SLAMTEC Aurora AI-Powered 3D Mapping & 6DOF Positioning Sensor (ROS2 Compatible)
$859.00
SKU: DFR1220
Aurora is an all-in-one sensor for 3D mapping, integrating LiDAR, vision, IMU, and AI for precise indoor/outdoor positioning and navigation.
Purchase this product and earn 7730 reward points, which are tied to VIP membership program. Learn More >
Building the next generation of autonomous robots—whether a delivery drone for city parks, a humanoid robot for complex inspections, or an agricultural AMR for vast fields—presents a core challenge: enabling the machine to truly see, understand, and navigate its surroundings. Traditional approaches demand deep expertise in sensor fusion, often resulting in robots getting lost after the painstaking integration of separate sensors. The SLAMTEC Aurora changes everything. Born from over a decade of expertise, it ends this complexity as the industry's first all-in-one sensor. It seamlessly merges LiDAR, binocular vision, IMU, and AI to deliver instant, high-precision 3D maps and 6DOF positioning for the most ambitious robotics projects. Aurora is not just a sensor, but a complete perception solution that saves expert teams months of R&D and integration work.
AI + SLAM: A New Era of Perception
The Aurora achieves what was once considered a fundamental conflict in robotics: the harmonious marriage of LiDAR and vision. At its core is a powerful fusion of 2D LiDAR, binocular fisheye cameras, a 6DOF IMU, and a dedicated AI processor. This isn't just a hardware bundle; it's a deeply integrated system powered by proprietary deep learning models. This eliminates the need for in-house sensor fusion experts and bypasses years of complex algorithm development.
Its proprietary neural network models go beyond simple geometry to extract concise, meaningful features from the environment—the texture of a wall, the edge of a curb, subtle changes in terrain. This allows Aurora to build hyper-accurate maps and maintain its position with incredible stability, even when spinning rapidly or moving through visually repetitive or feature-poor areas.
Traditional solutions lose positioning (left), while the Aurora solution remains stable (right).
Figure: Traditional solutions lose positioning (left), while the Aurora solution remains stable (right).
Even when faced with high-speed rotation, Aurora's AI-driven perception captures millisecond-level position changes, ensuring the platform is never lost.
Aurora's deep learning stability vs. Traditional high-speed rotation.
Figure: Aurora's deep learning stability vs. Traditional high-speed rotation.
Embrace the 3D World, Indoors and Out
The SLAMTEC Aurora is engineered for the age of embodied intelligence. It delivers full 3D, 6DOF spatial positioning right out of the box, with no external dependencies required. Once powered on, it's ready to work. This makes it the perfect partner for humanoid robots, robotic dogs, and other advanced mobile platforms that need to navigate complex, real-world terrain.
From challenging the dark to mapping at high speeds, the Aurora's performance remains exceptional, providing a continuous stream of high-quality positioning and mapping data.
Unprecedented Scale and Detail
The power of this new architecture is best demonstrated by its sheer scale. The Aurora can successfully map the entire 47.7 km inner ring road of Shanghai, an area of 120 square kilometers, in a single run. This level of performance opens up possibilities for previously unimaginable applications.
While providing a rich 3D point cloud, Aurora also synchronizes the output of a high-precision, top-down 2D laser grid map. This brilliant feature facilitates the rapid migration of existing 2D-based navigation algorithms, protecting the software investment while upgrading to a 3D world.
Traditional solutions create noisy, cluttered points (left), while Aurora's AI extracts only clean, concise, and stable landmarks (right).
Figure: Escape the Noise. Traditional SLAM (left) vs. Aurora's clean, AI-driven perception (right).
Compact, Sleek, and Ready to Integrate
Powerful technology does not need to be bulky. The Aurora’s compact and sleek design takes up minimal space, making it easy to integrate into any robotic system. Operation is incredibly straightforward:
  • Install the sensor onto the platform.
  • Power it on.
  • Start collecting rich, real-time data.
  • SLAMTEC Aurora - Plug-and-Play for Robotic
    Video: SLAMTEC Aurora - A New Era of Mapping and Localization Solution
  • Autonomous Navigation for Humanoid and Multi-legged Robots
  • Large-Scale Environmental Surveying and 3D Mapping
  • Warehouse & Logistics AMR (Autonomous Mobile Robot) Guidance
  • Construction Site Progress Monitoring and As-Built Verification
  • Autonomous Utility Vehicles (Lawn Mowers, Inspection Drones)
  • High-Precision Positioning in GPS-Denied Environments (Indoors, Tunnels, Urban Canyons)
  • University Research in Robotics, SLAM, and AI Perception
  • Applications of SLAMTEC Aurora Positioning Mapping Sensor
  • Power Input: DC 12V @ 2A (via DC5.5*2.1mm)
  • Power Consumption: 10W
  • LiDAR Range: 40m @ 70% Reflectivity
  • 2D Map Resolution: 2cm / 5cm / 10cm (Adjustable)
  • Maximum Map Area: >1,000,000 m²
  • Relocalization: Global Relocation Supported
  • Map Continuation: Supported
  • Data Interfaces: USB-C, Ethernet (RJ45), Wi-Fi
  • Positioning Mode: LiDAR + Vision + Inertial Fusion (SLAM)
  • Camera: Binocular Fisheye Global Shutter, HDR, FOV 180°, 6cm Baseline
  • Camera Frame Rate: 10Hz
  • Weight: 505g
  • Operating Temperature: 0°C to 40°C
  • Max Tilt Angle: No hard requirement (Recommend <30° for optimal 2D mapping)
  • SLAMTEC Aurora Positioning Mapping Sensor x1
  • Type-C to DC5.5*2.1 PD cable x1
  • Power adapter x1
  • Triangular bracket x1
  • Out Of Stock
