25m Long Distance ToF Laser Sensor (±3cm Accuracy, 100Hz, 100K LUX Resistant)
$25.00
SKU: SEN0647
  • $24.00 3+ items
  • $23.50 5+ items
  • $23.00 10+ items
A laser distance sensor for precise 25m measurements with ±3cm accuracy and 100Hz refresh rate. Supports UART/I2C and is ideal for automation and drones.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
The TOFSense F2 is a high-performance, mid-range laser distance sensor based on dTOF (Direct Time-of-Flight) technology, offering precise measurements up to 25m (±3cm) at a rapid 100Hz refresh rate. Compatible with Raspberry Pi, Arduino, and ESP32 via UART/I2C interfaces, it seamlessly integrates into industrial automation, drones, AGVs, and smart traffic systems. Engineered for robustness, its 100K LUX ambient light resistance ensures reliable operation in outdoor and high-interference environments, while multi-interface support (UART/I2C/GPIO) enables flexible integration with microcontrollers, PLCs, and sensor fusion setups.
Features of ToF laser ranging sensor
Figure: Features of ToF laser ranging sensor
25m Mid-Range Detection with ±3cm Accuracy
The TOFSense F2 provides high-precision distance measurements up to 25m, making it ideal for industrial automation (e.g., conveyor belt tracking, bin level monitoring) and robotic navigation (e.g., AGV obstacle avoidance). With ±3cm accuracy and 1mm resolution, it ensures reliable data for positioning, object counting, and smart traffic systems.
100Hz High-Speed Data for Real-Time Control
With a 100Hz refresh rate, the F2 delivers instantaneous distance updates, critical for fast-moving applications like drone stabilization, dynamic robot path planning, and vehicle speed detection. Unlike slower 50Hz sensors, it minimizes latency in time-sensitive operations.
100K LUX Ambient Light Resistance
Engineered for outdoor and industrial environments, the F2 maintains stable performance under direct sunlight (100K LUX) and artificial lighting. This makes it suitable for smart traffic monitoring, outdoor drones, and construction site automation where lighting conditions vary.
Multi-Interface Support (UART / I2C / I/O)
The F2 supports UART, I2C, and I/O interfaces, offering flexible connectivity for microcontrollers, PLCs, and custom hardware. The I/O trigger function allows synchronization with cameras or other sensors, making it ideal for multi-sensor fusion systems.
Dimensions of ToF laser ranging sensor
Figure: Dimensions of ToF laser ranging sensor
Note: The cable colors included with this product correspond to the power supply as follows: RED->GND, Black->VCC. Please carefully check the power connections before proceeding.
  • AGV & Robot Navigation
  • Warehouse Automation & Inventory Tracking
  • Drone Altitude Stabilization
  • Smart Traffic & Parking Systems
  • applications of ToF laser ranging sensor
  • Refresh Rate: 100 Hz
  • Ranging Range: 0.05–25 m
  • Ranging Accuracy: ±3 cm
  • Wavelength: 905 nm
  • Ambient Light Resistance: Up to 100,000 lux
  • Field of View (FOV): 1–2°
  • Power Supply: 4.3–5.2 V DC
  • Power Consumption: 250 mW (typical)
  • Communication Interface: UART / I2C / GPIO
  • I2C Default Address: 0x80
  • Operating Temperature: -10°C to +60°C
  • Dimensions (L×W×H): 22.7 × 28.0 × 13.6 mm
  • Weight: 7.5 g
  • ToF laser ranging sensor-25m x1
  • Wiring x2
    Andree.Salazar Nov 16, 2025
    For mis first buying experience all good.
    Out Of Stock
