The FireBeetle 2 ESP32-C5 IO Expansion Kit is an advanced development platform that combines the powerful FireBeetle 2 ESP32-C5 microcontroller with a dedicated IO expansion shield. Engineered for next-generation IoT applications, it delivers cutting-edge wireless performance, comprehensive protocol support, and robust power flexibility. At its core is the ESP32-C5, offering dual-band Wi-Fi 6 connectivity (2.4 & 5 GHz), alongside Bluetooth 5, Thread, and Zigbee.
This enables seamless integration into modern smart home platforms. It's an ideal choice for DIY enthusiasts building custom devices for open-source systems like Home Assistant or creating commercial products compatible with Matter. The development kit features an intelligent power management system with solar charging capabilities and an ultra-low deep sleep current of 21 μA. The included solderless IO expansion board simplifies prototyping, making it ideal for creating sophisticated projects such as custom Home Assistant sensor nodes, solar-powered outdoor monitors that report back via MQTT, or even a multi-protocol Zigbee/Thread gateway.
Next-Generation Connectivity with Dual-Band Wi-Fi 6
The ESP32-C5 is Espressif's first module to support Wi-Fi 6 on both 2.4 GHz and 5 GHz bands. The 5 GHz band provides higher transmission speeds, lower latency, and reduced interference, ensuring stable and responsive wireless connections. Wi-Fi 6 technology further enhances network capacity and efficiency through OFDMA and TWT mechanisms, significantly reducing device power consumption and extending battery life for long-term deployments.
Figure: FireBeetle 2 ESP32-C5 with IO Expansion Board
Figure: FireBeetle 2 ESP32-C5 with Dual-Band Wi-Fi 6
Unified Smart Home Ecosystem with Multi-Protocol Support
This development board natively supports Wi-Fi, Bluetooth 5, Thread, and Zigbee protocols. This comprehensive support allows for the creation of Matter end-devices over Wi-Fi or Thread, enabling cross-platform interoperability among smart home products. This versatility makes it a powerful tool for Home Assistant users, who can leverage it to create reliable MQTT clients, build custom Zigbee devices, or experiment with Thread and Matter integrations, all with a single board.
Flexible & Efficient Power Management
Designed for versatile deployments, the board accommodates multiple power sources, including Type-C, 5V DC, and direct solar panel input for charging a lithium battery. An integrated solar power management IC maximizes charging efficiency across varying light conditions, making it suitable for outdoor or power-constrained locations. Onboard systems provide battery level monitoring and a controllable 3.3V power output, which can de-energize external sensors to achieve minimal power consumption during idle periods.
Rapid Prototyping with Solderless IO Expansion Board
The kit includes a dedicated IO expansion board that eliminates the need for soldering during initial development phases. All IO pins from the FireBeetle 2 ESP32-C5 are brought out to conveniently arranged headers with clear functional partitions. This design facilitates the quick and direct connection of various sensors, displays, and peripherals, allowing for immediate out-of-the-box use and accelerating the transition from concept to functional prototype.
Basic Parameters
Hardware Information
Wi-Fi
Bluetooth
IEEE 802.15.4
FireBeetle 2 ESP32-C5 Development Board Interface Pins
IO Expansion Board Interface Pins
Mar 17, 2026
Fast Shipping and easy to work with. Build my own Grow Controller
Feb 27, 2026
The break out board makes prototyping so much easier. Clearly labeled pins, plenty of I/O, and the ESP-C5 is a great project board.
