50m TOF Laser Ranging Sensor (±3cm Accuracy, 100Hz, 100K LUX Resistant)
$29.00
SKU: SEN0648
  • $28.00 3+ items
  • $27.50 5+ items
  • $27.00 10+ items
A long-range laser sensor with 50m detection, ±3cm accuracy, and 100Hz refresh rate. Compatible with Raspberry Pi, Arduino, and ESP32, ideal for outdoor use.
The TOFSense F2P is a professional-grade, long-range laser sensor leveraging dTOF (Direct Time-of-Flight) technology to achieve 50m ranging (±3cm accuracy) with 100Hz refresh rate, engineered for mission-critical outdoor and industrial applications like drone terrain mapping, highway traffic monitoring, and large-scale 3D scanning. Compatible with Raspberry Pi, Arduino, and ESP32 via UART/I2C interfaces, it offers plug-and-play integration for robotics, smart infrastructure, and automation systems. Built to withstand extreme conditions, its 100K LUX ambient light resistance ensures robust performance in direct sunlight, while multi-interface support (UART/I2C/GPIO) enables seamless synchronization with cameras, PLCs, and sensor arrays.
Features of ToF laser ranging sensor
Figure: Features of ToF laser ranging sensor
50m Long-Range & ±3cm High Precision
The TOFSense F2P delivers best-in-class 50m detection capability, making it ideal for demanding applications like drone altitude hold, terrain mapping, and traffic monitoring. With ±3cm accuracy across its entire range, it ensures reliable measurements even at maximum distance, while its 1mm resolution enables fine-detailed tasks such as stockpile volume scanning and industrial inventory management. This combination of long-range and high precision sets it apart for professional-grade deployments where distance and reliability are critical.
100Hz High-Speed Refresh Rate
With an ultra-fast 100Hz refresh rate, the F2P provides real-time responsiveness for dynamic environments. This high-speed data output is essential for drone obstacle avoidance systems that require instantaneous reaction times, as well as smart traffic applications where accurate vehicle speed tracking and parking detection are crucial. The rapid updates ensure seamless performance in fast-moving scenarios, giving users a competitive edge in time-sensitive operations.
Unmatched Ambient Light Resistance (100K LUX)
Engineered to thrive in harsh conditions, the F2P operates flawlessly under direct sunlight (100K LUX) and high-intensity artificial light, making it uniquely suited for outdoor, industrial, and urban environments. Unlike conventional sensors that falter in bright settings, its advanced optics and algorithms maintain stable performance—whether deployed in sunlit construction sites, highway traffic gantries, or drone-based aerial surveys.
Multi-Interface Support (UART / I2C / I/O)
Designed for seamless integration, the F2P supports UART, I2C, and I/O interfaces, offering flexibility for embedded systems, PLCs, and custom hardware setups. The I/O trigger function allows synchronization with external devices like cameras or additional sensors, enabling synchronized data capture in multi-sensor arrays. This versatility makes it a go-to solution for developers needing plug-and-play compatibility across diverse architectures.
Dimensions of ToF laser ranging sensor
Figure: Dimensions of ToF laser ranging sensor
Note: The cable colors included with this product correspond to the power supply as follows: RED->GND, Black->VCC. Please carefully check the power connections before proceeding.
  • Drone & UAV Developers – For precise terrain following, landing assistance, and obstacle detection at high altitudes.
  • Smart Traffic Engineers – For vehicle speed detection, parking management, and toll gate automation.
  • Industrial Automation – For long-range material level monitoring, conveyor belt tracking, and large-area 3D scanning.
  • Robotics & AGV Systems – Where long-distance navigation and dynamic path planning are critical.
  • applications of ToF laser ranging sensor
  • Refresh Rate: 100Hz
  • Classic Ranging Range: 0.05~50m
  • Classic Ranging Accuracy: ±3cm
  • Wavelength: 905nm
  • Resistance to Ambient Light: 100K LUX Illuminance
  • Field of View (FOV): 1~2°
  • Power Supply Voltage: 4.3V~5.2V
  • Power Consumption: 250mW
  • Communication Interface: UART/I2C/IO
  • I2C Default Slave Address: 0x80
  • Operating Temperature: -10℃~60℃
  • Dimensions: 22.7 mm *28.0 mm *13.6mm
  • Product Weight: 7.5g
  • TOF laser ranging sensor-50m x1
  • Wiring x2
  • FAQ
    Only 1 Left
