Smart UPS Expansion Board for LattePanda IOTA (18650 Battery)
$39.90
SKU: DFR1247
  • $38.80 3+ items
  • $38.00 5+ items
  • $36.80 10+ items
LattePanda IOTA 18650 UPS Board accommodates three user-supplied 3.7V 18650 Li-ion batteries and supports hardware-level configuration of auto power-on and safe shutdown via DIP switches. Power input is supplied through a USB Type-C (PD 20V) or a 5.5x2.5mm DC jack (12–24V, ≥36W). Features an ultra-low standby current of approximately 30μA. Dimensions: 88mm × 70 mm.
The LattePanda 18650 UPS Expansion Board is a high-performance uninterruptible power supply module engineered specifically for the LattePanda IOTA. It delivers a seamless, laptop-like power management experience through a true plug-and-play design. By leveraging the standard HID-UPS protocol, this LattePanda UPS module is natively recognized as a battery device in Windows 10 and 11, eliminating the need for drivers or custom programming. Its core function is to provide stable, continuous power, ensuring project stability and data integrity during unexpected power interruptions. Key features include intelligent hardware-level power management, an ultra-low power standby mode (~30μA), and a high-efficiency power path capable of supporting up to 8 hours of runtime with three 18650 cells. This makes it an essential component for mobile robotics, portable embedded systems, and any application requiring robust power-fail protection.
LattePanda IOTA & 18650 UPS Expansion Board
Figure: LattePanda IOTA & 18650 UPS Expansion Board
Plug-and-Play Simplicity
Integration is effortless thanks to the onboard HID-UPS protocol. When connected, the LattePanda IOTA's Windows operating system automatically identifies this 18650 UPS as a standard battery pack. This allows for immediate monitoring of battery status directly from the taskbar and ensures full compatibility with native system power policies, such as automated low-battery shutdown or sleep mode, without any software installation or configuration.
Intelligent Hardware-Level Power Management
This power management module provides users with direct, reliable control over critical power functions via an onboard 3-position DIP switch. This hardware-based approach allows for the configuration of essential behaviors like auto power-on when external power is applied, graceful system shutdown upon power loss, and setting the battery charging limit. This removes software dependencies and provides a robust, set-and-forget power management solution.
High-Efficiency for Extended Runtime
Designed for maximum energy efficiency, the power circuit minimizes conversion losses to prolong operational time. When equipped with three high-capacity 3500mAh 18650 lithium-ion cells, this uninterruptible power supply can sustain a LattePanda IOTA for up to 8 hours. This extended runtime is critical for applications that are mobile, deployed off-grid, or require long-term operation without access to a stable power source.
Ultra-Low Power Standby Mode
After the LattePanda IOTA performs a shutdown, the UPS expansion board automatically transitions into an ultra-low-power standby state, drawing a mere ~30μA of static current. This feature significantly reduces battery drain during long periods of inactivity, preserving the charge and protecting the overall health and lifespan of the 18650 cells, ensuring the system is ready for its next deployment.
Important Notes
  • Battery not included (due to aviation safety regulations)
  • Windows 10 / Windows 11 only (HID-UPS support is native in these OS versions)
  • Compatible only with LattePanda IOTA
  • Untethered Mobile Robots
  • Portable Cyberdeck or Workstation
  • Off-Grid Data Logger & IoT Hub
  • Interactive Art Installations & Kiosks
  • Resilient Edge AI Device
  • Charging Input:
          USB Type-C: Supports PD 20V input
          DC Jack: 5.5×2.5mm (center positive), 12–24V input
          Minimum Power Requirement: ≥36W
  • Battery Configuration: 3 × 3.7V 18650 Li-ion batteries (user-installed)
  • Max Charging Current: 1A
  • Static Standby Current: ~30μA (after system shutdown)
  • Onboard Output Interface: MX1.25 10-Pin connector (for LattePanda board)
  • OS Compatibility: Windows 10 / Windows 11 (native HID-UPS support)
  • Compatible Board: LattePanda IOTA
  • Dimensions: 88mm × 70 mm
  • UPS Expansion Board x1
  • 10-Pin Cable x1
  • M3 Hex Standoff x4
  • M3 Screw x4
  • User Manual x1
    Intel N150 LattePanda IOTA: Small Board, Huge Expandability
    Media Intel N150 LattePanda IOTA: Small Board, Huge Expandability
    Interfacing Linux
    Invalid Date
    Worlds Smallest PC And It GAMES - Latte Panda IOTA
    Media Worlds Smallest PC And It GAMES - Latte Panda IOTA
    Toasty Bros
    Invalid Date
    Andrew.Wickens Jan 24, 2026
    Great UPS solution for portable and embedded builds. This Smart UPS expansion board works very well with the LattePanda IOTA and makes battery-backed operation easy. Power switching is smooth, charging works reliably with 18650 cells, and it’s ideal for portable, mobile, or always-on projects. Solid design and very useful for anyone building compact x86 systems.
    Kaj Ronny.Nilsen Dec 08, 2025
    Very nice UPS HAT for the Iota, connects easily and works out of the box - just add three of those 18650's. Like the power screw terminals.
