The LattePanda IOTA Fanless Heatsink is a passive cooling solution specifically designed for the LattePanda IOTA. Made from high-quality aluminum alloy with a thickened design, it significantly enhances thermal capacity and heat dissipation area through its expanded volume and precision-machined fins.
Coupled with the included high-performance thermal paste, it ensures efficient heat transfer from the processor and uniform distribution across the entire heatsink.
Its fully passive, zero-noise construction and robust build provide reliable cooling stability for the LattePanda IOTA during continuous high-performance operation.
Installation steps:
1. Apply an even layer of thermal paste to the processor.
2. Mount it onto the back of the LattePanda board and secure with screws and standoffs.
Figure: LattePanda IOTA and Fanless Heatsink
Note:
Dec 08, 2025
Very good heatsink, which may be sufficient for lower power bands. Easy to add a fan, and it doesn't take much of a breeze to cool this big heatsink.
