LattePanda IOTA Active Cooler (Aluminum Heatsink & Fan)
$12.00
SKU: FIT1027
  • $11.60 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
Ultra-thin heatsink with adjustable-speed fan for efficient cooling of the LattePanda IOTA. Made of aluminum alloy and engineering plastic, features PWM fan control.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
This active cooler is an ultra-thin heatsink specifically designed for the LattePanda IOTA. Its adjustable-speed fan works together with the cooling fins to quickly dissipate heat generated by the processor, keeping the LattePanda board operating at an appropriate temperature to ensure optimal performance.
The main body is made of aluminum alloy with good thermal conductivity and comes with pre-applied thermal pads to ensure efficient heat transfer. Its surface is covered with a lightweight, high-temperature-resistant engineering plastic housing, giving it a restrained and attractive appearance.
Installation Steps:
1. Connect the fan's cable to the "FAN" connector on the back of the LattePanda board.
2. Apply an even layer of thermal paste to the processor.
3. Remove the protective film from the heatsink thermal pad, align the heatsink with the mounting holes on the back of the LattePanda board, and secure it using the screws and standoffs.
LattePanda IOTA and Active Cooler
Figure: Overview of LattePanda IOTA Active Cooler
Note:
  • 1.When installing or removing the cooler, the LattePanda IOTA must be powered off.
  • 2.The heatsink's air outlet should be installed facing the network port side.
  • Features
  • Ultra-thin cooling design: While providing heat dissipation, the ultra-thin profile maximizes the saving of valuable space
  • Dynamic Pressure Bearing Fan: Low noise, high airflow, long service life
  • Compatible Board: LattePanda IOTA
  • Operating Voltage: 5V
  • Operating Current: 0.22A
  • Fan Speed: up to 5300 RPM
  • Speed Control Method: PWM
  • Connector Type: MX1.25-4P (Flat Type)
  • Wire Length: 18±5mm(Exposed Length)
  • Dimensions: 87*69*10.45mm
  • Thermal Material: Aluminum Alloy
  • Housing Material: Temperature-resistant Engineering Plastic
  • Weight: 62g (Fan Only)
  • LattePanda IOTA Active Cooler x1
  • Active Cooler Accessory Kit x1
    Intel N150 LattePanda IOTA: Small Board, Huge Expandability
    Media Intel N150 LattePanda IOTA: Small Board, Huge Expandability
    Interfacing Linux
    Invalid Date
    Worlds Smallest PC And It GAMES - Latte Panda IOTA
    Media Worlds Smallest PC And It GAMES - Latte Panda IOTA
    Toasty Bros
    Invalid Date
    Spencer.Espinoza Apr 13, 2026
    Perfect for cooling the IOTA's CPU
    Jesse.Stephens Apr 07, 2026
    Love the sleek design of this while keeping inside the form factor
    Benjamin.Powell Apr 04, 2026
    Im a fan of the IOTA, super powerful and low cost replacement to the PI, getting a FAN is a must of course. so don't forget.
