Industrial All-Metal PWM Magnetic Encoder Brushless Servo (IP65, 24V, 1000kg)
$650.00
SKU: SER0074
Industrial-grade brushless servo with 1000kg·cm torque, IP65-rated aluminum housing, and 12-bit magnetic encoder for precise control in heavy-duty applications.
Purchase this product and earn 6500 reward points, which are tied to VIP membership program. Learn More >
An industrial-grade, high-voltage brushless servo engineered to deliver exceptional torque and precision for demanding applications. It operates by integrating a high-efficiency brushless motor with a 12-bit non-contact magnetic encoder, all controlled via a standard PWM signal. The defining feature is an immense 1000kg·cm stall torque at 24V, combined with a robust, IP65-rated all-metal construction for durability in harsh conditions. This level of performance makes it an ideal actuation solution for applications in heavy machinery, marine equipment, and large-scale industrial automation.
Extreme Torque for Heavy-Duty Actuation
With a powerful stall torque of 1000kg·cm, this high-torque servo motor is designed to move significant loads with ease. The high-strength 390:1 steel gear train efficiently translates the motor's power into rotational force, providing the strength necessary to operate large mechanical joints, control steering mechanisms on heavy vehicles, or actuate industrial-sized valves. This actuation capability ensures reliable performance in applications where standard servos would fail.
Industrial-Grade Durability and Reliability
Built to withstand challenging operational environments, this industrial servo features a full aluminum alloy housing that is IP65-rated, offering complete protection against dust ingress and low-pressure water jets from any direction. The internal components, including the robust steel gears and ball bearings, are designed for longevity and can operate reliably in temperatures ranging from -40°C to 60°C. This rugged construction makes the 24V brushless motor suitable for outdoor, marine, and factory floor deployments.
High-Precision Control with Magnetic Sensing
Precision is achieved through a 12-bit magnetic encoder, which provides accurate positional feedback with a resolution of 0.09° and maintains an angle deviation of less than 1°. Unlike traditional potentiometers, this non-contact sensing technology is immune to wear, vibration, and debris, ensuring consistent accuracy over the actuator's extensive lifespan of over 200,000 cycles. Paired with the brushless motor, the system delivers stable, repeatable, and reliable positioning.
Motion Characteristics Diagram of Industrial All-Metal PWM Magnetic Encoder Brushless Servo
Figure: Motion Characteristics Diagram
  • Heavy machinery: Engineering vehicle steering, excavator joints
  • Marine equipment: Rudder controllers, windlass drives
  • Industrial automation: Stamping press positioning, large valve actuators
  • Specialized devices: Firefighting PTZ tilt mechanisms, stage robotics
    Power & Performance
  • Operating Voltage: 16V - 28V (24V Typical)
  • Stall Torque: 1000 kg·cm — enough to move seriously heavy loads.
  • Speed: 0.588 s/60° (17 RPM)
  • Motor Type: High-efficiency Brushless
  • Build & Durability
  • IP Rating: IP65 — Dust-tight and resistant to water jets. Ready for outdoor and rugged use.
  • Gears: Hardened Steel
  • Housing: All-Aluminum Alloy
  • Dimensions: 100 x 51 x 90.9 mm
  • Weight: 1000 g
  • Control & Sensing
  • Control Signal: Standard PWM (500-2500μs) — compatible with Arduino, Raspberry Pi, and other microcontrollers.
  • Rotation Angle: 180°
  • Position Sensor: 12-Bit Magnetic Encoder — for high-precision, wear-free positioning.
  • All-Metal PWM Magnetic Encoder Brushless Servo (24V 1000kg) ×1
  • Out Of Stock
