CS30 RGB-D ToF Depth Camera for ROS, Interactive AI & SLAM (1080P Color, 5m, 100°x75° FOV)
$299.00
SKU: SEN0673
The CS30 RGBD ToF Depth Camera offers high-fidelity 3D data with a compact design for robotics and AI applications, featuring RGBD fusion and broad OS support.
Purchase this product and earn 2990 reward points, which are tied to VIP membership program. Learn More >
CS30 RGBD ToF Depth Camera delivers compact, high‑precision 3D perception for robotics, AI vision, and machine intelligence applications. The integrated RGB‑D imaging system combines a Time‑of‑Flight depth sensing unit with a full‑HD color camera, enabling simultaneous capture of geometric structure and visual texture. By merging depth and color streams into detailed point‑cloud data, this compact 3D vision module simplifies environmental understanding for mapping, measurement, and interaction tasks. A small 90 × 25 × 25 mm form factor, USB connectivity, and cross‑platform software support allow rapid deployment in robotics, industrial vision systems, and intelligent sensing platforms.
High‑Precision RGBD Depth Sensing
Engineered for accurate spatial perception, this RGB‑D vision sensor fuses a 640×480 ToF depth imager with a 1920×1080 HD color camera to generate synchronized depth and color data streams. The fusion process produces dense point clouds enriched with visual detail, enabling robust scene reconstruction and object analysis. A sensing range of 0.1 m to 5 m supports both close‑range inspection and mid‑range environment capture. Millimeter‑level depth accuracy ensures reliable performance in demanding scenarios such as robotic SLAM, automated measurement, and 3D modeling.
Compact Design for Embedded Integration
This miniature ToF depth camera is optimized for embedded and mobile platforms where space and power efficiency are critical. The 90 mm × 25 mm × 25 mm enclosure allows straightforward integration into robotic platforms, smart devices, and industrial equipment. USB Type‑C connectivity provides stable data transfer while simplifying system wiring. With compatibility for Windows, Linux, and ROS environments, the RGB‑D sensing module supports rapid development workflows through available SDK tools and example code, accelerating the transition from prototype to functional AI vision systems.
The compact 3D imaging unit enables reliable perception across robotics, industrial automation, and interactive computing scenarios. Accurate depth mapping combined with real‑time color imaging supports tasks such as robot navigation, object scanning, gesture recognition, and spatial analytics. Flexible deployment, consistent depth performance, and integrated RGB‑D fusion make this depth‑sensing camera well suited for research laboratories, intelligent machines, and advanced computer vision applications.
CS30 RGBD ToF Depth Camera GUI Interface
Figure: CS30 RGBD ToF Depth Camera GUI Interface
CS30 RGBD ToF Depth Camera Demonstration Tools Scene
Figure: CS30 RGBD ToF Depth Camera Demonstration Tools Scene
CS30 RGBD ToF Depth Camera Shelf Point Cloud Depth Map
Figure: CS30 RGBD ToF Depth Camera Shelf Point Cloud Depth Map
CS30 RGBD ToF Depth Camera Portrait Plant Shapes
Figure: CS30 RGBD ToF Depth Camera Portrait Plant Shapes
Selection Guide
Depth Sensing Camera Selection Guide
Figure
SKU
SEN0581
SEN0583
SEN0579
SEN0673
Depth Resolution
100×100 @ 20fps
320×240
640×480 / 320×240
640×480 / 320×240
Sensing Range
0.15 – 1.5m
0.2 – 2m (indoor)
0.1 – 5m (90% reflectivity)
0.1 – 5m
RGB Support
No
Yes
No
Yes
RGB Resolution
N/A
800×600
N/A
1920×1080 / 640×480
Measurement Accuracy
≤1% / cm
≤1% / cm
±1.5cm @ 0.5m ±1% @ 0.5–5m
±2.5cm @ 0.5m ±1% @ 0.5–5m
FOV (Depth)
H70° × V60°
H55° × V72°
H60° × V45°
H97° × V95.5°
FOV (RGB)
N/A
H78° × V98°
N/A
H91.5° × V59°
Power Consumption
Low (5V supply)
Medium (with active cooling)
Avg. 1.2W (5V / 0.5A)
Avg. 3W (5V / 0.6A)
Data Interface
UART / USB 2.0
UART / USB 2.0
USB 2.0 Type-C
USB 2.0 Type-C
Compatibility
Windows / Linux / ROS
Linux (RNDIS)
Win10 / Linux / ROS
Win10 / Ubuntu / ROS
Special Features
Built-in LCD for real-time preview
RGB-3D fusion Python SDK
Dual-frequency / single-frequency modes Industrial-grade reliability
AI recognition Wide dynamic range
Laser Safety
N/A
N/A
Class 1
Class 1
Add to Cart
  • Integrated RGB‑D imaging combining ToF depth sensing and HD color capture
  • Depth resolution up to 640×480 with synchronized 1920×1080 RGB data
  • Working distance from 0.1 m to 5 m for short‑ and mid‑range perception
  • Millimeter‑level depth precision for measurement and mapping tasks
  • Compact 90 × 25 × 25 mm enclosure suitable for embedded robotics systems
  • USB Type‑C interface for stable data transmission and power supply
  • Compatible with Windows, Ubuntu Linux, and ROS environments
  • Supports point‑cloud generation for SLAM, 3D reconstruction, and vision AI
  • Robotic SLAM and autonomous navigation
  • Volume measurement and spatial dimension analysis
  • 3D object scanning and digital modeling
  • Motion sensing and gesture‑based interaction
  • Security monitoring and people counting systems
  • Industrial inspection, automation, and sorting
  • Applications of CS30 RGBD ToF Depth Camera
  • Depth image
        Resolution: 640*480/320*240
        FOV: H100°xV75°
  • Color image
        Resolution: 1920*1080/640*480
        FOV: H97° x V59.5°
  • RGBD fusion
        FOV: H91.5° x V59.5°
  • Working distance: 0.1-5m, indoor
  • VCSEL wavelength: 940nm
  • Precision: 0.1~0.5m: ±2.5cm; 0.5~5m: ±1% @ 90% reflectivity
  • Data transmission: USB 2.0, Type C Interface
  • Power supply: 5V, average 0.6A
  • Power consumption: average 3W
  • Operating system: Win 10, Ubuntu, ROS
  • Operating temperature: -10 ~ 50℃
  • Safety: Laser CLASS1
  • Size: 90mm x 25mm x 25mm
  • CS30 RGBD Depth Camera ×1
    Certifications
    Only 19 Left
