The Industrial water turbidity sensor based on the 90° light scattering principle. The probe and housing are integrated into a single unit, resulting in a simple and compact structure that is easy to use. It is designed for accurate measurement of turbidity in water, with a measurement range of 0-1000 NTU, a resolution of 0.1 NTU, and an accuracy of ±5% FS. The water turbidity sensor uses an infrared LED light source and a fiber optic light path design, incorporating a filtering algorithm to provide strong resistance to external light interference.
Developer Pro-Tips
Quick Comparison of the Water Quality Turbidity Sensors
