Aluminum Heatsink Case for LattePanda IOTA
$29.90
SKU: FIT1029
  • $29.00 3+ items
  • $28.50 5+ items
  • $28.00 10+ items
This rugged aluminum heatsink case offers superior passive cooling and protection for the LattePanda IOTA, with silent operation and versatile mounting options.
The Aluminum Heatsink Case for the LattePanda IOTA is a rugged, high-performance enclosure engineered to provide superior passive cooling and robust physical protection. It functions by integrating the entire case body as a large heatsink, efficiently drawing heat away from the processor to prevent thermal throttling and ensure sustained performance. Key features include its fanless, silent cooling design, durable all-metal construction, and versatile mounting options. This case is specifically designed to enhance the stability and longevity of the LattePanda IOTA in demanding environments.
LattePanda IOTA & Aluminum Heatsink Case
Figure: LattePanda IOTA & Aluminum Heatsink Case
Superior Passive Cooling for Silent Operation
The case features a thickened, integrated heatsink structure that significantly increases the surface area for heat dissipation. This passive cooling design effectively transfers thermal energy from the LattePanda IOTA's processor, maintaining optimal operating temperatures without the need for a fan. This ensures completely silent operation and reliable, long-term performance under heavy computational loads, eliminating the risk of CPU throttling.
Rugged All-Metal Protection
Constructed from high-quality aluminum alloy with a fine sandblasted, glossy black anodized finish, this case offers exceptional durability. The solid, fully-enclosed design provides robust protection against physical impacts, scratches, and wear, safeguarding the delicate internal components of the LattePanda IOTA board in challenging conditions.
Versatile Mounting and Full Accessibility
Engineered for flexibility, the case is equipped with wing-shaped mounting tabs on the bottom. These provide stable placement on a desktop and include pre-drilled holes to support various installation methods, such as wall mounting. Despite its comprehensive protection, the case features precisely positioned cutouts, offering unimpeded access to all external ports on the LattePanda IOTA, ensuring full functionality and seamless integration with other devices.
Please Note:
Compatibility: This case is designed exclusively for use with the LattePanda IOTA model.
Safety Warning: To prevent burns, avoid direct skin contact with the heatsink or casing during operation as they may become hot.
  • Dimensions: 90.6*87.6*51.8mm
  • Material: Aluminum Alloy
  • Cooling Capacity: Processor TDP 10 W, ambient temperature 25°C, case temperature rise 40°C
  • Weight: 360g (Case Only)
  • Compatible Board: LattePanda IOTA
  • Aluminum Heatsink Case for LattePanda IOTA x1
  • Aluminum Heatsink Case Accessory Kit x1
    Justin. Feb 26, 2026
    Great looking case, easy to set up. Keeps it cool when set to lower wattage, but still allows higher wattage than standard passive cooling. Running mine at 10watts and performance is solid.
