The NVIDIA® Jetson AGX Thor™ Developer Kit marks a paradigm shift in edge computing, establishing itself as the ultimate platform for building the next generation of physical AI and humanoid robotics. This compact developer kit, powered by the revolutionary NVIDIA Blackwell GPU architecture, delivers up to 2070 FP4 TFLOPS AI performance—over 7.5 times the AI compute and 3.5 times the energy efficiency of the Jetson AGX Orin™. Its powerful performance is specifically designed to effortlessly execute the latest large generative AI models and handle complex robotic workloads at the edge. The platform combines the high-performance, low-latency processing of a 14-core Arm® Neoverse®-V3AE CPU, 128GB of high-bandwidth LPDDR5X memory, and high-speed I/O including 4x25 GbE and PCIe Gen5, providing the foundation for cutting-edge applications like real-time multi-sensor fusion, spatial intelligence, and autonomous systems, making it the ideal solution for tackling the most demanding challenges in robotics and automation.
Figure: Features of NVIDIA® Jetson AGX Thor™ Developer Kit
A Supercomputer for Humanoids
Accelerate large transformer models and generative AI tasks directly on the device with the 2070 FP4 TFLOPS Blackwell GPU and its Multi-Instance GPU (MIG) capability for parallel processing.
Figure: Industry-Leading Performance for Humanoid Robots
Accelerated Robotics Stack
Enables faster development with the NVIDIA Isaac™ platform and GR00T foundational models. It provides a complete, end-to-end solution designed specifically for humanoid robotics and physical AI applications.
High-Speed Sensor Fusion
Ingest and process massive amounts of data in real time from high-resolution cameras, LiDAR, and other sensors with 4x25 GbE networking, a camera offload engine, and the Holoscan Sensor Bridge.
Enterprise-Grade Security
Delivers end-to-end safety and security across the entire deployment, from the compute hardware and AI models to the edge-to-cloud data pipeline.
Video: Get Started With NVIDIA Jetson Thor
Figure: Workloads - Unlock Physical AI with the Power of Jetson Thor
