Unleash true 1080p edge AI and interactive HMI applications with the FireBeetle 2 ESP32-P4 Development Kit. This all-in-one solution is engineered around the powerful ESP32-P4: a dual-core RISC-V processor featuring a Single-Precision FPU and a professional-grade media engine with hardware-accelerated H.264 encoding (1080p@30fps). The kit provides both MIPI and parallel interfaces for maximum camera and display flexibility, while an onboard co-processor delivers next-generation Wi-Fi 6 and Bluetooth 5. To bring it all together, the included IO Expansion Board streamlines development, providing an effortless platform to create sophisticated projects like high-performance AI cameras, responsive smart displays, and other advanced vision systems.
High-Performance AI and Video Processing
The ESP32-P4 is engineered for advanced HMI and video applications. Its 360MHz dual-core RISC-V CPU features a single-precision FPU and AI instruction extensions, providing powerful computational performance for complex algorithms.
It boasts a professional-grade multimedia engine, capable of handling 1080p video streams via its MIPI-CSI/DSI and parallel camera/display interfaces. The onboard hardware accelerator delivers real-time H.264 encoding at 1080p@30fps, while the integrated ISP, PPA, and 2D-DMA ensure smooth, responsive GUI development. Combined with native support for capacitive touch and speech recognition, this kit is the perfect choice for any intelligent interactive device.
Next-Generation Wireless Connectivity
A dedicated ESP32-C6 co-processor handles all wireless tasks, freeing the main ESP32-P4 CPU to dedicate its full power to AI models and video processing. This separation ensures maximum performance and stability for the core application.
Rapid Prototyping with IO Expansion Board
The IO Expansion Board is designed to eliminate common hardware bottlenecks like messy wiring and unstable connections. It provides a clean, reliable, and clearly labeled hardware foundation, freeing developers to focus on application code.
ESP32-P4 Development Board & IO Expansion Board
Compatibility Notice: This board uses the ESP32-P4 chip (v1.0). It is compatible with both Arduino IDE and ESP-IDF. Please note that the advanced MIPI-CSI and AI functions currently require the ESP-IDF. All other functions are fully supported in the Arduino IDE.
Processor & Memory
Interfaces & Peripherals
Physical & Electrical
Note: Peripheral functions are multiplexed. The numbers above represent the maximum available count for each type.
Projects [FireBeetle 2 ESP32 P4 Development Kit] Home Assistant IoT Stepper Motor Control
Projects Using a Raspberry Pi-Compatible CSI Camera with FireBeetle 2 ESP32 P4 (ESP-IDF)
Media DFRobot Launches FireBeetle 2 ESP32-P4 – The Ultimate Edge AI and Multimedia Development Platform
