Length: 2.8mm
             Aperture: F2.0
             Format: 1/3"
             HFOV = 70.8°, VFOV = 55.6°
             Mount: M12*0.5
             IR Cut Filter: 650nm (removable)
  • Electrical Info
             All pins are 3.3V tolerant with 3.3V output. All pins can sink or source up to 4mA. VIN may be between 3.6V and 5V. Do not draw more than 250mA from your OpenMV Cam's 3.3V rail.
  • Power Consumption
             Idle: 100mA @ 5V
             Active: 130mA @ 5V
  • Storage Temperature: -25°C to 85°C
  • Operating Temperature: 0°C to 70°C
  • OpenMV Cam RT1062 Development Board X 1
  • Only 15 Left
