Gravity: Offline Edge AI Gesture & Face Detection Sensor – 5 Gestures, 10 Faces, 3m (Arduino/ RPi/ ESP32)
$14.90
SKU: SEN0626
The sensor enables offline AI gesture and face detection, recognizing 5 hand gestures and up to 10 faces within 3 meters, ensuring privacy without cloud use.
The Gravity: Offline Edge AI Gesture & Face Detection Sensor is designed for intuitive gesture control and multi-person presence detection. Equipped with an integrated camera and onboard AI processor, the sensor can recognize 5 predefined hand gestures and detect up to 10 faces or upper-body presences simultaneously within a 3-meter range. By combining computer vision and real-time edge AI computing, it delivers responsive and private interaction without cloud dependency.
Featuring dual communication interfaces (I2C and UART) and wide voltage support (3.3V–5V), this module is fully compatible with Arduino, Raspberry Pi, ESP32 and graphical platforms like MakeCode and Mind+. It is ideally suited for smart home interfaces, touchless control systems, public interaction devices, and privacy-focused IoT solutions.
Edge AI Processing – Real-Time, Offline, and Privacy-Safe
All recognition tasks are handled by the onboard AI processor—no data is ever stored or transmitted to the cloud. This completely offline operation guarantees data privacy, making it ideal for sensitive applications in healthcare, public spaces, or homes. Despite its powerful capabilities, the offline AI gesture Sensor has a low operating current of just 100mA, making it perfect for power-sensitive and standalone projects.
Edge AI Processing – Real-Time and Offline
Figure: Edge AI Processing – Real-Time and Offline
Recognizes 5 Intuitive Hand Gestures
The offline AI gesture & face detection sensor accurately recognizes five common hand gestures from 0.5 to 3 meters away. Each recognized gesture triggers a corresponding colored RGB light, providing instant visual feedback for seamless interaction. This makes it perfect for contactless control of smart appliances, interactive installations, and assistive devices.
The 5 recognized gestures are: Good (Thumbs-up, Blue light), OK (OK gesture, Green light), Stop (Open palm, Red light), Victory (V sign, Yellow light), Call me (Call me gesture, Purple light)
Face & Upper-Body Detection with Real-Time Data
Beyond gestures, the offline AI gesture & face detection sensor excels at detecting human presence by identifying the head-and-shoulders area. It can track up to 10 people simultaneously and outputs the total count in real-time. For more advanced applications, it provides the position coordinates (X/Y) and confidence score of the most clearly detected face. This enables sophisticated functions like occupancy-based climate control, people-counting for retail analytics, or a fan that automatically tracks a person's position.
Wide Detection Range with Optimized Field of View
With an 85° diagonal field of view and a 3-meter detection range, the long-range AI gesture & face detection sensor ensures consistent and reliable performance in a variety of environments. Whether mounted on a wall, integrated into a device, or placed on a desk, its wide coverage is ideal for everything from small rooms to larger, multi-user spaces like classrooms or lobbies.
  • Offline AI Processing: Fast, accurate, and private recognition performed entirely on the device.
  • 5 Predefined Hand Gestures: Recognizes Good (Thumbs-up), OK (OK gesture), Stop (Open palm), Victory (V sign), and Call me (Call me gesture).
  • Face & Upper-Body Detection: Reliably detects human presence and can count up to 10 individuals simultaneously.
  • Rich Data Output: Provides face count, X/Y position coordinates, and confidence scores for advanced applications.
  • Dual Communication Interfaces: Flexible integration using either I2C or UART (Modbus-RTU).
  • Wide Voltage Compatibility: Works seamlessly with both 3.3V and 5V systems.
  • Graphical Programming Support: Compatible with platforms like MakeCode and Mind+.
  • Integrated Visual Feedback: Features distinct RGB and LED indicators for gesture and face detection status.
  • Contactless smart home controls (e.g., gesture-controlled lighting, fans, media players)
  • Interactive public displays and advertising kiosks
  • Assistive technology for healthcare and elder care settings
  • Occupancy and people-counting systems for smart buildings
  • Creative projects and interactive art installations (e.g., the Dazzling LED Ring project)
  • Robotics projects (e.g., the Face-Tracking Fan project)
    Power Specifications
  • Supply Voltage: 3.3V - 5V
  • Level Voltage: 3.3V
  • Operating Current: 100mA
  • Interface Parameters
  • Communication Interface: PH2.0-4P / 2.54mm pin header
  • Communication Methods: I2C / UART
  • Default I2C Address: 0x72
  • Default UART Baud Rate: 9600
  • UART Protocol: Modbus
  • Interrupt Interface: 2.54mm pin header hole (Low level output on gesture recognition)
  • Recognition Parameters
  • Gesture Recognition Types: 5, Good (Thumbs-up) / OK (OK gesture) / Stop (Open palm) / Victory (V sign) / Call me (Call me gesture)
  • Recognition Distance (Gesture/Face): 0.5 - 3 meters
  • Facial Recognition Range: Area above the human shoulders
  • Maximum Recognizable Faces: 10
  • Recognition Score Range: 0 - 100
  • Facial Position Coordinate Range: 0 - 640
  • Display Parameters
  • Gesture Indicator Light: RGB LED - Blue for Good (Thumbs-up), Green for OK (OK gesture), Red for Stop (Open palm), Yellow for Victory (V sign), Purple for Call me (Call me gesture)
  • Facial Indicator Light: Single LED (lit for presence, unlit for no presence)
  • Mechanical Dimensions
  • PCB Dimensions: 42mm * 32mm
  • Mounting Hole Spacing: 25mm * 35mm
  • Mounting Hole Diameter: 3.1mm
  • Gravity: AI Gesture & Face Detection Sensor ×1
  • Gravity-4P I2C/UART Sensor Cable ×1
    Juan.Navarro Jan 28, 2026
    It was a very simple purchase, the treatment was very friendly and the delivery was very fast, thank you
    Judy.Lee Jul 03, 2025
    i got it well. the shipping was so fast and delivery status was very good.
