GNSS-RTK High Precision Positioning Kit with LoRa (EU 868 MHz, GPS / GLONASS / Galileo / BDS / QZSS)
$169.00
SKU: KIT0198-EU
  • $164.00 3+ items
  • $160.00 5+ items
  • $155.00 10+ items
This all-in-one kit gives you everything needed for ultra-precise, centimeter-level RTK positioning right out of the box. Ideal for drone navigation, robotics, surveying, and any project that demands accuracy.
Purchase this product and earn 1690 reward points, which are tied to VIP membership program. Learn More >
The LoRa-Based GNSS-RTK High Precision Positioning Kit (EU Version) is a complete, out-of-the-box solution designed to deliver centimeter-level positioning accuracy. By leveraging Real-Time Kinematic (RTK) technology, the system utilizes a stationary base station to transmit real-time correction data via a LoRa wireless link, operating on the EU 868 MHz frequency, to a mobile rover unit. This process corrects for atmospheric and satellite orbit errors, enabling a positioning precision of up to 5cm + 1ppm. The key advantages of this kit are its exceptional accuracy, pre-configured simplicity, reliable long-range data transmission, and robust multi-constellation support, tracking signals from GPS, GLONASS, Galileo, BDS, and QZSS. It is engineered for applications demanding high precision, such as autonomous vehicle navigation, land surveying, and asset tracking.
Schematic Diagram of GNSS-RTK High Precision Positioning Kit
Figure: Schematic Diagram of GNSS-RTK High Precision Positioning Kit
Centimeter-Level RTK Accuracy
At the core of the kit are the Quectel LC29H series modules, which enable the system to achieve an RTK Fixed positioning status. This represents the highest level of precision, far surpassing the meter-level accuracy of standard GPS or GNSS receivers. By processing carrier phase observations and applying differential corrections, the mobile unit can determine its position with remarkable repeatability and reliability, making it suitable for professional and mission-critical tasks.
Overview of GNSS-RTK High Precision Positioning Kit
Figure: Overview of GNSS-RTK High Precision Positioning Kit
Out-of-the-Box Simplicity
This kit is engineered to make advanced RTK technology accessible. Unlike traditional component-based solutions that require users to configure their own data links, this system comes with a pre-configured wireless connection between the base station and the mobile unit. As a fully integrated solution, it eliminates complex setup procedures, significantly lowering the barrier to entry for developers, makers, and students, and allowing for rapid deployment in the field.
Reliable Long-Range Wireless Link
The transmission of correction data is handled by an integrated LoRa communication system operating at 868MHz. This technology provides a stable and reliable data link with a range of up to 1.5 kilometers in open areas. The robust wireless connection ensures that the mobile unit consistently receives the necessary RTCM data from the base station, maintaining high-precision positioning even at a distance.
Advanced Dual-Band, Multi-Constellation Support
To ensure optimal performance and signal availability, the modules support dual-band (L1/L5) reception across multiple global satellite navigation systems, including GPS, GLONASS, Galileo, BDS, and QZSS. This multi-constellation capability allows the receiver to track more satellites simultaneously, leading to faster signal acquisition, quicker convergence times (under 10 seconds), and improved positioning robustness in challenging environments such as urban canyons or areas with partial sky obstruction.
  • Academic and Research Projects: Providing an affordable platform for learning and experimenting with high-precision positioning.
  • Autonomous Systems Prototyping: Enabling precise navigation and path-tracking for UAVs, rovers, and agricultural robots.
  • Geospatial and Surveying Tasks: Facilitating accurate mapping, boundary marking, and data collection for small-scale surveying.
  • High-Value Asset Tracking: Monitoring the exact location of equipment or personnel in open environments like construction sites or farms.
    Base Station
  • Power Input: Terminal Block (5~10V); Type-C
  • GNSS Antenna Interface: SMA
  • Reception Bands:
              GPS/QZSS: L1 C/A, L5
              GLONASS: L1
              Galileo: E1, E5a
              BDS: B1l, B2a
  • Default Constellations: GPS + GLONASS + Galileo + BDS + QZSS
  • Concurrent Tracking Constellations: 4+ QGNSS
  • Function: Base Station
  • Sensitivity:
              Acquisition: -147 dBm
              Tracking: -165 dBm
              Reacquisition: -159 dBm
  • Dynamic Performance:
              Max Altitude: 10000 m
              Max Velocity: 500 m/s
              Max Acceleration: 4 g
  • Raw Data Output Rate: 1 Hz
  • Protocol: NMEA 0183 / RTCM 3.x
  • Mobile Station (RTK Mobile)
  • Power Interface: Gravity interface, 3.3~5V
  • Output Signal: I2C / UART
  • Antenna Interface: SMA
  • Reception Bands:
              GLONASS: L1
              Galileo: E1, E5a
              BDS (BeiDou): B1l, B2a
  • SBAS: WAAS, EGNOS, MSAS, GAGAN
  • Function: RTK
  • Horizontal Positioning Accuracy:
              Autonomous: 1 m
              RTK: 5 cm + 1 ppm
  • Velocity Accuracy: 0.03 m/s
  • 1PPS Accuracy: 20 ns
  • RTK Convergence Time: < 10 s
  • Sensitivity:
              Acquisition: -145 dBm
              Tracking: -165 dBm
              Reacquisition: -157 dBm
  • Navigation Update Rate (RTK): 1 Hz
  • Raw Data Output Rate (GNSS): 1 Hz
  • LoRa Parameters
              RF Chip Semtech: LLCC68
              Operating Frequency: 868MHz
              Modulation: LoRa Spread Spectrum
              Max Transmit Power: 22dBm
              Receiver Sensitivity: -129dBm
  • Weight: 700g
  • RTK Base Station × 1
  • RTK Mobile × 1
  • GNSS Antenna × 2
  • TX868-JKD-20 LoRa Antenna × 2
  • Flathead Screwdriver × 1
  • Plug-in Terminal Block DB2EK-3.81-2P-GN-S (Female) × 1
  • PH2.0-4P Connection Cable (30cm) × 1
  • Review
    andy.blyth Dec 08, 2025
    Straight out of the box functionality. Very easy to setup and use. Just connect to microcontroller and use the enhanced GPS data. Easy. Mine worked inside my office , but much faster externally.
    Only 15 Left
