Create a private IoT network for under $100. No cloud fees, full data privacy. The DFRobot LoRaWAN Indoor Gateway (US915) is a comprehensive solution for home automation enthusiasts and IoT developers. Unlike traditional gateways that rely on external clouds, this device features a Built-in SIoT Local Server and Pre-installed Node-RED. Powered by a Quad-core Cortex-A35 processor and the high-performance Semtech SX1302 8-channel chip, it enables data collection from outdoor sensors (up to 4km range) with local processing. This architecture ensures data safety, facilitates home automation, and eliminates monthly subscription costs.
_0x0.png.webp)
LoRaWAN Gateway Local Server - Privacy, Speed, and Reliability.
Most gateways act as simple bridges to the internet. The DFRobot Gateway operates as a standalone processing unit.
_0x0.png.webp)
Figure: LoRaWAN local server configuration interface showing offline rule automation without cloud dependency
Automate with Built-in Node-RED
Zero-Code Logic for Everyone. Building complex IoT systems does not require programming expertise. The industry-standard visual programming tool, Node-RED, comes pre-installed on the device.
Scenario: Smart Irrigation
Figure: LoRaWAN Smart Irrigation System
Simplified Network Architecture
Complex configurations are unnecessary. The following diagram illustrates how the DFRobot Gateway simplifies data flow:
_0x0.png.webp)
Figure: Wiring diagram of LoRaWAN control terminal connecting soil sensors, liquid level sensors, and relay for water pump control
High-Performance Hardware
DFRobot LoRaWAN Series
DFRobot LoRaWAN product series is centered on "simplified development and efficient deployment", covering scenarios such as learning, development, testing, and deployment, and providing developers with comprehensive low-power wide-area network (LPWAN) solutions.
Video: Long-Range Private IoT with DFRobot LoRaWAN Gateway & Nodes: 4km Range, Local Server & Dashboard
Power Supply Specifications
LoRaWAN Parameters
Network Parameters
System Parameters
Physical Parameters
Supported Countries
