Gravity: STCC4 True Carbon Dioxide (CO2) Sensor (3-in-1 Air Quality Monitoring, 400 ~ 5000ppm)
$14.90
SKU: SEN0678
  • $14.50 3+ items
  • $14.20 5+ items
  • $13.80 10+ items
The Gravity: STCC4 Carbon Dioxide (CO2) Sensor is a highly accessible, 3-in-1 environmental monitoring module designed for rapid integration. Utilizing the Thermal Conductivity (TC) measurement principle, it delivers stable CO2 concentration readings (400 to 5,000 ppm) alongside precise ambient temperature and humidity data via an integrated SHT40 sensor.
The Gravity: STCC4 Carbon Dioxide (CO2) Sensor is a highly cost-effective, multi-functional air quality monitoring module designed for rapid hardware integration and scalable deployments. Utilizing the Sensirion STCC4 high-performance gas sensing chip based on the Thermal Conductivity (TC) measurement principle, this sensor delivers stable and reliable CO2 concentration readings. Its standout feature is the combination of extreme affordability with 3-in-1 measurement capabilities, integrating an onboard SHT40 sensor to provide simultaneous CO2 (with a measurement range of 400 to 5,000 ppm and an accuracy of ±[100 ppm + 10%]), ambient temperature, and humidity data.
Operating on a wide 3.3V to 5V voltage range and communicating via a standard I2C interface, it eliminates complex wiring and soldering. This makes the module highly suitable for deploying multi-node indoor air quality monitoring networks, building automation systems, smart home setups, and educational STEM projects where budget constraints, compact size, and ease of use are primary considerations.
features of Gravity: STCC4 True Carbon Dioxide (CO2) Sensor
True CO2 Measurement
The Gravity STCC4 CO2 sensor powered by Sensirion’s advanced Thermal Conductivity (TC) technology, it directly measures the physical thermal properties of the surrounding air to calculate absolute CO2 concentration (400–5000 ppm). Supported by a built-in Automatic Self-Calibration (ASC) algorithm, it ensures long-term stability and pin-point accuracy. Say goodbye to inaccurate estimations and build your HVAC automations, air quality alarms, and smart home systems on data you can actually trust.
Gravity STCC4 vs Traditional eCO2 Sensors Comparison
Unmatched Cost-Effectiveness for Scalable IoT Networks
By leveraging Thermal Conductivity technology, the manufacturing and operational costs are significantly reduced compared to traditional NDIR or PAS sensors. This high accessibility allows developers, engineers, and educators to build multi-room air quality networks or large-scale distributed IoT deployments without exceeding hardware budgets. It provides a highly viable alternative when deploying dozens of high-cost professional sensors is financially impractical.
Cross-sectional schematic diagram illustrating the internal Thermal Conductivity sensing mechanism of the STCC4 chip, featuring a micro-heater, temperature sensor, protective membrane, and ASIC.
Figure: Internal structural diagram illustrating the Thermal Conductivity (TC) measurement principle utilized by the STCC4 chip.
3-in-1 Sensing with Automatic Compensation
The inclusion of the onboard SHT40 sensor transforms the module from a single-purpose gas detector into a comprehensive environmental node. It continuously monitors ambient temperature and humidity, actively utilizing this data to automatically compensate the CO₂ readings. This ensures reliable accuracy in fluctuating indoor climates, outputs three critical environmental metrics from a single device, and simplifies the overall system architecture.
Arduino serial monitor interface displaying real-time data output from the STCC4 module, including CO2 concentration in ppm, ambient temperature in Celsius, and humidity percentage.
Seamless Integration and Plug-and-Play Design
Hardware development is streamlined through the standard Gravity I2C interface. The wide 3.3V to 5V operating voltage ensures native compatibility with popular microcontrollers such as Arduino, ESP32, and Raspberry Pi. The plug-and-play nature eliminates the need for breadboards, soldering, or complex level-shifting circuitry, significantly reducing development time and accelerating the transition from prototype to final product.
Hardware connection diagram showing the Gravity STCC4 CO2 sensor seamlessly connected to an Arduino microcontroller using a standard 4-pin I2C Gravity cable.
Figure: Plug-and-play hardware integration of the Gravity STCC4 CO2 Sensor with an Arduino microcontroller via a standard I2C interface.
Low Power Consumption for Continuous Monitoring
Designed for modern, energy-conscious applications, the module supports a highly efficient power profile. With a continuous measurement current of just 950 μA and a deep sleep mode drawing merely 1 μA, it is optimized for battery-powered smart home nodes and remote environmental monitoring stations requiring long-term, uninterrupted operation.
Figure: Real-time serial monitor data demonstrating simultaneous CO2, temperature, and humidity readings output directly from the sensor.
Selection Guide
CO2 Sensor Selection Guide
Figure
SKU
SEN0678
SEN0159
SEN0220
SEN0219
SEN0536
Operation Voltage
3.3 ~ 5V
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: I2C
Gravity: Analog (Analog2.7~4.1V) + 3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART (0~3.3V Level)
Gravity: I2C
Measurement Principle
Electrochemistry (Solid electrolyte battery principle)
NDIR (non-dispersive infrared)
photoacoustic NDIR
Measurement Range
400 ~ 5000 ppm
0~10000 ppm
0~50000 ppm
400~5000 ppm
400~5000 ppm
Accuracy
±(100 ppm + 10% of reading)
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<20s
<90s
<30s
60s
Average Power
<4.8mW@5V (950μA continuous)
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
10℃ ~ 40℃
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
20 ~ 80% RH (non-condensing)
0~95% RH (No condensation)
Dimension (PCB)
32*22 mm
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. 3-in-1 (CO2, Temp, Humidity) 2. High cost-effectiveness 3. Low power (1μA sleep) 4. Auto compensation 5. I2C Plug and play
1. Large Range 2. Adjustable Alarm Threshold 3. Fast Response 4. Analog Output
1. High Accuracy 2. Long Lifespan 3. Auto Temperature Compensation 4. Water Vapor Interference Resistance 5. Ananglog Output
1. High Accuracy 2. Large Range 3. Long Lifespan 4. Auto Temperature Compensation 5. Water Vapor Interference Resistance 6.3.3V UART Output
1.CO2, temperature, and humidity, three in one 2. Small size of 32*27*8mm 3. Low power, average current<4mA
Add to Cart
  • High measurement accuracy: Based on the TC principle for stable and reliable data
  • Low power consumption: Suitable for battery-powered or always-on systems
  • Compact size: Easy to integrate into space-constrained and modular design
  • Digital output: I2C interface with strong anti-interference capability
  • Plug and play: Standard Gravity interface, no soldering required
  • Indoor air quality monitoring: Real-time CO₂ detection to improve comfort in homes and offices
  • Smart home systems: Works with ventilation, air conditioning, and windows for automated airflow control
  • Building and classroom monitoring: Ensures air safety in high-occupancy environments
  • Environmental monitoring & IoT: Suitable for various IoT air quality nodes
  • Educational & experimental projects: Intuitive demonstration of CO₂ concentration changes for STEM education
  • Supply Voltage: 3.3–5.0 V DC
  • Operating Temperature: 10°C ~ 40°C
  • Operating Humidity: 20% ~ 80% RH (non-condensing)
  • Operating Current:
               Peak: 4.2 mA
               Continuous Measurement: 950 μA
               Single-shot Mode: 100 μA (10s sampling interval)
               Deep Sleep: 1 μA
  • CO₂ Measurement Range: 400–5000 ppm
  • CO₂ Accuracy: ±(100 ppm + 10% of reading)
  • Response Time: 20 s
  • Interface: Gravity I2C
  • Gravity STCC4 CO2 Sensor x1
  • Gravity 4Pin Cable x1
    How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Blog How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Mar 26, 2026
