FireBeetle 2 ESP32-C5 Development Kit for Smart Home (2.4/5GHz Wi-Fi 6, Home Assistant, BLE 5, Zigbee, Thread)
$8.90
SKU: DFR1236
  • $8.70 3+ items
  • $8.50 5+ items
  • $8.20 10+ items
Includes the FireBeetle 2 ESP32-C5 board and an IO expansion shield. The ESP32-C5 supports 2.4/5GHz Wi-Fi 6, BLE 5, Zigbee 3.0, and Thread 1.3. Perfect for building custom sensor nodes for Home Assistant via MQTT, Zigbee, or Matter and includes solar charging, battery management, and solderless connections.
The FireBeetle 2 ESP32-C5 IO Expansion Kit is an advanced development platform that combines the powerful FireBeetle 2 ESP32-C5 microcontroller with a dedicated IO expansion shield. Engineered for next-generation IoT applications, it delivers cutting-edge wireless performance, comprehensive protocol support, and robust power flexibility. At its core is the ESP32-C5, offering dual-band Wi-Fi 6 connectivity (2.4 & 5 GHz), alongside Bluetooth 5, Thread, and Zigbee.
This enables seamless integration into modern smart home platforms. It's an ideal choice for DIY enthusiasts building custom devices for open-source systems like Home Assistant or creating commercial products compatible with Matter. The development kit features an intelligent power management system with solar charging capabilities and an ultra-low deep sleep current of 21 μA. The included solderless IO expansion board simplifies prototyping, making it ideal for creating sophisticated projects such as custom Home Assistant sensor nodes, solar-powered outdoor monitors that report back via MQTT, or even a multi-protocol Zigbee/Thread gateway.
Next-Generation Connectivity with Dual-Band Wi-Fi 6
The ESP32-C5 is Espressif's first module to support Wi-Fi 6 on both 2.4 GHz and 5 GHz bands. The 5 GHz band provides higher transmission speeds, lower latency, and reduced interference, ensuring stable and responsive wireless connections. Wi-Fi 6 technology further enhances network capacity and efficiency through OFDMA and TWT mechanisms, significantly reducing device power consumption and extending battery life for long-term deployments.
FireBeetle 2 ESP32-C5 with IO Expansion Board
Figure: FireBeetle 2 ESP32-C5 with IO Expansion Board
FireBeetle 2 ESP32-C5 with Dual-Band Wi-Fi 6
Figure: FireBeetle 2 ESP32-C5 with Dual-Band Wi-Fi 6
Unified Smart Home Ecosystem with Multi-Protocol Support
This development board natively supports Wi-Fi, Bluetooth 5, Thread, and Zigbee protocols. This comprehensive support allows for the creation of Matter end-devices over Wi-Fi or Thread, enabling cross-platform interoperability among smart home products. This versatility makes it a powerful tool for Home Assistant users, who can leverage it to create reliable MQTT clients, build custom Zigbee devices, or experiment with Thread and Matter integrations, all with a single board.
Flexible & Efficient Power Management
Designed for versatile deployments, the board accommodates multiple power sources, including Type-C, 5V DC, and direct solar panel input for charging a lithium battery. An integrated solar power management IC maximizes charging efficiency across varying light conditions, making it suitable for outdoor or power-constrained locations. Onboard systems provide battery level monitoring and a controllable 3.3V power output, which can de-energize external sensors to achieve minimal power consumption during idle periods.
Rapid Prototyping with Solderless IO Expansion Board
The kit includes a dedicated IO expansion board that eliminates the need for soldering during initial development phases. All IO pins from the FireBeetle 2 ESP32-C5 are brought out to conveniently arranged headers with clear functional partitions. This design facilitates the quick and direct connection of various sensors, displays, and peripherals, allowing for immediate out-of-the-box use and accelerating the transition from concept to functional prototype.
  • Matter Smart Devices
  • Off-Grid Weather Station
  • High-Speed, Low-Latency Robot Controller
  • Multi-Protocol IoT Gateway
  • Prototype Interactive Art & Wearables
    Basic Parameters
  • Operating Voltage: 3.3V
  • Type-C Input Voltage: 5V DC
  • VIN Input Voltage: 5V DC or 4.5-6V solar panel
  • Maximum Charging Current: 0.5A
  • Sleep Current: 21 μA (deep sleep mode, battery powered)
  • Module Size: 25.4 x 60 mm
  • Hardware Information
  • Processor: RISC-V single-core processor
  • Clock Frequency: 240 MHz
  • SRAM: 384 KB
  • ROM: 320 KB
  • Flash: 4 MB
  • LP SRAM: 16 KB
  • Wi-Fi
  • Wi-Fi Frequency Bands: 2.4 GHz and 5 GHz, 1T1R
  • Wi-Fi Protocols: IEEE 802.11a/b/g/n/ac/ax
  • IEEE 802.11a/b/g/n (data rate up to 150 Mbps)
  • IEEE 802.11ax (20 MHz-only non-AP mode)
  • Wi-Fi Modes: Station mode, SoftAP mode, SoftAP+Station mode and Promiscuous mode
  • Bluetooth
  • Bluetooth Protocols: Bluetooth 5, Bluetooth mesh
  • Bluetooth Frequencies: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
  • IEEE 802.15.4
  • Compatible with IEEE 802.15.4-2015 protocol
  • Frequency Band: 2.4 GHz
  • Data Rate: 250 Kbps
  • Supports Thread 1.3, Zigbee 3.0
  • FireBeetle 2 ESP32-C5 Development Board Interface Pins
  • Digital I/O x18
  • LED PWM Controller with 6 channels
  • SPI x1
  • UART x3 (LP UART x1)
  • I2C x2 (LP I2C x1)
  • I2S x1
  • Infrared Transceiver: 5 transmitting channels, 5 receiving channels
  • 1x 12-bit SAR ADC with 7 channels
  • DMA Controller with 3 receiving channels and 3 transmitting channels
  • IO Expansion Board Interface Pins
  • IO x11
  • I2C x3
  • UART x1
  • SPI x1
  • RST x1
  • VIN: 5V x1
  • VOUT: 3V3_C x1
  • FireBeetle 2 ESP32-C5 IO Expansion Kit x1
    DIY Smart Interactive Eyes: Human Tracking & Blink Animation with ESP32-C5 (Arduino Tutorial)
    Projects DIY Smart Interactive Eyes: Human Tracking & Blink Animation with ESP32-C5 (Arduino Tutorial)
    auroraAA
    Nov 13, 2025
    Step-by-step Tutorial: Connecting FireBeetle 2 ESP32-C5 Development Board to Home Assistant Using MQTT
    Blog Step-by-step Tutorial: Connecting FireBeetle 2 ESP32-C5 Development Board to Home Assistant Using MQTT
    Aug 18, 2025
    FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Blog FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Jul 15, 2025
    Jan.Gruntmann Mar 17, 2026
    Fast Shipping and easy to work with. Build my own Grow Controller
    Ash.Barney Feb 27, 2026
    The break out board makes prototyping so much easier. Clearly labeled pins, plenty of I/O, and the ESP-C5 is a great project board.
