Aluminum M.2 2280 Solid-state Drive Heat Sink (Compatible with LattePanda Sigma)
$11.90
SKU: FIT0969
  • $11.60 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
All-aluminum M.2 SSD heatsink with silicone gasket, adjustable screws, and nano silicone pads, offering cooling up to 30°C for various SSD heights.
This is an all-aluminum M.2 solid-state drive radiator. The aluminum alloy slot design greatly increases the heat dissipation area, which can cool the M.2 solid-state drive to a safe temperature and avoid overheating. Depending on the environment, the cooling effect can reach 10°C to 30°C.
The Structure of M.2 2280 SSD Heat sink
The radiator is equipped with a silicone gasket with a heat dissipation performance of up to 14.8w/m.k. It adopts a full electroplating reflow soldering process. The pure aluminum electroplated passive fin group and pure aluminum electroplated base provide excellent heat dissipation performance. The heat dissipation area reaches 4500mm² and uses a single tube and double joints. Welding machine technology provides the ultimate cooling experience.
M.2 2280 SSD Heat sink with 4 height-adjustable screws
The radiator adopts a double-sided clamp design and is equipped with 4 height-adjustable screws, which is suitable for M.2 SSD of various heights, ensuring stable installation and better protecting M.2 SSD.
Overview of M.2 2280 SSD Heat sink
The radiator also uses advanced heat-conducting pads, made of nano silicone grease material, which has good thermal conductivity. The gasket is soft and malleable enough to be compatible with the uneven slopes of the M.2 SSD surface, and the low-viscosity design will not damage the SSD warranty label.
  • Aluminum alloy
  • With thermal conductive silicone sheet
  • Compatible with 2280 SSD
  • Thermal conductive heat pipe + passive fin structure, strong heat dissipation ability
  • Size: L79 * W24 * H43.5mm
  • Weight: 80g
  • Fin specifications: thickness = 0.4mm, spacing = 1.8mm
  • Number of fins: 32pcs
  • Catheter diameter: 6mm
  • M.2 2280 SSD Heat sink x1
  • Review
    Elwyn. Aug 30, 2025
    Heat sinks work well keeping ssd a lot cooler. Very happy with them.
    Only 15 Left
