Building Block Expansion Board for micro:bit & UNIHIKER K10 (Wireless & LEGO-Ready)
$23.90
SKU: MBT0044
  • $23.50 3+ items
  • $22.80 5+ items
  • $22.00 10+ items
The Building Block Expansion Board is a multi-functional robotics interface designed for micro:bit and UNIHIKER K10. It integrates a rechargeable 18650 battery holder for autonomous operation, 4 motor ports, 4 servo ports, and native LEGO-compatible mechanical mounts.
Purchase this product and earn 239 reward points, which are tied to VIP membership program. Learn More >
The Building Block Expansion Board is a versatile wireless controller hub compatible with micro:bit, UNIHIKER K10, and UNIHIKER M10. Unlike standard breakout boards, it features a built-in 18650 battery slot that eliminates dependence on USB cables, making it indispensable for mobile robotics. With a LEGO-compatible base and plug-and-play Gravity ports, electronics can be snapped directly onto bricks to connect motors, servos, or AI cameras instantly—removing the need for complex wiring.
Compatibility Note: This version is designed for micro:bit and UNIHIKER K10. If you are using UNIHIKER M10, you require a specific data cable for connection. Please purchase the UNIHIKER M10 Bundle Kit instead.
Building Block Expansion Board compatible with UNIHIKER K10, micro:bit, and UNIHIKER M10 controllers.
Figure: Building Block Expansion Board compatible with UNIHIKER K10 and micro:bit.
Cable-Free Mobility
A robot is not truly "mobile" if tethered to a power source. This board addresses this limitation with an integrated rechargeable 18650 battery holder, capable of powering both the main controller and high-torque motors simultaneously. Additionally, the support for solar charging enables the creation of fully autonomous outdoor projects.
Seamless LEGO Integration
The design eliminates the need for adhesives or tape to attach electronics. The bottom of the board features a standard LEGO-compatible base, allowing it to snap securely onto beams and plates. This structural integration transforms the electronic module into a seamless part of the mechanical build.
DIY LEGO robot projects built with micro:bit and expansion board: tank, robotic arm, forklift, and helicopter.
Figure: DIY LEGO robot projects built with micro:bit and expansion board: tank, robotic arm, forklift, and helicopter.
3-in-1 Compatibility
Compatible with the classic micro:bit as well as the powerful UNIHIKER K10, this single board offers broad hardware support. It serves as a standardized platform for educational environments or workshops that utilize multiple types of controllers.
Top view of Building Block Expansion Board
Figure: Top view of Building Block Expansion Board
  • Mobile Robots: Build a line-following car or obstacle-avoiding rover that runs completely wireless.
  • Interactive LEGO Cities: Motorize elevators, gates, or windmills that react to sensors.
  • AI Companions: Mount a HUSKYLENS and K10 to create a pet robot that recognizes its owner.
  • Solar Projects: Utilize the PH2.0 solar port to create self-charging environmental monitors.
    Controller Compatibility:
  • micro:bit (V1 & V2)
  • UNIHIKER K10 (Direct Plug-in)
  • Power System:
  • Battery: Slot for 1x 3.7V 18650 Lithium Battery (User Replaceable)
  • Charging: USB Type-C, MicroUSB, or Solar (PH2.0)
  • Status: Onboard Power & Charging Indicator LEDs
  • Drive Capability:
  • Motors: 4x DC Motor Ports (PH2.0)
  • Servos: 4x Servo Ports (PH2.0)
  • Expansion Ports:
  • Sensors: 2x Digital/Analog IO (Gravity Standard)
  • I2C: 1x 3.3V I2C + 1x 5V I2C (Great for AI Cameras/OLEDs)
  • Special Features:
  • LEGO-Compatible Base: Standard spacing holes
  • Onboard RGB: 4x Programmable LEDs
  • Dimensions: 62mm x 88mm (Compact credit-card size footprint)
  • Building Block Expansion Board for micro:bit & UNIHIKER K10 x1
  • Building Block Expansion Board for micro:bit & UNIHIKER K10 (Wireless & LEGO-Ready)
