Private LoRaWAN Gateway with Built-in Local Server & Node-RED (US 915MHz)
$149.00
SKU: DFR1093-915
  • $146.00 3+ items
  • $142.00 5+ items
  • $137.00 10+ items
A LoRaWAN indoor gateway for the 915 MHz frequency band (US915/AU915). Features an 8-channel Semtech SX1302 chip, Quad-core A35 CPU, 512MB RAM, and 16GB eMMC. Integrates a local SIoT server for MQTT, a data parser, and visual Node-RED. Connectivity via 100Mbps Ethernet and 2.4G WiFi.
Purchase this product and earn 1490 reward points, which are tied to VIP membership program. Learn More >
Create a private IoT network for under $100. No cloud fees, full data privacy. The DFRobot LoRaWAN Indoor Gateway (US915) is a comprehensive solution for home automation enthusiasts and IoT developers. Unlike traditional gateways that rely on external clouds, this device features a Built-in SIoT Local Server and Pre-installed Node-RED. Powered by a Quad-core Cortex-A35 processor and the high-performance Semtech SX1302 8-channel chip, it enables data collection from outdoor sensors (up to 4km range) with local processing. This architecture ensures data safety, facilitates home automation, and eliminates monthly subscription costs.
DFRobot LoRaWAN Indoor Gateway with 4km long-range coverage for smart agriculture and home automation
Figure: DFRobot LoRaWAN Indoor Gateway with 4km long-range coverage
LoRaWAN Gateway Local Server - Privacy, Speed, and Reliability.
Most gateways act as simple bridges to the internet. The DFRobot Gateway operates as a standalone processing unit.
  • Total Privacy: Camera feeds, moisture levels, and location data never leave the local network.
  • Zero Latency: Local processing ensures instant response times for automations.
  • No Cloud Fees: Eliminates subscription services for data hosting.
  • Offline Operation: Smart garden or security systems continue functioning even without an internet connection.
  • LoRaWAN local server configuration interface showing offline rule automation without cloud dependency
    Figure: LoRaWAN local server configuration interface showing offline rule automation without cloud dependency
    Automate with Built-in Node-RED
    Zero-Code Logic for Everyone. Building complex IoT systems does not require programming expertise. The industry-standard visual programming tool, Node-RED, comes pre-installed on the device.
    Scenario: Smart Irrigation
  • Hardware: Gateway + Control Terminal
  • Logic: Connect a soil sensor to the Terminal's RS485/Analog port. Connect a water valve to the Relay port.
  • Node-RED Flow: Configure the Gateway to read sensor data -> If moisture < 20% -> Send Downlink command to open Relay.
  • LoRaWAN Smart Irrigation System
    Figure: LoRaWAN Smart Irrigation System
    Simplified Network Architecture
    Complex configurations are unnecessary. The following diagram illustrates how the DFRobot Gateway simplifies data flow:
    Wiring diagram of LoRaWAN control terminal connecting soil sensors, liquid level sensors, and relay for water pump control
    Figure: Wiring diagram of LoRaWAN control terminal connecting soil sensors, liquid level sensors, and relay for water pump control
    High-Performance Hardware
  • Semtech SX1302 8-Channel Chip: Handles dozens of sensors simultaneously with high sensitivity (-140dBm).
  • Quad-Core CPU: Powerful Cortex-A35 processor (1.3GHz) ensures Node-RED flows run smoothly without lag.
  • Auto Data Parsing: Automatically converts raw hex data into readable values (e.g., converting 0x1C to 28°C).
  • DFRobot LoRaWAN Series
    DFRobot LoRaWAN Series Products
    DFRobot LoRaWAN product series is centered on "simplified development and efficient deployment", covering scenarios such as learning, development, testing, and deployment, and providing developers with comprehensive low-power wide-area network (LPWAN) solutions.
  • Gateway: Embedded local MQTT server (SIoT) eliminates the need for server setup; supports Node-RED graphical programming for rapid automation task construction.
  • Control Terminal: Multi-interface design (analog/digital input, RS485, relays) enables both data acquisition and device control; supports custom control rules and stable offline operation without network connectivity.
  • Development Board: Compatible with the Arduino ecosystem, providing pre-built libraries and sample code for a low-threshold getting started; integrated with a screen, buttons, and other peripherals for real-time debugging without external devices.
  • Node Module: Built-in LoRa/LoRaWAN protocol stack, supporting multi-platform graphical programming; features standard I2C/UART interfaces, compatible with mainstream controllers such as Micro:bit, Arduino, and ESP32
  • Video: Long-Range Private IoT with DFRobot LoRaWAN Gateway & Nodes: 4km Range, Local Server & Dashboard
  • Crop Growth Monitoring
  • Greenhouse Temperature and Humidity Monitoring
  • Ecological Zone Environmental Monitoring
  • LoRaWAN Weather Station
  • Garden Planting Project
  • Outdoor IoT Teaching
    Power Supply Specifications
  • USB-TYPE-C Port: 5V 2A
  • DC2.1 Power Supply Port: 7-12V 2A
  • LoRaWAN Parameters
  • Channels: ×8
  • Operating Frequency Band: US915 AU915
  • Transmission Power: 27dBm MAX
  • Protocol: Class A/Class C
  • Sensitivity: -140dBm@292bps
  • Antenna Connector: SMA
  • Antenna: 5dB Gain
  • Network Parameters
  • WiFi: IEEE 802.11 b/g/n (2.4G)
  • AP Hotspot: IEEE 802.11 b/g/n (2.4G)
  • Ethernet: 1× 100Mbps Ethernet Port
  • System Parameters
  • CPU: Quad-core Cortex-A35, maximum frequency 1.3GHz
  • Memory: 512 MB DDR4 RAM
  • Flash Memory: 16GB eMMC
  • RTC: Built-in
  • RST Button ×1
  • BOOT Button ×1
  • Firmware Update: USB-TypeC
  • Physical Parameters
  • Product Dimensions: 142mm (L) × 102mm (W) × 30mm (H) (Antenna Excluded)
  • Product Weight: 445g (Including Packaging & Power Supply) / 188g (Gateway Host + Antenna)
  • Case Material: Environmentally Friendly ABS
  • Supported Countries
  • United States
  • Canada
  • Mexico
  • Brazil
  • Argentina
  • Australia
  • LoRaWAN Indoor Gateway (915MHz) × 1
  • Gateway Antenna × 1
  • AC/DC Power Adapter × 1
    Certifications
    LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Blog LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Jan 16, 2025
    6 Applications of Lora Technology
    Blog 6 Applications of Lora Technology
    May 03, 2023
    Getting Started with LoRaWAN
    Blog Getting Started with LoRaWAN
    May 05, 2023
    LoRa vs LoRaWAN
    Blog LoRa vs LoRaWAN
    Apr 11, 2023
    LoRaWAN Gateway Software
    Blog LoRaWAN Gateway Software
    Aug 09, 2023
