Industrial All-Metal PWM Magnetic Encoder Brushless Servo (IP65, 24V, 450kg)
$399.00
SKU: SER0071
Industrial-grade servo with 24V brushless motor and 12-bit encoder offers 450kg·cm torque. IP65-rated aluminum housing for heavy-duty applications.
Purchase this product and earn 3990 reward points, which are tied to VIP membership program. Learn More >
All-Metal PWM Magnetic Encoder Brushless Servo (24V 450kg) is designed for high-load industrial motion control where torque, durability, and positional accuracy are equally critical. Powered by a 24V brushless motor and integrated with a 12‑bit magnetic encoder, this heavy‑duty actuator delivers up to 450kg·cm of stall torque while maintaining precise angular positioning. A sealed aluminum alloy housing, hardened steel gear train, and IP65-rated protection enable reliable operation in harsh environments involving vibration, dust, and moisture. This industrial servo solution is engineered for demanding robotics joints, automated machinery, and outdoor electromechanical systems that require consistent power and long operational lifespan.
Immense Torque for Heavy-Duty Loads
At the core of this high‑torque motion control module is a power‑optimized drivetrain capable of delivering an impressive 450kg·cm stall torque output. Such force enables precise actuation of large mechanical loads, making the brushless servo actuator well suited for robotic arm joints, steering systems of engineering vehicles, and marine rudder control assemblies. Brushless motor architecture improves electrical efficiency while reducing mechanical wear, enabling sustained torque delivery under continuous workloads. The result is a robust drive component capable of handling demanding mechanical tasks that exceed the capability of conventional hobby or mid‑grade servos.
Industrial-Grade Durability and Reliability
This IP65 waterproof servo integrates a full aluminum alloy enclosure paired with a hardened steel gear transmission system. The rigid metal structure enhances heat dissipation while resisting shock, vibration, and mechanical stress encountered in industrial deployments. Dust‑tight sealing and water‑resistant protection prevent environmental contaminants from affecting internal electronics and drivetrain components. Reliable operation across an extreme temperature range from -40°C to 60°C further supports deployment in outdoor automation equipment, marine installations, construction machinery, and other rugged mechanical platforms where environmental resilience is essential.
High-Precision Closed-Loop Control
A 12‑bit magnetic encoder provides high‑resolution positional feedback with a control resolution of 0.09°. This closed‑loop feedback mechanism allows the industrial motion servo to maintain an angular deviation within ±1° across its 180° operating range, ensuring repeatable and accurate positioning. Magnetic sensing technology operates without physical contact, eliminating the wear issues common in potentiometer-based feedback systems. Combined with precise PWM control, this encoder‑equipped servo module achieves reliable long‑term accuracy in robotics mechanisms, automated positioning platforms, and precision industrial actuation systems.
Motion Characteristics Diagram of  Industrial All-Metal PWM Magnetic Encoder Brushless Servo
Figure: Motion Characteristics Diagram
Such a high‑torque brushless servo module supports a wide range of demanding applications including industrial automation equipment, large robotic manipulators, marine steering systems, and heavy mechanical platforms. Durable construction, encoder‑based feedback, and powerful torque output make this precision actuator an effective motion control component for robotics development, automated machinery, and other high‑load engineering systems.
  • High-torque industrial servo delivering 450kg·cm stall torque at 24V
  • Integrated 12-bit magnetic encoder providing 0.09° positional resolution
  • Closed-loop PWM control with angular deviation ≤1°
  • Brushless motor design for higher efficiency and longer operational lifespan
  • Full aluminum alloy housing with hardened steel gear train
  • IP65-rated dust-tight and water-resistant protection
  • Wide operating temperature range from -40°C to 60°C
  • Designed for heavy-duty robotics, automation, and marine systems
  • Industrial Automation: Large valve control, sorting and stamping machinery
  • Heavy Robotics: Joints for large manipulators and AGV steering systems
  • Marine Equipment: Rudder control, winch and windlass drives
  • Specialized Machinery: Construction vehicle joints and PTZ platforms
    Performance
  • Operating Voltage: 16V – 28V (24V Recommended)
  • Stall Torque: 450 kg·cm (6,260 oz·in) @ 24V
  • No-Load Speed: 0.285s / 60° (35 RPM) @ 24V
  • Rated Torque: 150 kg·cm @ 24V
  • Control
  • Control Signal: PWM
  • Pulse Range: 500μs – 2500μs
  • Operating Angle: 180°
  • Sensor: 12-bit Magnetic Encoder
  • Positional Resolution: 0.09°
  • Angular Deviation: ≤ 1°
  • Mechanical
  • Housing: Aluminum Alloy
  • Gears: Hardened Steel
  • Gear Ratio: 1:252
  • Output Shaft: 25T Spline (11.8mm Diameter)
  • Dimensions: 86 × 45 × 100.3 mm
  • Weight: 850g (1.87 lbs)
  • Electrical
  • Motor Type: Brushless
  • Stall Current: 10.8A @ 24V
  • Rated Current: 3.5A @ 24V
  • No-Load Current: 360mA @ 24V
  • Power Connector: XT30
  • Durability
  • IP Rating: IP65 (Dust-tight and Water-resistant)
  • Operating Temperature: -40°C to 60°C (-40°F to 140°F)
  • Load Lifespan: >100,000 Cycles
  • All-Metal PWM Magnetic Encoder Brushless Servo (24V 450kg) ×1
  • Servo horn screw accessory kit ×1
  • Out Of Stock
