Gravity: GP8630N I2C/PWM to ±10V / 4-20mA DAC Module (16-bit)
$17.90
SKU: DFR1230
  • $17.50 3+ items
  • $17.00 5+ items
  • $16.50 10+ items
A high-precision 16-bit DAC module capable of converting I2C and PWM signals into ±10V, 0-10V, 0-5V, or 4-20mA outputs. Features bidirectional voltage support for direct motor control and 1.2x over-range capability.
This Gravity: GP8630N DAC module functions as a high-precision digital-to-analog converter, transforming I2C or PWM digital signals into stable analog voltage or current outputs. Built around the GP8630N chip, this converter addresses the need for versatile signal generation in industrial and robotics applications by supporting multiple output modes including ±10V, 0-5V, 0-10V, and 4-20mA. The 16-bit resolution ensures fine-grained control for sensitive equipment, making this module an essential tool for automated systems requiring accurate analog inputs.
Bidirectional Control with ±10V Symmetrical Output
Unlike conventional DACs that only provide positive voltage ranges, this 16-bit DAC module generates a symmetrical ±10V output. This feature allows for the direct control of bidirectional devices without requiring complex external bridge circuits. For instance, in servo motor applications, a +10V signal can drive forward rotation, -10V enables reverse rotation, and 0V actuates a stop, significantly simplifying the hardware design for motor drive systems and valve actuators.
Flexible Integration and Wide Compatibility
Designed for broad interoperability, this I2C/PWM DAC module seamlessly interfaces with 3.3V and 5V logic levels. The dual-mode input capability ensures compatibility with a wide range of microcontrollers. Users can easily integrate this device into projects using Arduino for rapid prototyping, ESP32 for IoT-connected industrial nodes, or Raspberry Pi for complex computing tasks. Furthermore, the support for 8 configurable I2C addresses enables the cascading of multiple units, allowing simultaneous control of up to 8 devices on a single bus.
Selection Guide
DFRobot Gravity DAC Module Selection Guide
Figure
SKU
DFR0552
DFR0971
DFR0972
DFR1071
DFR1036
DFR1037
DFR1073
DFR1035
DFR1230
DFR1034
DFR1229
Add to Cart
Description
I2C 12-Bit DAC
2-Ch 0-10V DAC
4-20mA Current DAC
1-Ch 15-Bit (0-10V)
1-Ch PWM (0-10V)
2-Ch PWM (0-2.5V)
2-Ch 15-Bit (0-10V)
1-Ch 15-Bit (0-2.5V)
Hi-Res ±10V / 4-20mA
2-Ch 12-Bit (0-2.5V)
Hi-Res 0-10V / 4-20mA
Comm.
I2C
I2C
I2C
I2C
PWM
PWM
I2C
I2C
I2C/PWM
I2C
I2C/PWM
Res.
12-bit
12-bit
12-bit
15-bit
8-bit
8-bit
15-bit
15-bit
16-bit
12-bit
16-bit
Channels
1
2
1
1
1
2
2
1
1
2
1
Output Range
0~VCC
0-10V / 0-5V
4-20mA (0-25mA)
0-10V / 0-5V
0-10V / 0-5V
0-2.5V / 0-VCC
0-10V / 0-5V
0-2.5V / 0-VCC
±10V, 0-10V, 4-20mA
0-2.5V / 0-VCC
0-10V, 0-10V, 4-20mA
Chip
MCP4725
GP8403
GP8302
GP8211S
GP8101S
GP8501
GP8413
GP8512
GP8630N
GP8503
GP8600
Key Features
Classic model, with EEPROM, cost-effective
Dual-channel industrial voltage, cascade up to 16 devices
Industrial current loop, requires 18-24V power
High precision (0.01%), single channel
PWM driven, easy to use, industrial voltage
PWM driven, dual channel, low voltage control
High precision, dual channel, industrial voltage
High precision, single channel, low voltage control
Flagship, supports bipolar (negative voltage) output
Medium precision, dual channel, low voltage control
16-bit ultra-high precision, multi-function all-in-one
  • Supports ±10V symmetrical high-voltage output for bidirectional control
  • Provides standard 4-20mA current loop output for industrial sensors
  • High 16-bit resolution with low full-scale error (±0.2%)
  • Dual interface support: I2C and PWM input signals
  • Compatible with 3.3V-5V power supplies and Gravity interface
  • Motor Forward/Reverse Control
  • Lighting Brightness Control
  • Valve and Pump Control
  • Signal Generator
  • Automation Upgrades for Small Equipment
    Basic Parameters
  • Chip Model: GP8630N
  • Operating Voltage: 3.3V-5V
  • Power/Communication Interface: PH2.0-4Pin/3Pin
  • Input Signal: I2C / PWM
  • Output Signal:
         Current Output Range: 0-24mA
         Voltage Output Range: ±12V/0-6V/0-12V
  • Number of Channels: 1 channel
  • Resolution:
         16-bit (I2C mode)
         8-bit, 10-bit (PWM mode, selectable based on controller)
  • Full‑Scale Error: ±0.2% (measured after fitting calibration)
  • Value Range:
         I2C Mode: 0-65535 corresponds to ±12V, 0-6V, 0-12V, or 0-24mA
         PWM Mode: 0-255 or 0-1023 corresponds to output range
  • Physical Dimensions
  • PCB Dimensions: 42 × 32 × 12.39 mm
  • Mounting Hole Spacing: 25mm
  • Mounting Hole Diameter: 3.0 mm
  • Gravity: GP8630N 1-Channel I2C & PWM to ±10V / 0-5V / 0-10V / 4-20mA DAC Module ×1
  • Gravity-4Pin I2C/UART Sensor Cable ×1
  • Gravity-3Pin Analog Sensor Cable ×1
    Gravity: GP8630N DAC Module Accuracy Test Report
    Blog Gravity: GP8630N DAC Module Accuracy Test Report
    Mar 04, 2026
    Only 14 Left
