Gravity: GP8600 1-Channel I2C & PWM to 0-5V / 0-10V / 4-20mA DAC Module (16-bit)
$15.90
SKU: DFR1229
  • $15.50 3+ items
  • $15.20 5+ items
  • $14.70 10+ items
The DFRobot GP8600 is a high-precision 16-bit Digital-to-Analog Converter module designed for converting I2C or PWM digital signals into standard industrial analog outputs. The device supports configurable output ranges including 0-5V, 0-10V, and 4-20mA with a full-scale error of ±0.2%.
Purchase this product and earn 159 reward points, which are tied to VIP membership program. Learn More >
The Gravity: GP8600 16-bit DAC module is a high-precision signal conversion tool designed to bridge the gap between digital microcontrollers and analog industrial equipment. By converting I2C or PWM input signals into stable 0-5V, 0-10V, or 4-20mA outputs, this digital-to-analog converter enables makers to control standard industrial hardware—such as lighting systems, inverters, and valves—using logic-level controllers like Arduino, ESP32, or Raspberry Pi. Unlike basic 8-bit DACs, this GP8600 converter offers a linearity error of just ±0.2% and supports cascading up to 8 devices, making the unit ideal for complex, multi-channel automation projects requiring fine-grained control.
Industrial-Grade Signal Conversion
The GP8600 DAC module excels in scenarios requiring compatibility with industrial standards. While many microcontrollers only output weak 3.3V analog signals, this converter boosts these logic signals to industry-standard 0-10V voltage or 4-20mA current loops. This capability allows the GP8600 to drive water pumps, servo motors, and heavy-duty lighting drivers directly. The inclusion of a 4-20mA current mode is particularly valuable for transmitting signals over long distances in noisy electrical environments without signal loss.
Flexible Control & Expansion
Designed for scalability, the GP8600 16-bit converter supports 8 adjustable I2C addresses, enabling the simultaneous control of up to 8 independent channels from a single microcontroller interface. This feature simplifies the wiring for multi-axis motor controllers or complex LED arrays. Additionally, the device accepts a wide 3.3V-5V power supply and utilizes the standard Gravity PH2.0 interface, ensuring plug-and-play compatibility with the DFRobot ecosystem and widespread platforms like STM32 and Raspberry Pi.
Selection Guide
DFRobot Gravity DAC Module Selection Guide
Figure
SKU
DFR0552
DFR0971
DFR0972
DFR1071
DFR1036
DFR1037
DFR1073
DFR1035
DFR1230
DFR1034
DFR1229
Add to Cart
Description
I2C 12-Bit DAC
2-Ch 0-10V DAC
4-20mA Current DAC
1-Ch 15-Bit (0-10V)
1-Ch PWM (0-10V)
2-Ch PWM (0-2.5V)
2-Ch 15-Bit (0-10V)
1-Ch 15-Bit (0-2.5V)
Hi-Res ±10V / 4-20mA
2-Ch 12-Bit (0-2.5V)
Hi-Res 0-10V / 4-20mA
Comm.
I2C
I2C
I2C
I2C
PWM
PWM
I2C
I2C
I2C/PWM
I2C
I2C/PWM
Res.
12-bit
12-bit
12-bit
15-bit
8-bit
8-bit
15-bit
15-bit
16-bit
12-bit
16-bit
Channels
1
2
1
1
1
2
2
1
1
2
1
Output Range
0~VCC
0-10V / 0-5V
4-20mA (0-25mA)
0-10V / 0-5V
0-10V / 0-5V
0-2.5V / 0-VCC
0-10V / 0-5V
0-2.5V / 0-VCC
±10V, 0-10V, 4-20mA
0-2.5V / 0-VCC
0-10V, 0-10V, 4-20mA
Chip
MCP4725
GP8403
GP8302
GP8211S
GP8101S
GP8501
GP8413
GP8512
GP8630N
GP8503
GP8600
Key Features
Classic model, with EEPROM, cost-effective
Dual-channel industrial voltage, cascade up to 16 devices
Industrial current loop, requires 18-24V power
High precision (0.01%), single channel
PWM driven, easy to use, industrial voltage
PWM driven, dual channel, low voltage control
High precision, dual channel, industrial voltage
High precision, single channel, low voltage control
Flagship, supports bipolar (negative voltage) output
Medium precision, dual channel, low voltage control
16-bit ultra-high precision, multi-function all-in-one
  • Motor & Inverter Control: Precise 0-10V speed regulation for variable frequency drives (VFDs).
  • Smart Lighting Systems: Flicker-free, high-resolution dimming for 0-10V LED drivers.
  • Fluid Automation: Accurate position control for 4-20mA proportional valves and water pumps.
  • Lab Signal Generation: Creating custom voltage waveforms for testing sensors and analog circuits.
  • Device Retrofitting: Converting legacy analog appliances into smart, microcontroller-managed devices.
    Basic Parameters
  • Chip Model: GP8600
  • Operating Voltage: 3.3V-5V
  • Power/Communication Interface: PH2.0-4Pin/3Pin
  • Input Signal: I2C / PWM
  • Output Signal:
         Current Output Range: 0-20mA
         Voltage Output Range: 0-6V / 0-12V
  • Number of Channels: 1 channel
  • Resolution:
         16-bit (I2C mode)
         8-bit, 10-bit (PWM mode, selectable based on controller)
  • Full-Scale Error: ±0.2% (measured after fitting calibration)
  • Value Range:
          I2C Mode: 0-65535 corresponds to 0-6V, 0-12V, or 0-20mA
         PWM Mode:0-255 corresponds to 0-6V, 0-12V, or 0-20mA, 0-1023 corresponds to 0-6V, 0-12V, or 0-20mA
  • Physical Dimensions
  • PCB Dimensions: 38 × 32 × 12.39 mm
  • Mounting Hole Spacing: 25mm
  • Mounting Hole Diameter: 3.0 mm
  • Gravity: GP8600 1-Channel I2C & PWM to 0-5V / 0-10V / 4-20mA DAC Module ×1
  • Gravity-4Pin I2C/UART Sensor Cable ×1
  • Gravity-3Pin Analog Sensor Cable ×1
    Certifications
