Aluminum Active Cooler for LattePanda Mu Compute Module
$12.00
SKU: FIT0981
  • $11.70 3+ items
  • $11.50 5+ items
  • $11.00 10+ items
The Mu Active Cooler for Mu compute module ensures stable temperature with low-noise fan and efficient heat dissipation. Compatible only with Mu model.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
The LattePanda Mu Active Cooler is a high-quality cooler designed specifically for the LattePanda Mu compute module. It allows for perfect integration between LattePanda Mu and the carrier board, enabling you to freely build various DIY projects. This low-noise fan ensures stable temperature for your LattePanda Mu, and the heat dissipation fins quickly absorb the heat generated by the CPU. This simple yet effective method keeps your LattePanda Mu in its best condition at all times! The aluminum alloy housing has excellent thermal conductivity and comes with high-quality phase change materials for even better heat dissipation performance.
Installation steps:
1. Remove the three spring screws of the Active Cooler and peel off the phase change material protective film.
2. Align the CPU of the LattePanda Mu with the phase change material of the Active Cooler and align the screw holes.
3. Tighten the three spring screws in a circular motion until the installation is complete.
Be careful not to fully tighten one screw before loosening another, as it may cause damage to the CPU chip due to uneven force.
Note: Compatible solely with the LattePanda Mu model.
1. This model is an active cooler with a heatsink.
2. When installing or removing the cooler, the LattePanda Mu must be powered off.
3. During use, please avoid direct contact between your skin and the case to prevent burns.
Aluminum Active Cooler and LattePanda Mu Compute Module
  • All-metal material
  • Wall-mounted
  • Active cooling aluminum alloy heatsink
  • Double ball bearing fan
  • Aluminum alloy material, corrosion-resistant and durable
  • Compatible motherboard: LattePanda Mu
  • Operating voltage: 5V
  • Operating current: 0.35A
  • Maximum rotational speed: 4000 RPM
  • Wire length: 105mm
  • Interface type: PH2.0-4P
  • Dimensions: 69.6 * 50.4 * 19mm
  • Material: Aluminum alloy
  • Weight: 69g
  • LattePanda Mu Active Cooler x1
    AI-driven LoRa & LLM-enabled Drive-through Kiosk & Food Delivery System
    Projects AI-driven LoRa & LLM-enabled Drive-through Kiosk & Food Delivery System
    Kutluhan Aktar
    Sep 30, 2025
    PixelPanda: a 3D Printed RGB Matrix PC Build
    Projects PixelPanda: a 3D Printed RGB Matrix PC Build
    Mukesh Sankhla
    Jun 18, 2024
    Duane.Cree Mar 17, 2026
    Very quite until put on a demanding game but still isnt very noticable
    Craig.Pruitt Mar 13, 2026
    Love this little cooler. Works great on n100 cpu. Gonna try it on a N305 soon hopefully :)
    Andrew.Wickens Jan 24, 2026
    Well-designed active cooler for high-load use. This cooler provides excellent thermal performance on the LattePanda Mu when running sustained workloads. The fan is quiet, airflow is effective, and the low-profile design fits neatly into compact enclosures. Installation is quick and the overall build quality is very good.
    Only 14 Left
