RS485 Industrial-Grade Water Electrical Conductivity Sensor (K=10, EC / TDS / Salinity Support)
$159.00
SKU: SEN0707
  • $155.00 3+ items
  • $150.00 5+ items
  • $146.00 10+ items
Industrial-grade IP68 water conductivity sensor with RS485, temp compensation, salinity/TDS output, 10–20000 μS/cm range, for water and agriculture monitoring.
Purchase this product and earn 1590 reward points, which are tied to VIP membership program. Learn More >
This product is an industrial-grade water electrical conductivity sensor. The probe and housing are integrated into a single unit, resulting in a simple and convenient design for accurate measurement of water electrical conductivity. It features an electrode constant K=10, a measurement range of 10~20000 μS/cm, a resolution of 1 μS/cm, and an accuracy of ±1%FS. It also includes salinity and TDS conversion functions, allowing for the output of salinity and TDS data, meeting the needs of multi-parameter water quality monitoring.
Overview of RS485 Industrial-Grade Water Electrical Conductivity Sensor (K=10)
The electrical conductivity sensor is equipped with an RS485 communication interface and supports the standard ModBus-RTU protocol. Tutorials are provided for connecting the sensor to Arduino development boards and DFRobot LoRaWAN, enabling quick setup of a test environment and real-time data monitoring. A built-in temperature sensor provides automatic temperature compensation, ensuring accurate and reliable data output under varying environmental conditions.
Measurement data of RS485 Industrial-Grade Water Electrical Conductivity Sensor (K=10)
The electrical conductivity sensor is rigorously calibrated before leaving the factory and is ready for immediate use without further calibration. It also comes with a conductivity calibration solution, allowing users to quickly optimize measurement accuracy after prolonged use through register settings. With an overall waterproof rating of IP68, it can be submerged in water for extended periods, making it suitable for aquaculture, tap water monitoring, drinking water treatment, hydroponics, and agricultural irrigation applications.
  • Simple calibration function, supports electrode calibration
  • Measurement range: 10~20000 μS/cm, resolution: 1 μS/cm, accuracy: ±1% FS
  • Features salinity and TDS conversion function, capable of outputting salinity and TDS data
  • Integrated probe housing design, waterproof rating up to IP68
  • Built-in temperature sensor, automatic temperature compensation to ensure measurement accuracy
  • RS485 communication interface, supports ModBus-RTU protocol
  • Aquaculture & Fisheries: Real-time monitoring of water purity and salinity ensures a healthy environment for aquatic life.
  • Tap Water & Drinking Water Treatment: Tracking raw and treated water quality guarantees safe drinking water standards.
  • Hydroponics & Soilless Cultivation: Accurate control of nutrient solution concentrations boosts crop yields.
  • Agricultural Irrigation & IoT: Integration with LoRa/WiFi modules enables the creation of large-scale soil and water monitoring networks.
  • Power Supply Voltage: 10~30V DC
  • Power Consumption: 0.4W
  • Communication Interface: RS485 (Standard ModBus-RTU protocol)
  • Measurement Range:
             Conductivity: K=10: 10~20000 μS/cm
             Temperature: -20°C~+60°C
             Salinity: K=10: 0~11476ppm
             TDS: K=10: 0~13400ppm
  • Measurement Accuracy:
             Conductivity: ±1%FS
             Temperature: ±0.5°C
  • Resolution:
             Conductivity: 1 μS/cm
             Temperature: 0.1°C
  • Temperature Compensation Range: -20°C~+60°C
  • Temperature Compensation Coefficient: Default 0.02
  • Response Time: <1S
  • Operating Temperature: -20°C~+80°C
  • Waterproof Rating: IP68
  • Pressure Resistance: 0.6MPa
  • Cable Length: 5m
  • Housing Material: Corrosion-resistant plastic
  • RS485 Water Quality Electrical Conductivity Sensor (K=10) x1
  • 5m sensor cable x1
  • 12880μS/cm conductivity calibration solution 100ml x1
  • Black protective mesh x1
  • Cable ties x2
    Building a Continuous Water Quality Monitoring System? Meet the New RS485 Sensor Series
    Blog Building a Continuous Water Quality Monitoring System? Meet the New RS485 Sensor Series
    May 13, 2026
    DFRobot Electrical Conductivity (EC) Sensor Selection Guide
    Blog DFRobot Electrical Conductivity (EC) Sensor Selection Guide
    Apr 07, 2026
    Only 4 Left
