Industrial All-Metal PWM Magnetic Encoder Brushless Servo (IP65, 24V, 750kg)
$550.00
SKU: SER0073
This industrial-grade servo offers 750kg·cm stall torque, high precision with a 12-bit magnetic encoder, and an IP65-rated metal body, ideal for heavy-duty applications.
Purchase this product and earn 5500 reward points, which are tied to VIP membership program. Learn More >
This industrial-grade, high-voltage brushless servo is engineered for applications demanding immense torque, high precision, and exceptional reliability. It integrates a high-efficiency brushless motor with a 12-bit non-contact magnetic encoder, delivering superior performance over traditional servos. The key differentiators are its massive 750kg·cm stall torque at 24V, precise angular control with ±1° deviation, and a rugged, IP65-rated all-metal construction. This combination makes it an ideal actuator for heavy-duty robotics, industrial automation, and marine systems.
Massive 750kg·cm Stall Torque
This 750kg·cm brushless servo is designed to deliver extreme power, providing up to 750kg·cm of stall torque. This immense force is generated by a high-efficiency brushless motor paired with a robust 252:1 all-steel gear reduction system. Such high torque capacity enables the heavy-duty actuator to move heavy loads, overcome significant resistance, and provide stable holding force, making it suitable for the most demanding physical tasks.
High-Precision Magnetic Encoder
For precise and repeatable positioning, this high-precision servo utilizes a 12-bit magnetic encoder instead of a conventional potentiometer. This non-contact sensor technology offers a resolution of 0.09° and ensures an angular deviation of less than 1°. The magnetic encoder is immune to the wear, vibration, and dither issues common in mechanical potentiometers, resulting in significantly longer operational life and consistent accuracy over time.
Industrial-Grade Durability and Reliability
Engineered for longevity and continuous operation, the entire all-metal servo motor is housed in an IP65-rated, sealed aluminum case, protecting internal components from dust and water ingress. The brushless motor design offers a lifespan exceeding 100,000 cycles, far surpassing that of brushed motors. Combined with the wear-resistant steel gears, this industrial servo is built to withstand the rigors of industrial environments without compromising performance.
Designed for Harsh Environments
This high-voltage servo is built to operate reliably under extreme conditions. It functions across a wide temperature range, from -40°C to +60°C, ensuring consistent performance in both freezing and high-heat environments. The IP65 rating further guarantees its resilience against environmental factors, making it a dependable choice for outdoor machinery, marine equipment, and factory floor applications.
Motion Characteristics Diagram of Industrial All-Metal PWM Magnetic Encoder Brushless Servo
Figure: Motion Characteristics Diagram
  • Mega Robotics & Animatronics: Build a life-sized robotic arm, a heavy-lifting rover, or cinematic animatronics with powerful, realistic movements.
  • All-Weather Marine Projects: Design a robust steering system for a large remote-controlled boat, an automated anchor winch, or other marine gear exposed to the elements.
  • Workshop & Home Automation: Construct a custom CNC machine, a powerful automated vise, a smart solar panel tracker, or even open and close heavy gates and doors effortlessly.
  • Interactive Art & Exhibits: Create large, dynamic sculptures or interactive museum displays that require immense strength and reliable, repeatable motion.
    Power & Performance
  • Operating Voltage: 24V DC (nominal)
  • Stall Torque: 750 kg·cm (10433 oz·in) - That's enough power to move seriously heavy objects.
  • Speed: 0.385 sec/60° - Impressively quick for its size and torque.
  • Motor Type: High-efficiency Brushless
  • Precision & Control
  • Control Signal: Standard PWM (500-2500μs), compatible with Arduino, Raspberry Pi, and other microcontrollers.
  • Rotation Angle: 180°
  • Sensor: 12-bit Magnetic Encoder for high-resolution, non-contact positioning (far more durable than potentiometers).
  • Resolution: 0.09°
  • Built for Tough Jobs
  • IP Rating: IP65 - Dust-tight and resistant to water jets, ready for outdoor and messy projects.
  • Chassis: Full Aluminum Body
  • Gears: Hardened Steel
  • Operating Temp: -40°C to 60°C (-40°F to 140°F)
  • Physical Details
  • Dimensions: 90 x 48 x 109.3 mm
  • Weight: 1050 g (2.31 lbs)
  • Output Shaft: 25T Spline (11.8mm diameter)
  • All-Metal PWM Magnetic Encoder Brushless Servo (24V 750kg) ×1
  • Servo horn screw accessory kit ×1
    Out Of Stock
