The ESP32-S3 AI Camera is a cutting-edge intelligent camera module built around the high-performance ESP32-S3 chip, designed for efficient video processing, edge AI, and voice interaction. Featuring a wide-angle infrared camera, onboard microphone, and speaker, it is ideally suited for applications such as electronic peepholes, baby monitors, and license plate recognition. With powerful AI processing capabilities, it integrates seamlessly into IoT ecosystems, supporting edge image recognition and online AI model interaction through Wi-Fi connectivity, making it an essential component for IoT applications, from security surveillance to AI assistants.
Intelligent AI Processing and Edge Computing
The ESP32-S3 AI CAM utilizes the powerful neural network capabilities of the ESP32-S3 chip for edge-based image recognition with platforms like Edge Impulse, YOLOv5, and OpenCV. It supports efficient on-device processing for tasks such as object detection and image classification, while integration with ChatGPT enables voice-controlled command execution. This combination of local AI processing and cloud-based model access makes the module ideal for a wide range of IoT applications.
To ensure easy integration, the ESP32-S3 AI CAM comes with extensive tutorials, documentation, and sample code:
Build camera-and-audio prototypes with fewer separate modules. Local inference depends on the model and firmware deploy; cloud AI services require a network connection, credentials and any applicable service fees. On hardware V1.1, the Gravity 3.3V pin is a power output, not a power input. Use the documented USB or VIN power connection.
Integrated Voice Interaction for Enhanced Usability
The onboard microphone and amplifier support voice recognition (ASR) and interactive dialogue powered by ChatGPT, enabling intuitive voice commands and real-time interaction. This integration allows for smart automation in IoT devices, simplifying control and enhancing user experience. With voice recognition capabilities, the ESP32-S3 AI CAM opens up possibilities for voice-activated smart assistants, AI-controlled surveillance, and hands-free device management.
Night Vision for All-Day Monitoring
Equipped with a 160° wide-angle infrared camera and infrared illumination, the ESP32-S3 AI CAM ensures exceptional image quality even in low-light or complete darkness. The module’s light sensor further enhances adaptability, making it an ideal choice for 24/7 monitoring in applications like baby monitoring, security surveillance, and smart home systems. Its ability to perform in all weather and lighting conditions makes it a reliable solution for around-the-clock surveillance.
Build a Smart Baby Monitor:
Also Great For: Security Camera, Pet Monitor, Doorbell
Wireless Transmission Support: Wi-Fi & BLE 5
The ESP32-S3 AI Camera Module is equipped with Wi-Fi and BLE 5 connectivity, enabling seamless remote monitoring from your mobile devices or other connected equipment. Whether you're at home or on the go, you can easily access live video feeds and manage your monitoring system remotely. This wireless transmission capability expands the flexibility of the module, making it an ideal solution for applications requiring real-time surveillance and control, such as home security and smart automation.
Basic Parameters
Functional Indicators
Camera Specifications
Nov 08, 2025
An amazing all-in-one AI camera module! The ESP32-S3 AI Camera is compact yet extremely powerful for edge computing projects. The image recognition and face detection are fast and reliable, even under low light thanks to the built-in night-vision LEDs. Voice interaction with ChatGPT or other LLMs works surprisingly well once configured. It’s easy to program with ESP-IDF or Arduino, and perfect for IoT, robotics, or smart monitoring systems. A great choice for anyone exploring AI vision or real-time image analysis at the edge!
Jul 03, 2026
These are great esp32-s3 AI boards . The only downfall is that it would be great if there were at least a couple of gpio ports to add a couple devices . But the functionality is great and a nice compact design . I would also like to say the customer support is excellent one board would not connect to PC via USB and they were quick to resolve the issue and send a replacement. Thank you DFRobot . I will be purchasing more from you.
Dec 13, 2025
The ESP32‑S3 AI Camera Module is a powerful, flexible board for builders and makers who want vision, AI recognition, voice interaction, and wireless connectivity all in one. Its blend of edge AI, night vision, and ChatGPT‑powered voice interaction gives it a distinct advantage over simpler camera modules — especially for smart security, interactive automation, and IoT projects.
