The ST3215 is a high-performance, intelligent serial bus servo engineered for advanced robotics and automation. Operating at 12V, it delivers a substantial 30kg.cm of torque, driven by a durable coreless motor and a high-strength metal gear train. Its core technology is a 12-bit high-precision magnetic encoder, which enables 360° absolute positioning with a resolution of 0.088°, offering superior accuracy and lifespan compared to traditional potentiometers. Communication is handled via a half-duplex UART serial bus, allowing up to 253 servos to be daisy-chained on a single port for simplified wiring and bi-directional data feedback. With four distinct operating modes, comprehensive electronic protections, and real-time parameter feedback, the ST3215 is an ideal solution for building complex robotic arms, quadruped robots, humanoid robots, and other sophisticated mechatronic systems.
360° High-Precision Magnetic Encoder
At the heart of the ST3215 serial bus servo is a 12-bit magnetic encoder that provides absolute position feedback over a full 360° range. With 4096 steps of resolution, it achieves a control accuracy of 0.088°, which is four times the resolution of conventional potentiometers. This non-contact sensing technology eliminates physical wear, leading to a much longer operational life. A key feature is the one-click midpoint calibration, allowing any position within the 360° range to be set as the new center point, greatly simplifying installation and maintenance.
High Torque & Durable Metal Gear Design
Engineered for demanding loads, the ST3215 serial bus servo provides a stall torque of 30kg.cm. The internal 1:345 gear train is constructed from a combination of copper and aluminum, ensuring high strength and low operational noise. Housed in a robust PA+GF casing, the servo is designed for reliability and longevity in applications requiring significant force and continuous operation.
Four Versatile Operating Modes
To accommodate a wide variety of applications, the ST3215 serial bus servo is equipped with four distinct operational modes.
Intelligent Serial Bus Communication
The ST3215 serial bus servo utilizes a TTL-level UART serial bus protocol, which enables daisy-chaining of up to 253 servos. This architecture drastically reduces wiring complexity in multi-axis robotic systems. The bus supports bi-directional communication, allowing not only for command execution but also for real-time feedback of critical parameters, including position, speed, load, voltage, and temperature. This capability is essential for creating closed-loop control systems and monitoring the health of the entire robotic assembly.
Advanced Control and Comprehensive Protection
The ST3215 serial bus servo integrates a suite of advanced features to ensure reliable and safe operation. The configurable acceleration start/stop function creates a smoother and more natural motion profile, reducing mechanical shock. Furthermore, built-in electronic protections guard against overload, overcurrent, overvoltage, and overheating conditions. These protections are customizable and automatically trigger to prevent damage to the servo, enhancing the overall system's robustness.
Electrical Characteristics
Mechanical Specifications
Control Characteristics
Reliability Testing
Signal Parameters
Oct 30, 2025
Super fast delivery in Chicago !!!
