M.2 M Key to SATA3.0 Expansion Board (Compatible with LattePanda Sigma)
$25.00
SKU: FIT0970
  • $24.00 3+ items
  • $23.50 5+ items
  • $23.00 10+ items
An M.2 M Key to SATA3.0 expansion board offering 5 SATA interfaces, plug-and-play functionality, real-time indicators, and aluminum heat sink for stable performance.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
This is an M.2 M Key to SATA3.0 expansion board specially prepared for LattePanda Sigma users. it requires no driver installation and is plug and play. It has high-speed transmission and stable performance. SATA3.0 interface can be utilized for connecting SATA devices, such as optical drives, Solid State Drives (SSD), Hard Disk Drives (HDD), and Solid State Hybrid Drives (SSHD). The expansion card comes with 5 SATA interfaces and can be used with the sigma motherboard to connect external SATA interface hard drives to provide Sigma with more data storage space.
M.2 M Key to SATA3.0 Expansion Card use JMB585 chip
The expansion card is equipped with an indicator light. When the corresponding SATA device is connected, the indicator light will light up; when data is read or written, the indicator light will flash, allowing you to observe the status of the expansion card and hard disk in real time.
M.2 M Key to SATA3.0 Expansion Card equipped with an indicator light
In order to enhance operational stability, the chip is also equipped with an aluminum alloy heat sink to provide better heat dissipation.
M.2 M Key to SATA3.0 Expansion Card equipped with an aluminum alloy heat sink
Wiring Diagram of M.2 M Key to SATA3.0 Expansion Card and LattePanda Sigma
  • With 5 SATA3.0 interfaces
  • With heat sink, the performance is more stable
  • With indicator light to check status in real time
  • Compatible with multiple systems
  • Transmission protocol: PCIe 3.0x2, supports up to two channels of PCIe XPRESS
  • Compatibility: Hard drives that support SATA protocol
  • Speed: Uplink PCIe 3.0 X2 16Gbps, Downlink SATA3.0 6Gbps*5
  • Number of extensions: SATA3.0*5
  • Compatible systems: Windows/Linux/Mac os
  • Size: 22*80mm
  • M.2 M Key to SATA3.0 Expansion Card x1
  • M.2 M Key to SATA3.0 Expansion Board (Compatible with LattePanda Sigma)
