SLAMTEC Aurora AI-Powered 3D Mapping & 6DOF Positioning Sensor (ROS2 Compatible)
$1101.00
SKU: DFR1220
Aurora is an all-in-one sensor for 3D mapping, integrating LiDAR, vision, IMU, and AI for precise indoor/outdoor positioning and navigation.
Purchase this product and earn 11010 reward points, which are tied to VIP membership program. Learn More >
SLAMTEC Aurora Positioning Mapping Sensor delivers a new approach to robotic perception by integrating LiDAR, binocular vision, inertial sensing, and AI processing into a single autonomous mapping platform. Designed for advanced robotics development, this all‑in‑one spatial perception system eliminates the traditional complexity of multi‑sensor fusion and algorithm integration. The intelligent mapping unit instantly produces high‑precision 3D maps and stable 6DOF localization data, enabling mobile robots to understand surroundings and maintain accurate positioning even in challenging environments. Robotics developers gain a ready‑to‑deploy perception solution that dramatically reduces months of integration effort while supporting ambitious autonomous platforms such as delivery robots, inspection systems, and agricultural AMRs.
AI‑Driven Fusion of LiDAR, Vision, and Inertial Sensing
SLAMTEC Aurora combines 2D LiDAR, binocular fisheye cameras, a 6DOF IMU, and a dedicated AI processor into a deeply integrated SLAM perception architecture. Proprietary neural network models analyze both geometric structure and visual features, extracting meaningful environmental landmarks such as wall textures, curb edges, and terrain variations. This AI‑enhanced perception engine allows the robotic mapping module to maintain precise localization even in visually repetitive or feature‑poor environments. Rapid rotations and dynamic movement no longer cause localization loss, providing robotics platforms with reliable mapping stability during high‑speed operation.
Figure: Traditional solutions lose positioning (left), while the Aurora solution remains stable (right).
Figure: Aurora's deep learning stability vs. Traditional high-speed rotation.
Full 3D Mapping and 6DOF Localization Out of the Box
This robotic perception sensor is engineered for modern embodied intelligence platforms requiring full spatial awareness. Built‑in LiDAR‑vision‑IMU fusion enables instant 3D mapping and continuous six‑degree‑of‑freedom positioning without external sensors or calibration complexity. Humanoid robots, quadruped robots, and advanced mobile machines gain accurate spatial understanding immediately after power‑up. Reliable operation across dark environments, complex terrain, and dynamic scenes ensures continuous high‑quality localization and mapping data for demanding robotics applications.
Massive‑Scale Mapping with Clean AI‑Filtered Point Clouds
The AI‑enhanced SLAM architecture supports extremely large‑scale mapping scenarios while maintaining high map clarity. Demonstrated performance includes mapping the entire 47.7 km Shanghai inner ring road—covering approximately 120 square kilometers—in a single continuous run. Advanced neural feature extraction filters noise and preserves stable environmental landmarks, producing clean and reliable point‑cloud maps. Simultaneously, the intelligent mapping platform generates a synchronized high‑precision 2D laser grid map, allowing existing 2D navigation algorithms to transition smoothly into modern 3D robotics workflows.
Figure: Escape the Noise. Traditional SLAM (left) vs. Aurora's clean, AI-driven perception (right).
Compact Plug‑and‑Deploy Robotics Integration
Advanced perception capability arrives in a compact and lightweight form factor designed for easy integration into robotic systems. The streamlined sensor housing occupies minimal installation space while providing robust onboard processing and multi‑interface connectivity. Deployment requires only mounting the unit, powering the system, and starting data acquisition. Real‑time mapping, localization, and perception outputs immediately become available for robotic navigation stacks, dramatically accelerating development timelines for autonomous platforms.
Video: SLAMTEC Aurora - A New Era of Mapping and Localization Solution
Autonomous robots operating in warehouses, outdoor campuses, agricultural fields, and research laboratories benefit from this integrated AI perception sensor. Reliable localization, large‑scale mapping capability, and simplified deployment make the system suitable for humanoid robots, robotic dogs, inspection drones, and autonomous mobile robots requiring accurate environmental understanding and navigation.
  • All‑in‑one perception system integrating LiDAR, binocular cameras, IMU, and AI processor
  • Real‑time 3D mapping with full 6DOF localization
  • AI‑based environmental feature extraction for stable positioning
  • Supports extremely large‑scale mapping environments
  • Simultaneous 3D point cloud and 2D laser grid map output
  • Stable localization during rapid motion and rotation
  • Multiple connectivity interfaces including USB‑C, Ethernet, and Wi‑Fi
  • Compact and lightweight design for robotic integration
  • Global relocalization and map continuation supported
  • Compatible with modern robotics development platforms and SLAM frameworks
  • Autonomous Navigation for Humanoid and Multi-legged Robots
  • Large-Scale Environmental Surveying and 3D Mapping
  • Warehouse & Logistics AMR (Autonomous Mobile Robot) Guidance
  • Construction Site Progress Monitoring and As-Built Verification
  • Autonomous Utility Vehicles (Lawn Mowers, Inspection Drones)
  • High-Precision Positioning in GPS-Denied Environments (Indoors, Tunnels, Urban Canyons)
  • University Research in Robotics, SLAM, and AI Perception
  • Power Input: DC 12V @ 2A (via DC5.5*2.1mm)
  • Power Consumption: 10W
  • LiDAR Range: 40m @ 70% Reflectivity
  • 2D Map Resolution: 2cm / 5cm / 10cm (Adjustable)
  • Maximum Map Area: >1,000,000 m²
  • Relocalization: Global Relocation Supported
  • Map Continuation: Supported
  • Data Interfaces: USB-C, Ethernet (RJ45), Wi-Fi
  • Positioning Mode: LiDAR + Vision + Inertial Fusion (SLAM)
  • Camera: Binocular Fisheye Global Shutter, HDR, FOV 180°, 6cm Baseline
  • Camera Frame Rate: 10Hz
  • Weight: 505g
  • Operating Temperature: 0°C to 40°C
  • Max Tilt Angle: No hard requirement (Recommend <30° for optimal 2D mapping)
  • SLAMTEC Aurora Positioning Mapping Sensor x1
  • Type-C to DC5.5*2.1 PD cable x1
  • Power adapter x1
  • Triangular bracket x1
  • Out Of Stock
