NVIDIA Jetson Thor Developer Kit for Robotics & Embedded Edge AI (Pre-Order, 2070 FP4 TFLOPS, 14 Cores)
$3499.00
SKU: DFR1251
A compact developer kit for edge computing, featuring a high-performance GPU and CPU for advanced AI and robotics applications, with real-time sensor fusion and security.
Purchase this product and earn 34990 reward points, which are tied to VIP membership program. Learn More >
The NVIDIA® Jetson AGX Thor™ Developer Kit marks a paradigm shift in edge computing, establishing itself as the ultimate platform for building the next generation of physical AI and humanoid robotics. This compact developer kit, powered by the revolutionary NVIDIA Blackwell GPU architecture, delivers up to 2070 FP4 TFLOPS AI performance—over 7.5 times the AI compute and 3.5 times the energy efficiency of the Jetson AGX Orin™. Its powerful performance is specifically designed to effortlessly execute the latest large generative AI models and handle complex robotic workloads at the edge. The platform combines the high-performance, low-latency processing of a 14-core Arm® Neoverse®-V3AE CPU, 128GB of high-bandwidth LPDDR5X memory, and high-speed I/O including 4x25 GbE and PCIe Gen5, providing the foundation for cutting-edge applications like real-time multi-sensor fusion, spatial intelligence, and autonomous systems, making it the ideal solution for tackling the most demanding challenges in robotics and automation.
Please note: The NVIDIA Jetson AGX Thor Developer Kit is coming soon! We expect it to be in stock in mid-to-late October 2025.
Features of NVIDIA® Jetson AGX Thor™ Developer Kit
Figure: Features of NVIDIA® Jetson AGX Thor™ Developer Kit
A Supercomputer for Humanoids
Accelerate large transformer models and generative AI tasks directly on the device with the 2070 FP4 TFLOPS Blackwell GPU and its Multi-Instance GPU (MIG) capability for parallel processing.
Industry-Leading Performance for Humanoid Robots
Figure: Industry-Leading Performance for Humanoid Robots
Accelerated Robotics Stack
Enables faster development with the NVIDIA Isaac™ platform and GR00T foundational models. It provides a complete, end-to-end solution designed specifically for humanoid robotics and physical AI applications.
High-Speed Sensor Fusion
Ingest and process massive amounts of data in real time from high-resolution cameras, LiDAR, and other sensors with 4x25 GbE networking, a camera offload engine, and the Holoscan Sensor Bridge.
Enterprise-Grade Security
Delivers end-to-end safety and security across the entire deployment, from the compute hardware and AI models to the edge-to-cloud data pipeline.
Video: Get Started With NVIDIA Jetson Thor
  • Humanoid Robotics: Supercharge humanoid robot development with NVIDIA GR00T workflows.
  • Spatial Intelligence & VLM: Allows for the creation of powerful visual AI agents that can understand, summarize, and search video content in real time using the NVIDIA Video Summarization and Search (VSS) workflow.
  • Generative AI at the Edge: Bring the creative and reasoning power of generative AI to the physical world, enabling advanced interaction, content creation, and problem-solving in autonomous systems.
  • Real-Time Multi-Sensor Processing: Provides for the seamless building and deployment of high-performance sensor processing pipelines for medical devices, industrial automation, and more with NVIDIA Holoscan.
  • Workloads - Unlock Physical AI with the Power of Jetson Thor
    Figure: Workloads - Unlock Physical AI with the Power of Jetson Thor
  • AI Performance: 2070 TFLOPS (FP4, sparse)
  • GPU: 2560-core NVIDIA Blackwell architecture GPU with 96 fifth-gen Tensor Cores
  • CPU: 14-core Arm® Neoverse®-V3AE 64-bit CPU @ 1.6 GHz (1 MB L2 cache per core, 16 MB L3 cache)
  • Memory: 128 GB 256-bit LPDDR5X (273 GB/s)
  • Storage: 1 TB NVMe (on M.2 Key M slot)
  • Vision Accelerator: 1x PVA v3 (Programmable Vision Accelerator)
  • Video Encode: Up to 6x 4Kp60 (H.265), 12x 4Kp30 (H.265), 50x 1080p30 (H.265)
  • Video Decode: Up to 4x 8Kp30 (H.265), 10x 4Kp60 (H.265), 92x 1080p30 (H.265)
  • Networking: 1x QSFP28 (for 4x 25 GbE)
          1x 5 GbE RJ45 Connector
  • PCIe: 1x M.2 Key M slot (x4 PCIe Gen5)
          1x M.2 Key E slot (x1 PCIe Gen5, with WiFi/BT module)
  • USB : 2x USB-A 3.2
          2x USB-C 3.1
  • Display: 1x HDMI 2.0b
          1x DisplayPort 1.4a
  • Camera Interfaces: HSB camera via QSFP slot, USB camera support
  • Other I/O: 2x CAN Headers, 2x Automation Headers, 2x JTAG, Fan Connector, Audio Header, RTC Connector
  • Power: Configurable: 40 W – 130 W
  • Dimensions: 243.19 mm x 112.40 mm x 56.88 mm
  • Jetson AGX Thor Developer Kit x1
  • Only 2 Left
