3.5" IPS Capacitive Touch Screen for ESP32 (480x320, GDI Port)
$29.90
SKU: DFR1092
  • $29.00 3+ items
  • $28.50 5+ items
  • $28.00 10+ items
The 3.5-inch IPS Capacitive Touch Screen with a resolution of 480x320. It utilizes optical bonding technology to reduce reflection and prevent dust ingress, offering a 178° wide viewing angle.
This 3.5-inch IPS Capacitive Touch Screen (480×320) utilizes advanced optical bonding technology to deliver superior clarity, reduced reflection, and dust resistance compared to standard displays. Designed for effortless integration with ESP32 and Arduino, the module features a dual-interface design: standard SPI for universality and DFRobot’s unique GDI port for a clutter-free, single-cable connection to FireBeetle controllers. Whether for smart home dashboards or retro gaming, this screen combines industrial-grade visuals with maker-friendly ease of use.
Cinema-Level Visuals with Optical Bonding
The high-quality IPS panel provides a superior 178° viewing angle, ensuring the display remains readable even from the side. The key upgrade in this model is the optical bonding process, where the touch panel and display are seamlessly laminated. This eliminates the air gap found in traditional screens, resulting in:
  • Higher Transmittance: Brighter and more vivid images.
  • Reduced Glare: Better readability under bright lights.
  • Dust Prevention: No gap means no dust accumulation inside the screen over time.
  • 5-Point Capacitive Touch: Offers a smooth, responsive smartphone-like interaction experience.
  • Plug-and-Play GDI Connectivity
    Wiring displays can often be complex, but this module simplifies the process. In addition to the universal SPI pin header, a GDI port is included. When used with DFRobot's FireBeetle 2 series (ESP32-E, ESP32-C5, etc.), the screen connects using a single FPC cable (included). This "One-Wire" solution eliminates the need for breadboards and jumper wires, ensuring the final project looks professional and clean.
    Accelerated Development Ecosystem
    The display module is designed to speed up prototyping. It includes an onboard MicroSD card slot, allowing for the storage of images and UI assets directly on the device without external breakout boards. On the software side, it is fully compatible with the powerful Arduino GDL library. With abundant examples available, complex UI elements like progress bars, buttons, and numeric keypads can be easily implemented, facilitating a rapid transition from initial code to a functional GUI.
  • IoT Control Panels: Smart home dashboards for controlling lights and reading sensors.
  • Desktop Gadgets: Wi-Fi weather stations, clock displays, or stock tickers.
  • HMI Systems: Monitoring screens for 3D printers or industrial equipment.
  • Interactive Entertainment: Portable retro game consoles or multi-function calculators.
    Basic Parameters
  • Operating Voltage: DC 3.3V ~ 5V
  • Operating Current: 80mA@5V
  • Communication Interface: SPI / GDI
  • Screen Parameters
  • Screen Size: 3.5-inch
  • Resolution: 480 × 320 (HVGA)
  • Panel Type: IPS
  • Viewing Angle: 178° (Full Viewing Angle)
  • Brightness: 300 cd/m²
  • Contrast Ratio: 800:1
  • Surface Treatment: Anti-Fingerprint Coating
  • Production Process: Optical Full Lamination
  • Active Area: 48.96 × 73.94 mm
  • Touch Characteristics
  • Touch Type: Capacitive
  • Touch Points: 5-point
  • Touch Interface: SPI/GDI
  • Mechanical Structure
  • Dimensions: 95.0 × 54.5 × 5.7 mm
  • Mounting Hole Diameter: 2.0 mm
  • Mounting Hole Spacing: 90 × 50 mm
  • Weight: 62.6g (with packaging)
  • Expansion Function
  • Storage Expansion: Onboard Micro SD Card Slot
    Software Support
  • Compatible with Arduino GDL library
  • 3.5" 480×320 IPS Capacitive Touch Screen ×1
  • 18pin-FPC Cable ×1
  • 14pin-2.54 Black Single Row Pin Header ×1
    Certifications
    David.Bachmann Jan 27, 2026
    The perfect IPS for ESP32
