UNIHIKER M10 IoT Single Board Computer with Black Silicone Case
$62.90
SKU: DFR0706-EN-5
A compact single-board computer with a 2.8-inch touchscreen, Wi-Fi, Bluetooth, sensors, and Python support. Comes with a silicone case for durability.
Purchase this product and earn 629 reward points, which are tied to VIP membership program. Learn More >
This package includes a UNIHIKER M10 single-board computer and a Silicone Case (Black) designed to enhance durability and reduce screen breakage.
UNIHIKER is a single-board computer that brings you brand new experience. It features a 2.8-inch touchscreen, Wi-Fi and Bluetooth. It is equipped with light sensor, accelerometer, gyroscope and microphone. With built-in co-processor, it is able to communicate with various analog/digital/I2C/UART/SPI sensors and acuators.
UNIHIKER brings a whole new experience for developers with its pre-installed software, allowing for an incredibly fast and easy start. Featuring a built-in Jupyter Notebook (a browser-based programming environment), developers can program the single board computer using a smartphone or tablet.
Of course, just like other single board computers, UNIHIKER supports VS Code, VIM, and Thonny. The integrated PinPong control library allows developers to directly control UNIHIKER's built-in sensors and hundreds of connected sensors and actuators using Python.
The built-in SIoT service on UNIHIKER allows users to store data through the MQTT protocol and provides real-time web data access. The best part is that all data is stored within the device itself.
Compact, feature-rich, and user-friendly, UNIHIKER offers an innovative development experience for learning, coding, and creating. Unleash your imagination and embark on a new journey with UNIHIKER.
UNIHIKER Single Board Computer brings brand new experience
Built-in 2.8-inch Touch Screen
Enables you to visualize sensor data in the form of charts, graphs, and even dynamic animations.
UNIHIKER Built-in 2.8-inch touchscreen
Incredibly Fast and Easy Start
UNIHIKER Incredibly fast and easy start
Using Python to Sense and Control
UNIHIKER Using Python to sense and control
Built-in IoT service
UNIHIKER Built-in IoT service
Can be Programmed Wirelessly
UNIHIKER can be programmed from a computer, an iPad, even a phone.
It also supports Hotspot, you can play it from anywhere.
UNIHIKER Can be Programmed Wirelessly
Supports Popular Coding Software
UNIHIKER Supports Popular Coding Software
Rich Interfaces and High Expandability
UNIHIKER Rich Interfaces and High Expandability
UNIHIKER Key Features
Recommended Accessories:
2x3A DC Motor Driver Carrier Board for UNIHIKER
Expand the capabilities of the UNIHIKER with this motor driver carrier board, featuring a dual DC motor drive, RGB lights, and infrared transmission/reception. It offers flexible power supply options and extensive I/O and I2C port expansion.
  • AIoT
  • Robot
  • STEM
  • Unihiker Application: AIoT, Robot, STEM
  • CPU: Quad-Core ARM Cortex-A35, up to 1.2GHz
  • RAM: 512MB
  • Flash: 16GB
  • OS: Debian
  • Wi-Fi: 2.4G
  • BT: Bluetooth 4.0
  • Screen: 2.8inch, 240×320, Touch Screen
  • MCU: GD32VF103
  • Sensor: Button, Microphone, Light Sensor, Accelerometer Sensor, Gyroscope Sensor
  • Actuator: Led, Buzzer
  • Port: USB Type-C, USB-A, Gravity 3pin&4pin port, Edge connector
  • Power: 5V 2A for USB Type-C
  • Size: 51.6mmx83mmx13mm
  • UNIHIKER M10 Single Board Computer x1
  • Silicone Case for UNIHIKER Single Board Computer M10 (Black) x1
  • Type-C USB cable x1
  • Double Sided PH2.0-3P white 20cm silicone wire x4
  • Double Sided PH2.0-4P white 20cm silicone wire x2
  • FAQ
