Fermion: BMP585 High-Precision Barometric Pressure & Temperature Sensor (±0.3 hPa, I2C / SPI / I3C)
$9.90
SKU: SEN0666
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
The Fermion: BMP585 is a digital barometric pressure and temperature sensor based on the Bosch BMP585 interface. It measures pressure from 30 to 125 kPa with an absolute accuracy of ±0.3 hPa and a relative accuracy of ±0.06 hPa.
The Fermion: BMP585 High-Precision Barometric Pressure & Temperature Sensor is an ultra-compact, industrial-grade environmental monitoring module designed for space-constrained applications requiring extreme durability. By integrating the next-generation Bosch BMP585 MEMS chip into the miniature Fermion form factor (19×16mm), this digital altimeter breakout delivers laboratory-level absolute accuracy of ±0.3 hPa and ultra-low noise (< 0.1 Pa RMS) without occupying valuable PCB real estate. Distinct from standard sensors, the pressure sensing unit features a proprietary gel-filled cavity that provides robust protection against water, humidity, and chemicals. With a sleep current of just 2μA and support for I2C, SPI, and I3C interfaces, this miniaturized barometric board is the definitive solution for highly integrated devices such as smart wearables, micro-drones, and portable GPS trackers where size, power efficiency, and environmental resistance are non-negotiable.
Liquid and Chemical Resistant Design
Unlike traditional open-cavity MEMS sensors susceptible to environmental failure, the BMP585 module utilizes a specialized gel-filled housing. This industrial-grade protective layer effectively shields the sensing element from water intrusion, high humidity, and chemical corrosion without interfering with pressure transmission. Consequently, the ruggedized atmospheric sensor maintains consistent performance in complex outdoor scenarios, such as marine environments, sewer monitoring, or industrial sites, significantly extending the operational lifespan of the hardware.
Superior Precision and Stability
Designed for applications where every centimeter matters, the Fermion environmental sensor achieves an absolute pressure accuracy of ±0.3 hPa and calculates altitude with exceptional fidelity. The integrated low-noise circuitry ensures output noise remains below 0.1 Pa, eliminating the need for aggressive external filtering that causes data lag. This high-fidelity data output makes the digital barometer particularly effective for vertical velocity monitoring in UAVs (drone altitude hold) and detecting minute floor-level changes in indoor navigation systems.
Intelligent On-Chip Data Processing
To reduce the processing burden on the host microcontroller, the MEMS pressure instrument features built-in hardware FIFO buffering and a configurable IIR (Infinite Impulse Response) filter. These onboard processing capabilities allow the sensing component to smooth out pressure fluctuations caused by sudden wind gusts or mechanical vibrations directly at the hardware level. This results in cleaner signal output for the main controller, freeing up CPU resources for other critical tasks like flight stabilization or wireless communication.
Versatile Integration and Efficiency
Th pressure sensor is engineered for flexibility, supporting legacy I2C and SPI protocols as well as the modern I3C standard for higher throughput. With an operating current of 200μA during measurement and an ultra-low sleep current of approximately 2μA, the IoT-ready module is perfectly suited for remote, battery-operated deployments. The inclusion of open-source libraries for Arduino and Python further accelerates the development cycle for prototypes involving environmental data logging or smart wearable technology.
Selection Guide
Pressure/Altitude Sensor Selection Comparison Table
Figure
SKU
SEN0664
SEN0666
SEN0665
SEN0667
SEN0423
SEN0251
Add to Cart
Chip/Module Type
Bosch BMP585
Bosch BMP585
Bosch BMP581
Bosch BMP581
Bosch BMP390L
Bosch BMP388
Size/Volume
Compact module
Ultra-small PCB
Compact module
Ultra-small PCB
Ultra-small PCB
Compact module
Power Consumption
∼700μA
200μA / 2μA sleep
∼700μA
200μA / 2μA sleep
54μA sleep / max ∼650μA
~0.5mA
Interface Protocol
I2C / UART, plug & play
I2C / SPI / I3C
I2C / SPI / I3C
I2C / SPI
I2C / SPI
Accuracy / Key Features
±0.3hPa / Industrial protection
±0.3hPa + Waterproof & Chemical resistant
±0.3hPa / Ultra-low noise
±0.50hPa / ±3Pa (∼±0.25m) / High stability
±8Pa (∼±0.5m) / Temp ±0.5∘C
Ideal Scenarios
Industrial / Agricultural environmental detection
Outdoor weather stations / Environmental monitoring device integration
Drone altitude control / High-precision pressure data logging
Battery-powered IoT / Micro-drone project integration
Drone altitude control / High-precision pressure & altitude detection
Basic pressure measurement / Indoor positioning / GPS enhancement
  • UAV/Drones: Precision altitude hold and obstacle avoidance (waterproof protection).
  • Outdoor IoT: Weather stations and environmental monitors in high-humidity zones.
  • Sports Tech: Altimeters for hiking, climbing, and cycling computers.
  • Indoor Navigation: Floor detection and elevator positioning.
  • Hydrology: Water level detection (air pressure based).
    Basic Parameters
  • Operating Voltage: DC 3.3V
  • Operating Current: 200μA
  • Sleep Current: 2μA
  • Communication Interface: I2C / I3C /SPI
  • Interface Form: 2.54mm Pin Header Socket
  • I2C Address: 0x47 (Default) / 0x46
  • BMP585 Parameters
  • Pressure Measurement Range: 30 ~ 125 kPa
  • Temperature Measurement Range: 0 ~ 65 °C
  • Absolute Pressure Accuracy: ±0.3 hPa (Typ.)
  • Relative Pressure Accuracy: ±0.06 hPa / 10 kPa (Typ.)
  • Relative Altitude Accuracy: ±0.5 m / 10 kPa
  • Temperature Drift Coefficient: ±0.5 Pa / K
  • Pressure Data Resolution: 1 / 64
  • Ultra-Low Noise: < 0.1 Pa (RMS, without low-pass filter enabled)
  • Physical Dimensions
  • PCB Dimensions: 19×16×3.55 mm
  • Mounting Hole Spacing: 14 mm
  • Mounting Hole Diameter: 2.0 mm
  • Fermion: BMP585 High-Precision Barometric Pressure & Temperature Sensor ×1
  • 10pin-2.54 Black Single Row Pin Header ×1
    What is I3C: The Next Generation of I2C
    Blog What is I3C: The Next Generation of I2C
    Jan 20, 2025
