Fermion: BMP581 High-Precision Barometric Pressure Sensor (Bosch Flagship | ±0.3hPa | 3.3V)
$5.90
SKU: SEN0667
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
The Fermion: BMP581 is a compact digital barometric pressure and temperature sensor module based on the Bosch BMP581 chip. It delivers an absolute accuracy of ±0.3 hPa and features ultra-low noise (< 0.1 Pa) and power consumption (2μA sleep current). The module supports I2C, SPI, and I3C communication interfaces and operates at 3.3V DC.
The Fermion BMP581 is powered by Bosch Sensortec's latest generation high-performance barometric pressure sensor chip. Compared to its predecessors, the BMP581 represents a quantum leap in accuracy, temperature stability, and power efficiency. With an absolute accuracy of ±0.3hPa and minimal offset, this sensor precisely detects minute altitude changes, capable of distinguishing floor levels or monitoring liquid level variations.
Featuring a compact footprint and comprehensive support for I2C/I3C/SPI interfaces, this module is the ideal choice for drone altitude hold, indoor navigation assistance (floor detection), and outdoor fitness trackers. For projects demanding superior data quality within a strict budget, the Fermion BMP581 offers an uncompromising solution.
Accuracy ±0.3hPa of Fermion: BMP581 High-Precision Barometric Pressure Sensor
Figure: Accuracy ±0.3hPa of Fermion: BMP581 High-Precision Barometric Pressure Sensor
Laboratory-Grade Precision and Stability
At the core of this atmospheric monitoring unit lies advanced linearity compensation and digital filtering capabilities. The Bosch-powered module utilizes a configurable IIR (Infinite Impulse Response) filter and a built-in hardware FIFO buffer. These features work in tandem to suppress data jitter caused by sudden environmental disturbances, ensuring the output remains smooth and reliable even in dynamic conditions. Whether measuring vertical velocity in aerial vehicles or detecting subtle pressure shifts in HVAC systems, the device delivers consistent data integrity without burdening the host processor.
The Stable Flight of Fermion: BMP581 High-Precision Barometric Pressure Sensor
Figure: The Stable Flight of Fermion: BMP581 High-Precision Barometric Pressure Sensor
Ultra-Low Power Architecture for IoT
Power efficiency remains a critical constraint for remote sensing nodes and wearable electronics. The Fermion BMP581 addresses this by achieving a sleep current as low as 2μA. This minimal power footprint allows the barometric pressure tracker to operate for extended periods on coin-cell batteries or energy-harvesting sources. The integration of 6 bytes of non-volatile memory further enhances efficiency by storing user-defined configurations, eliminating the need for repeated initialization sequences and reducing overall system wake time.
Versatile Connectivity and Integration
Designed to accommodate diverse hardware ecosystems, the high-performance altimeter module supports three distinct communication protocols: I2C, SPI, and the emerging I3C standard. This flexibility ensures seamless compatibility with a wide range of microcontrollers, from 8-bit systems to advanced 32-bit IoT gateways. To accelerate the development cycle, the hardware design retains a compact footprint with a standard 2.54mm pin pitch, facilitating easy breadboarding and integration into finished PCBs.
Selection Guide
Pressure/Altitude Sensor Selection Comparison Table
Figure
SKU
SEN0664
SEN0666
SEN0665
SEN0667
SEN0423
SEN0251
Add to Cart
Chip/Module Type
Bosch BMP585
Bosch BMP585
Bosch BMP581
Bosch BMP581
Bosch BMP390L
Bosch BMP388
Size/Volume
Compact module
Ultra-small PCB
Compact module
Ultra-small PCB
Ultra-small PCB
Compact module
Power Consumption
∼700μA
200μA / 2μA sleep
∼700μA
200μA / 2μA sleep
54μA sleep / max ∼650μA
~0.5mA
Interface Protocol
I2C / UART, plug & play
I2C / SPI / I3C
I2C / SPI / I3C
I2C / SPI
I2C / SPI
Accuracy / Key Features
±0.3hPa / Industrial protection
±0.3hPa + Waterproof & Chemical resistant
±0.3hPa / Ultra-low noise
±0.50hPa / ±3Pa (∼±0.25m) / High stability
±8Pa (∼±0.5m) / Temp ±0.5∘C
Ideal Scenarios
Industrial / Agricultural environmental detection
Outdoor weather stations / Environmental monitoring device integration
Drone altitude control / High-precision pressure data logging
Battery-powered IoT / Micro-drone project integration
Drone altitude control / High-precision pressure & altitude detection
Basic pressure measurement / Indoor positioning / GPS enhancement
  • Drone stability hovering and vertical velocity control
  • GPS navigation enhancement (dead-reckoning, slope detection)
  • Indoor navigation and floor localization
  • Fitness tracking (calorie expenditure, elevation gain)
  • Precision weather stations and hydrological monitoring
    Basic Parameters
  • Operating Voltage: DC 3.3V
  • Operating Current: 200μA
  • Sleep Current: 2μA
  • Communication Interface: I2C / I3C /SPI
  • Interface Form: 2.54mm Pin Header Socket
  • I2C Address: 0x47 (Default) / 0x46
  • BMP581 Parameters
  • Pressure Measurement Range: 30 ~ 125 kPa
  • Temperature Measurement Range: 0 ~ 65 °C
  • Absolute Pressure Accuracy: ±0.3 hPa (Typ.)
  • Relative Pressure Accuracy: ±0.06 hPa / 10 kPa (Typ.)
  • Relative Altitude Accuracy: ±0.5 m / 10 kPa
  • Temperature Drift Coefficient: ±0.5 Pa / K
  • Pressure Data Resolution: 1 / 64
  • Ultra-Low Noise: < 0.1 Pa (RMS, without low-pass filter enabled)
  • Physical Dimensions
  • PCB Dimensions: 19×16×2.49 mm
  • Mounting Hole Spacing: 14 mm
  • Mounting Hole Diameter: 2.0 mm
  • Note: This module operates at 3.3V logic. A logic level converter is required when using with 5V microcontrollers (e.g., Arduino Uno).
  • Fermion: BMP581 High-Precision Barometric Pressure & Temperature Sensor ×1
  • 10pin-2.54 Black Single Row Pin Header ×1
    What is I3C: The Next Generation of I2C
    Blog What is I3C: The Next Generation of I2C
    Jan 20, 2025
