GNSS-RTK High Precision Positioning Kit with LoRa (US 915 MHz, GPS / GLONASS / Galileo / BDS / QZSS)
$169.00
SKU: KIT0198-US
  • $164.00 3+ items
  • $160.00 5+ items
  • $155.00 10+ items
Achieve centimeter-level accuracy with the out-of-the-box GNSS-RTK Positioning Kit. Features a pre-configured LoRa data link for easy setup. Ideal for UAVs, device tracking, and mapping.
Purchase this product and earn 1690 reward points, which are tied to VIP membership program. Learn More >
The LoRa-Based GNSS-RTK High Precision Positioning Kit (US) is a comprehensive, dual-module system engineered to deliver centimeter-level location accuracy. It operates on the principle of Real-Time Kinematics (RTK), which involves a stationary base station transmitting correction data to a mobile rover, effectively eliminating common GNSS positioning errors. The kit's key differentiators are its out-of-the-box functionality with a pre-configured LoRa data link, its high-performance dual-band GNSS reception, and its rapid convergence time. Powered by Quectel LC29H series modules, the system supports GPS, GLONASS, Galileo, BDS, and QZSS constellations, making it a robust solution for demanding applications such as autonomous vehicle navigation, land surveying, and device tracking.
Schematic Diagram of GNSS-RTK High Precision Positioning Kit
Figure: Schematic Diagram of GNSS-RTK High Precision Positioning Kit
Out-of-the-Box, Centimeter-Level Accuracy
This GNSS-RTK positioning kit is designed to significantly lower the barrier to entry for high-precision positioning. Traditional RTK systems often require users to independently source and configure separate modules for the base, rover, and data transmission link. This product integrates all necessary components into a pre-configured, ready-to-use solution. Users can achieve centimeter-level accuracy within minutes of setup, bypassing the complex integration and debugging process typically associated with RTK technology.
Overview of GNSS-RTK High Precision Positioning Kit
Figure: Overview of GNSS-RTK High Precision Positioning Kit
High-Performance Dual-Band GNSS Engine
At the core of the system are the Quectel LC29H series modules, which feature dual-band (L1/L5) reception. This advanced capability allows the receiver to effectively mitigate ionospheric disturbances, a primary source of error in single-band receivers. The result is a significantly faster convergence time (less than 10 seconds to achieve a fixed solution) and more reliable and consistent positioning accuracy, even in challenging signal environments. Simultaneous tracking of all major satellite constellations ensures maximum satellite availability and positional integrity.
Integrated Long-Range LoRa Data Link (915 MHz US Version)
A stable data link is critical for RTK performance. This GNSS-RTK positioning kit incorporates a LoRa (Long Range) radio communication system to ensure robust and reliable transmission of correction data from the base station to the rover. This integrated wireless solution provides a communication range of up to 1.5 kilometers in open areas, eliminating the need for external radio modems or reliance on internet-based NTRIP services. This self-contained architecture makes the kit ideal for fieldwork and applications in areas with limited network connectivity.
  • Academic and Research Projects: Providing an affordable platform for learning and experimenting with high-precision positioning.
  • Autonomous Systems Prototyping: Enabling precise navigation and path-tracking for UAVs, rovers, and agricultural robots.
  • Geospatial and Surveying Tasks: Facilitating accurate mapping, boundary marking, and data collection for small-scale surveying.
  • High-Value Asset Tracking: Monitoring the exact location of equipment or personnel in open environments like construction sites or farms.
    Base Station
  • Power Input: Terminal Block (5~10V); Type-C
  • GNSS Antenna Interface: SMA
  • Reception Bands:
  • GPS/QZSS: L1 C/A, L5
  • GLONASS: L1
  • Galileo: E1, E5a
  • BDS: B1l, B2a
  • Default Constellations: GPS + GLONASS + Galileo + BDS + QZSS
  • Concurrent Tracking Constellations: 4+ QGNSS
  • Function: Base Station
  • Sensitivity:
              Acquisition: -147 dBm
              Tracking: -165 dBm
              Reacquisition: -159 dBm
  • Dynamic Performance:
              Max Altitude: 10000 m
              Max Velocity: 500 m/s
              Max Acceleration: 4 g
  • Raw Data Output Rate: 1 Hz
  • Protocol: NMEA 0183 / RTCM 3.x
  • Mobile Station (RTK Mobile)
  • Power Interface: Gravity interface, 3.3~5V
  • Output Signal: I2C / UART
  • Antenna Interface: SMA
  • Reception Bands:
              GLONASS: L1
              Galileo: E1, E5a
              BDS (BeiDou): B1l, B2a
  • SBAS: WAAS, EGNOS, MSAS, GAGAN
  • Function: RTK
  • Horizontal Positioning Accuracy:
              Autonomous: 1 m
              RTK: 5 cm + 1 ppm
  • Velocity Accuracy: 0.03 m/s
  • 1PPS Accuracy: 20 ns
  • RTK Convergence Time: < 10 s
  • Sensitivity:
              Acquisition: -145 dBm
              Tracking: -165 dBm
              Reacquisition: -157 dBm
  • Navigation Update Rate (RTK): 1 Hz
  • Raw Data Output Rate (GNSS): 1 Hz
  • LoRa Parameters
              RF Chip Semtech: LLCC68
              Operating Frequency: 915MHz
              Modulation: LoRa Spread Spectrum
              Max Transmit Power: 22dBm
              Receiver Sensitivity: -129dBm
  • Weight: 700g
  • RTK Base Station × 1
  • RTK Mobile × 1
  • GNSS Antenna × 2
  • TX915-JKD-20 LoRa Antenna × 2
  • Flathead Screwdriver × 1
  • Plug-in Terminal Block DB2EK-3.81-2P-GN-S (Female) × 1
  • PH2.0-4P Connection Cable (30cm) × 1
  • GNSS-RTK High Precision Positioning Kit with LoRa (US 915 MHz, GPS / GLONASS / Galileo / BDS / QZSS)
