BOSON Drip Irrigation Kit without Dev Board (Climate Action STEM Education)
$42.90
SKU: EDU0208
An educational coding kit for micro:bit and UNIHIKER designed to teach environmental science.
Purchase this product and earn 429 reward points, which are tied to VIP membership program. Learn More >
The BOSON Drip Irrigation Kit is a hands-on STEM educational kit designed to teach the principles of automated agriculture and water conservation. It operates by integrating environmental sensors with a micro:bit or UNIHIKER K10 microcontroller to construct a smart system that monitors soil moisture and available water levels. Based on this data, the system automatically irrigates plants, simulating real-world smart farming and water management solutions. Key features include a project-based approach to learning about climate action through UN Sustainable Development Goals (SDGs), a beginner-friendly design with a teacher-ready curriculum, and versatile platform compatibility. This classroom-ready kit is ideal for classroom instruction, STEM workshops, and at-home learning for students aged 8 and up.
Note: This kit requires a UNIHIKER K10 or micro:bit, which are sold separately. An all-in-one bundle with the UNIHIKER K10 board is also available.
Video: How to use BOSON Drip Irrigation Kit
Project-Based Learning for Climate Action
The STEM coding kit provides a scenario-based, immersive learning experience centered on UN Sustainable Development Goal 15: Life on Land. Students are tasked with building a functional model that combines a rainwater harvesting system with a smart drip irrigation system. This approach transforms abstract environmental concepts into a tangible project, making the purpose of learning to code clear and impactful. It addresses real-world problems like water scarcity, encouraging students to think critically about how technology can provide sustainable solutions.
Beginner-Friendly and Curriculum-Ready
Designed for absolute beginners, the environmental kit features a highly visual, step-by-step curriculum that ensures all students can follow along and build confidence. The included lesson plans are aligned with Next Generation Science Standards (NGSS) and Computer Science Teachers Association (CSTA) standards, making it an out-of-the-box resource for educators. The use of colorful, Lego-compatible BOSON modules and drag-and-drop programming lowers the barrier to entry for electronics and coding, fostering creativity and engagement.
Boson Drip Irrigation Kit Tutorial for micro:bit
Figure: Boson Drip Irrigation Kit Tutorial for micro:bit
Hands-On Sensor Technology and Coding
At the core of the learning experience is the interaction with real hardware. Students learn to connect and program a water level sensor and a soil moisture sensor to gather environmental data. They then write code to process this data and control a water pump, creating a closed-loop automated system. This process is fundamental to developing critical computational thinking and creative problem-solving skills, providing a solid foundation in both electronics and programming logic.
BOSON Drip Irrigation STEM Coding Kit - Hands-On Sensor Technology and Coding
Versatile Compatibility and Extensibility
The BOSON Drip Irrigation Kit offers broad compatibility, supporting both the popular micro:bit and the powerful UNIHIKER K10 microcontrollers. This flexibility allows it to be integrated into various existing classroom technology ecosystems. As part of the modular BOSON platform, the kit is also fully extensible. Students can expand their creations with a wide range of other BOSON sensors and modules, allowing the learning to grow with their skills from simple systems to more complex and innovative projects.
BOSON Drip Irrigation STEM Coding Kit Versatile Compatibility and Extensibility
  • Teaches Climate Action: Combines coding & hardware with UN sustainability goals (SDGs).
  • Easy for Kids(8+): Colorful, Lego-compatible blocks and simple drag-and-drop coding.
  • Grows with Skills: Wide range of sensors allows for more complex projects later.
  • Teacher-Ready: Includes full lesson plans for easy teaching, no expertise needed.
  • Module Input/Output Voltage: 3.3V
  • Maximum Current: 500mA
  • MicroUSB & Type C Power Port Voltage:5V
  • Working temperature: 0-60 ℃
  • Package size: 330*220*80 mm/ 12.99 * 8.66 *3.15 inches
  • Weight: 492g
  • Building Block Expansion Board x1
  • Water Level Sensor x1
  • Soil Moisture Sensor x1
  • Water Pump x1
  • 3-Pin Cable x2
  • Small plastic box x1
  • Plastic container x2
  • Building Blocks Parts Pack x1
  • Adjustable watering dripper x2
  • Plastic Tee Connector x1
  • Plastic Straight Connector x1
  • Tube x3
  • Scenario Board x1
    Boson Drip Irrigation Kit Tutorial for K10
    Tutorial Boson Drip Irrigation Kit Tutorial for K10
    Sep 25, 2025
    Boson Drip Irrigation Kit Tutorial for Micro:bit
    Tutorial Boson Drip Irrigation Kit Tutorial for Micro:bit
    Sep 25, 2025
